No Auto Lights?
Discussion in '5th Gen 4Runners (2010-2024)' started by coachhomer, Sep 2, 2023.
  1. Sep 5, 2023 at 6:13 PM
    #121
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Even better, you can add OE parts and get more functionality (auto dash . . . new thread?:p)
  2. Sep 5, 2023 at 10:22 PM
    #122
    At least a faulty switch can be easily replaced. What does John Q. 4RunnerOwner do when a component in the computer controlled auto headlight controller goes south? I suppose you join the rest of those forced to turn their lights on manually...
  3. Sep 6, 2023 at 8:13 AM
    #123
    backpacker
    backpacker New Member
    2023 TRD ORP
    I've never had an electronic failure like that - it's almost always mechanical parts of the switches (contacts, springs, catches), and they tend to fail when parts have become hard to get. Several of those I mentioned required steering column disassembly and junkyard parts. Fortunately parts are available much longer now that vehicle lifespans are longer.
  4. Sep 6, 2023 at 8:40 AM
    #124
    Agreed. I'm neither for nor against auto headlights. Mine doesn't have them, and I'm not missing them. I can see the value of them, but don't fall into the camp that they should be mandated across the model line.
  5. Sep 6, 2023 at 10:14 AM
    #125
    Lou
    Lou New Member
    2021 TRD Off Road Premium
  6. Sep 6, 2023 at 7:34 PM
    #126
    Gamma Ray
    2020 SR5 Barcelona Red
    Are you a pyromaniac? Because you're on fire!
  7. Sep 7, 2023 at 12:34 AM
    #127
    joshdub
    joshdub New Member
    2020 TRD ORP
    I don't think op is coming back to this thread. And that's what's wrong with America these days.
    gomiami and broken-giver like this.
  8. Sep 11, 2023 at 4:42 PM
    #128
    backpacker
    2023 TRD ORP
    I had to come back to this after trying it for a while. The problem for me is that leaving the lights on puts the head unit in permanent night mode. Hopefully swapping the dummy light sensor for a real one would fix that.
    djwantke[QUOTED] likes this.
  9. Sep 11, 2023 at 5:24 PM
    #129
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Is that right eh!?
    Yeah I don't do what Lou does I just use my right hand
  10. Sep 11, 2023 at 5:29 PM
    #130
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I'm offended by this comment. I'm going to give up and quit this site, then join another so I cam bash this one looking for validation
  11. Sep 11, 2023 at 5:31 PM
    #131
    FN2187
    FN2187 Stormtrooper
    Earth
    I didn't read the comment but assume it's similar to one I read a while back and practice. I keep them on 24/7 and just hit the lock button twice to turn them off.
    I would just turn them on when needed but I'm right handed and lazy
  12. Sep 11, 2023 at 5:56 PM
    #132
    FN2187
    FN2187 Stormtrooper
    Earth
    I had auto headlights on my '04 JGC and thought I was hot shit. When I lived in the country I thought it was stupid because as others have stated, I grew up turning them on and it's obvious when they aren't on. However, when I moved close-ish to DC where a lot of the highways and interstates are lit, you'd be surprised how many ding dongs drive out of a shopping center or gas station at night and don't turn them on because it's hard to tell they aren't on. Because I didn't have to guess or think about it (plenty of traffic to occupy the driving mind) I really began to appreciate them
  13. Sep 11, 2023 at 5:57 PM
    #133
    Naw actually my point was contrary to Lou, I don't keep 'em on I use my left hand to turn lights on like simpletons from the early 20th century
  14. Sep 11, 2023 at 6:03 PM
    #134
    FN2187
    FN2187 Stormtrooper
    Earth
    There we go, this is why I didn't make the joke I wanted to make earlier! Left hand is for headlights so not sure why edited but...
    My right hand is usually occupied while driving so I can't operate the light stalk. High-oh!
    gomiami likes this.
  15. Sep 11, 2023 at 6:09 PM
    #135
    shooter1231
    shooter1231 New Member
    2023 Mag Gray 4Runner Limited
    My 2023 Limited is the first vehicle I've ever owned with auto lights and DRLs. At first I didn't like them. Kept manually turning the headlights off. Couldn't stop doing it - after almost 43 years of driving with normal headlights it was just muscle memory to turn them off. Used to do it when I occasionally drove my wife's CR-V. She'd yell at me for turning the headlights off - couldn't help it. I'm used to them now and don't turn them off anymore. They're fine. Would've bought the 4Runner without them and not thought twice about it - but they work OK - and I'm used to them now. I still have the auto high beams turned off though. When I first got the 4Runner everyone kept flashing their brights at me - figured the auto high beams weren't turing off quickly enough - but I still get brights flashed at me when just driving with low beams - so probably try turning them back on.
  16. Sep 11, 2023 at 6:18 PM
    #136
    FN2187
    FN2187 Stormtrooper
    Earth
    I think growing up driving a manual is why I'm so used to driving with the one left hand on top of the steering wheel - I still find myself doing it.
    I remember when headlights were a pull knob from the dash rather than being on the stalk too. Not necessarily because I'm that old but just driving older cars.
