Novice- Need Help Wiring
Discussion in 'Lighting' started by thenewguywiththe24sr5, Feb 4, 2024.
  1. Feb 9, 2024 at 6:23 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That kit is set up to make what ever it powers turn off and on via that manual switch. It wouldn't turn on when the car starts. So your fangs or grill lights would only turn on manually.
    And if you did turn them on then you manually have to turn them off or they will just stay on and drain your battery even when your car is off.
    djwantke likes this.
  2. Feb 9, 2024 at 6:24 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Yes. This is exactly what I have done, x3!
    For the first one drilled a blank dash switch insert and installed the toggle switch inside. When I added two more 2-light wiring harnesses, I deleted that and wired to OE type dash switches.
    T in Texas and Thacrow like this.
  3. Feb 9, 2024 at 6:25 PM
    That's why I like em (I don't have raptor lights tho)
    I use em for trails and camping and other after dark stuff
    Thacrow[QUOTED] likes this.
  4. Feb 9, 2024 at 6:27 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Yeah would work great for spot lights and such but doesn't seem ideal for a passive running light like the fangs or grill lights.
  5. Feb 9, 2024 at 6:29 PM
    Yeah not my fog fangs, they come on with IGN
  6. Feb 9, 2024 at 6:39 PM
    @thenewguywiththe24sr5
    @Thacrow
    Just thinking out loud
    Theoretically, could we use the wiring harness kit for its all-in-one convenience and quality (my wiring harnesses are 16awg, 30A rated) but instead of energizing from pos battery terminal; t-tap the positive lead to DRL's for example / or piggyback to fusebox 12v? Then you leave the switch clicked to on but you have the ability to turn off independently.
  7. Feb 9, 2024 at 6:43 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Yeah my b.
    You would use an add-a-fuse. And use that as the positive.
    Ideally you would then separately fuse each accessory (and you can buy in life fuses to splice in just like the one this kit comes with so would jusylt need 1 more.)
    Then leave the switch on unless you want everything off.
    Well done dude.
  8. Feb 9, 2024 at 6:49 PM
    Right!?
    I'm learnding lol
    Wait so my wiring harnesses come with an inline 30A fuse built in to the positive lead near the battery connector. And then on the piggyback fuse holder add a fuse it's protected on the fuse box with a fuse there as well. I need more fuses than that?
  9. Feb 9, 2024 at 6:55 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I'm just saying specifically for OP's use case if he used this kit for both the fangs and the grill lights. Thats two things. You want the. Each on their own fuse so if one fails, then only one fails and you know there's an issue on that side instead of an issue just...somewhere. The add a fuse comes with a fuse so that's a lot of fuses. You don't need three it would just work like that if you used this kit.
    Or just do the one fuse on the add a fuse and cut the fuse off the kit. Don't need it.
    Whike It comes with a 30a fuse, I would buy a kit with a ton of different fuses and change it to a little over the max draw of everything being powered behind that fuse. For example, I have a 3a fuse on a small accessory on a motorcycle.
  10. Feb 9, 2024 at 6:58 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    OP if you want this really simple, go on Amazon and find any switch that has a 5 or 10amp rating. Your lights should be less than this.
    Then do the add a fuse to that switch. Boom. You're done. Don't need a relay.
    If you don't need the super clean look right now you can get a switch that looks like the switch on your kit that will handle the load no problem without a relay. You only need a relay if a switch can't handle it.
  11. Feb 9, 2024 at 7:00 PM
    Ahh I understand now you're exactly right. Thanks dumbing it down.
    Yeah I have 1-light and 2-light harnesses - on the two light circuits they are meant to always be on together.
    Another great point by you, cut out the inline fuse, go straight to add-a-fuse (since you already have to strip and crimp your pos wire to the add-a-fuse butt connector)
  12. Feb 9, 2024 at 7:01 PM
    This^
  13. Feb 9, 2024 at 7:05 PM
    That got me thinking what amperage is the cheapo wiring harness I bought recently for rear chase light?:
    It's 15A inline fuse and only 18awg (cheaper plastic switch button, and does come with an overkill 40A relay for some reason)
    $24 (CAD mind you) at the auto parts store
  14. Feb 9, 2024 at 7:22 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I always just Google "amp wire ga chart". Looks like you can run 10 feet at 15 amps on 18ga. But depends on how many amps the thing is you're powering and the length of the run.
    If you google this charts be careful about where the images are coming from. If from audio websites like Crutchfield the chart might be for amp power cables. Try not to use those as new amps run really efficiently and require less amps and thinner cables. So it might be off.
    djwantke[QUOTED] likes this.
  15. Feb 9, 2024 at 8:03 PM
    thenewguywiththe24sr5 [OP] New Member
    2024 SR5
    I’m trying so hard to understand what is going on, imma stick to the first tutorial
  16. Feb 9, 2024 at 10:23 PM
  17. Feb 9, 2024 at 10:37 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    lol - to the contrary i think you had one of the best ideas on here
    Both you and @djwantke have really good points. Why not keep it simple at first? you can decide later if you want to mess with the switchbacks.
    You could run the add-a-fuse to a switch like one of these 20a switches (or anything else)
    https://www.amazon.com/DaierTek-Rocker-Switch-Household-Appliances/dp/B07S1MV462?crid=22OARUEZIHWBV&keywords=10a+switch&qid=1707546884&sprefix=10a+switch%2Caps%2C141&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY
    and then out to both your fangs and grill lights.
    Ground those to almost anything that has bare metal
    zip tie everything up. zip tie the switch under the dash
    you're set.
  18. Apr 1, 2024 at 12:23 PM
    scottiezilla
    scottiezilla New Member
    ha…ha..haaaa
    My glove box has been out for bout a month
    Most days the HVAC is missing
    N bout 2 door foot sills, kick plate, left of steering are in the back seat….
    like all these mavericks said
    You’ll be good…but be cautious
