No Auto Lights?
Discussion in '5th Gen 4Runners (2010-2024)' started by coachhomer, Sep 2, 2023.
  1. Sep 5, 2023 at 1:28 PM
    #91
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Ahh I see. Even less sure now why Lou says he's confused by the conversation, it's pretty black and white. As for never turning your stalk to off - probably not a solution that everyone likes. Hard to believe, I know
  2. Sep 5, 2023 at 1:29 PM
    #92
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    OP's skin may be too thin for this game
  3. Sep 5, 2023 at 1:39 PM
    #93
    Maybe, but gotta hand it to OP he backs up himself which I appreciate
    HuskyMike likes this.
  4. Sep 5, 2023 at 1:55 PM
    #94
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    I probably should have used different words, because he does say that he turns his lights off:taco:
    after this thread I am happy that the 4runner has headlights that can be set to on
    op if you want to still hang out maybe you can post pics
  5. Sep 5, 2023 at 1:58 PM
    #95
    Right, only physically turns off out of courtesy once in a while..
  6. Sep 5, 2023 at 2:01 PM
    #96
    shooter1231
    shooter1231 New Member
    2023 Mag Gray 4Runner Limited
    Meh. It's not like debating whether auto headlights are a safety feature, or more of a convenience feature, is not worthy of debate. OP pointed out that once you get to where a certain percentage of all cars have it - it may be a safety issue that needs to be standardized. At what percentage? I don't know - but it is worth debating. But then a couple of members jump in and tell him he should learn how to operate the vehicle he drives, we don't need no stinking auto headlights, blah, blah, blah... Why? If you had auto headlights and didn't like the feature - you could operate them manually. Why the big deal? Are the people who jumped OP's ass saying that auto headlights vs. manual headlights has no safety content at all? There is definitely safety content in that debate. So why the rush to shut down debate with all this "if you can't figure out how to turn on the headlights you don't need to be driving" bullshit. And what about the bigger bullshit of one member telling another member he shouldn't disagree with someone who has been a member for 3 years when he has only been a member for a month? Fuck that. I don't think we need people being someone else's bitch boy when there is some type of disagreement. Especially when the debate/disagreement has some merit and further discussion could lead to more learning/thinking if it wasn't shut down with "if you can't turn on your headlights you don't need to be driving". You know, ~100 years ago you could have probably easily made the statement that if you couldn't handle major repairs yourself - you probably shouldn't be driving a car. We've come a long way. Or have we?
    Trail Runnah likes this.
  7. Sep 5, 2023 at 2:09 PM
    #97
    pastoreater
    On is less complicated than auto
    it took me half an hour but i finally got my post right
    djwantke likes this.
  8. Sep 5, 2023 at 2:14 PM
    #98
    Hey bitch boy, @shooter1231, it's me the bigger bullshit member here at your service. Relax, dude, and take your own advice on the offensiveness of your comments.
    I haven't called OP names. I contribute a lot of positive things to the community. I actually post a lot of my handiwork, as novice as I am, and don't just type.
    I simply said, and rightfully said, I disagree with the statement that it's "crazy" to manufacture vehicles since '99 without this feature.
    I simply said, and rightfully said, I disagree with the statement "So we should just remember to turn them on with the cars that don't have it?", and "You expect them to randomly remember to turn their headlights on when they have been driving a car that has auto lights for 10 years", implying that it's it's not safe to rely on folks ability to remember to do these things.
    I also disagreed with OP lumping people into a derogatory category he created.
    Thanks for your speech, sir.
  9. Sep 5, 2023 at 2:23 PM
    #99
    You're right the issue is worth debating, that's why we're debating it. I dunno if I saw anyone say it's legit has no safety content at all, certainly disagree with that.
    100 years ago if you called someone bitch boy, or said they're full of bullshit, in so many words - you'd likely have to put ur hands up and back up your mouth. It was a better time.
  10. Sep 5, 2023 at 2:48 PM
    #100
    shooter1231
    OP lumping people into a category he created? Dude just comes back with "How about you take some personal responsibility and know how to safely operate the vehicle you're driving rather than impose more useless mandates" in response to the supposition that a high enough percentage of vehicles on the road today have auto headlight that it should be a standard safety feature. OP responds with "Your comment falls in the “you can’t rationalize with crazy” bucket. It’s not about what I need to take responsibility for. It’s what I don’t trust our error prone species with more distractions than ever to be responsible for. Give some thought before you post if you really want to continue a constructive discussion." And you conclude the OP is "lumping people into a category he created? You know, I didn't even know who was the one who came back with the bullshit statement about a brand new member questioning a guy who has been here a whole three years. Didn't even bother to look back and see. Wonder why pointing it out hit you so hard? Maybe "bitch boy" was a bit harsh. I didn't intend to attack a specific member with that comment. Although I stand by everything I said - if the bitch boy comment was truly offensive to you I regret that. But come on "you'd likely have to put ur hands up and back up your mouth"? It doesn't take a genius to read through even a couple of these discussions to figure out who the lurker trolls are. The passive aggressive lurkers and trolls are bad enough - but the members who go along with them or encourage them are worse. OP got personally attacked - for no good reason other than having a differing opinion. These pricks that launch personal attacks at someone with a different opinion - and then come back with "its just my opinion" when someone calls them out for it - are just that - weak, passive aggressive pricks. They fuck it up for everyone.