    It's not a necessary feature but one of the more convenient of the tech features that at least doesn't have the feel of the car trying to drive you
  17. Sep 11, 2023 at 6:23 PM
    #137
    Oakboro, N.C
    Kinda wish we still had the floor push button on the left of the brake pedal to activate high beams. That was sweet...
    Dash buttons rocked in regards to shut down procedure. Find myself leaving headlights on ( while on the stalk) several times a week.
    HuskyMike likes this.
  18. Sep 11, 2023 at 6:26 PM
    #138
    FN2187
    FN2187 Stormtrooper
    Earth
    I've driven those too - also a cool feature if you don't have a clutch.
    I remember auto high beams from the 80's - they'd flicker like a strobe light every time you passed a reflective road sign. Tech has come a long way. The auto high beams in the JGC even "see" tail lights and will dim
  19. Sep 11, 2023 at 6:32 PM
    #139
    backpacker
    2023 TRD ORP
    Yeah, I like the floor button for high beams. As far as push-buttons go, The first car I drove was a '64 Dodge Polara, which had push-button gear select. I can't remember if the pull-out light switch on that was on the left or right, but I suspect it was the left.
    I've always steered mostly with my left hand, mainly because I'm left-handed, although I'm nearly ambidextrous. When driving in the UK, it's harder for me to adjust to shifting left-handed and steering right-handed than to adjust to driving on the left. (Harder because of the steering than the shifting).
  20. Sep 11, 2023 at 6:39 PM
    #140
    shooter1231
    Yep - my daily drivers from 1989-2010 were 5 speed manuals. I usually drive with my left hand on the wheel too. I remember the pull knob headlight switch and the high beam button on the floor to the left of the brake pedal - because I am that old!
  21. Sep 11, 2023 at 6:41 PM
    #141
    Oakboro, N.C
    The only thing I am ambidextrous with is archery (I have no idea how this sort of thing even works). Attempted to drive a right hand manual during my tech years and it was like I had 3 left feet. Cannot hardly open a jar off hand. I recall my Oldsmobile Cutlass light switch, at times, would pull all of the way out, Knob, stem and all) and you would have to slowly slider it back in to get the lights on.
  22. Sep 11, 2023 at 6:45 PM
    #142
    Pearla
    Pearla New Member
    2023 Blizzard Pearl
    Guess I am use to my 2018 Tundra. Can have led headlight surround with fog lights on when parking lights are on. 2023 4runner only the parking lights go on without the fog lights. Helps when pulling up to sentry gates.
  23. Sep 11, 2023 at 6:50 PM
    #143
    FN2187
    FN2187 Stormtrooper
    Earth
    Right hand manual as in right hand drive? I've never done that but think I'd feel like a fish out of water.
    I remember wondering if the pedals were reversed too until I saw on an episode of OG Top Gear (UK) that it looked like they were normal.
  24. Sep 11, 2023 at 6:58 PM
    #144
    Oakboro, N.C
    Yeppers, This was on a right hand drive manual Nissan... will leave the model up to speculation to retain my man card, Was like... the oddest experience of my short life up to that point. It was do able but very clunky based off of years of left hand drive. I guess over time one could grow more accustomed to it, Automagic would have been a non issue.
  25. Sep 11, 2023 at 7:00 PM
    #145
    shooter1231
    First car I drove - '68 Camaro, 327 w/ 2speed Powerglide, then a '70 Chevelle (not an SS:(), 350 w/ 3speed auto, then a '76 Olds Cutlass - all had high beam switch on the floor and pull knob headlight switch on the dash to the left of the steering wheel. Did some stupid shit in those cars.
    gomiami likes this.
  26. Sep 11, 2023 at 7:02 PM
    #146
    FN2187
    FN2187 Stormtrooper
    Earth
    I know I'm driving this (and other threads) off-topic but heard the interesting reason why the British drive on the left. Has to do with the old days of dueling - most people are right handed and passed each other on the left so they could sabre rattle
  27. Sep 11, 2023 at 7:02 PM
    #147
    Oakboro, N.C
    Easy to ghost ride through intersections in rural areas! Pro tip, am not suggesting this is an actual thing.
  28. Sep 11, 2023 at 7:05 PM
    #148
    FN2187
    FN2187 Stormtrooper
    Earth
    No cop no stop. I was (poorly) taught by a cousin how to turn off the headlights and blow through a 4-way at night when you could see for a mile in all directions. Just gotta hope nobody else had the same idea
  29. Sep 13, 2023 at 9:57 AM
    #149
    Lou
    Lou New Member
    I'm not sure if it works this way with the standard screen, since mine is pretty much always on Android Auto; but I turn night mode on and off with the dial that controls the dash lights.
  30. Sep 15, 2023 at 3:12 PM
    #150
    pastoreater
    I drive with my parking lights on and a dark dash. I can still see the big red needles with my sunglasses on during the glare of afternoon pickup. I've been turning the stalk to DRL if I need to see reverse camera.
    edit sometimes I do turn on my headlights too