  11. Sep 5, 2023 at 2:59 PM
    #101
    @shooter1231 like I said my man, relax, and easy with the heated language good way to get yourself in trouble with admin.
    I'm just bustin' ur balls, and standing by my statement, which I love to see you are too.
    I'm not offended by literally anyone's words, in my opinion speech is NOT violence like the kids say these days.
    Most of your comments aren't directed at me so I think we can leave it to those guys to answer
  12. Sep 5, 2023 at 3:13 PM
    #102
    pastoreater
    How do you feel about comment #4?
  13. Sep 5, 2023 at 3:29 PM
    #103
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    What’s wrong with that post?
    It is pretty crazy for a 2023 vehicle not to have auto headlight.
    And anyone driving without light at night is definitely a safety concern. Also the majority of car driving with no lights on (no DRL nor low beam) when it rains are most often than not cars that look old with no DRL (and most likely that don’t have the auto headlight feature). I’ve seen a couple of 5th gen 4Runners amongst these as well. So sure, maybe everyone on this forum turn their lights on at night and when it rains, but that doesn’t mean everyone out there on the road (4R or not) does it.
    i really don’t understand what’s wrong with wanting to have auto headlights. You won’t ever have to use that feature if you don’t want to even if you have a pro or limited. So what bothers you so much about it? I’m legitimately curious
  14. Sep 5, 2023 at 3:48 PM
    #104
    @semprenissart I know ur question may not be for me, but all I was sayin' is I wouldn't describe vehicles not having the feature as crazy or unbelievable (unfortunate, yeah sure. I guess for manufacturers ultimately it is extra parts extra tech, prolly will be standard in near future tho).
    Also, my biggest qualm was just with OP seeming to be dumbfounded by how people are supposed to be capable of remembering to flick lights on after driving a vehicle without auto lights. I thought "You are going to risk your life driving in the dark on my ability to remember that" was a bit much.
    And using the words "You expect them to randomly remember to turn their headlights" when driving a rental, work car, someone else's car.
    *If it's not auto headlights that cause wrecks, it'll be something else, always gunna be this way.
    Lastly I really dislike using language of "attacking" people. That's just me I guess. If I was attacking you, believe me you'd know it :)
    5thToy likes this.
  15. Sep 5, 2023 at 4:01 PM
    #105
    pastoreater
    Seriously. On is more visible than auto. It is not crazy. It is not crazy for Toyota to trim a vehicle like this and people are not crazy to choose it.
  16. Sep 5, 2023 at 4:19 PM
    #106
    semprenissart
    semprenissart Mèfi
    I have no idea what you’re trying to say here?
    It’s absolutely your right to have it and not choose it (as long as you make sure you turn your lights on when appropriate). It is crazy, in my opinion, for a $40-50k. Or to have this option in 2023
  17. Sep 5, 2023 at 4:25 PM
    #107
    joshdub
    joshdub New Member
    2020 TRD ORP
    It's crazy for what's effectively a 15+ year old platform (more if you actually look at the chassis) to still be selling for 50k. But here we are.
  18. Sep 5, 2023 at 4:26 PM
    #108
    semprenissart
    semprenissart Mèfi
    yes I understood from one of your previous post that you were not against auto headlights being available, you just didn’t care for it, which I can respect as long as you’re using your headlights as you should. Let’s be honest though, in the US (I don’t know about Canada), there’s a shitload of people that don’t use headlights (or at the very least DRL) when it’s raining or dark. Let’s not forget that lights are not only about seeing what’s in front of us but also being seen by others in poor conditions
  19. Sep 5, 2023 at 4:30 PM
    #109
    pastoreater
    A vehicle with its lights set to on will be at least as visible as one with its lights set to auto. So if you want best visibility, auto is not it.
  20. Sep 5, 2023 at 4:34 PM
    #110
    semprenissart
    semprenissart Mèfi
    I can absolutely understand this argument. So at least give the man auto headlights :D
    Joking aside, not many people will buy the 4R for $50k if it was bone stock the way it came out 15 years ago. At least they can justify the price increase with new techs like CarPlay, radar cruise, etc… (despite some not wanting all these but even a 5-8 year old 4R is arguably better than a 15 year old model for the same price). And the biggest chunk of the $50k is justified by the bulletproof engine
  21. Sep 5, 2023 at 4:36 PM
    #111
    semprenissart
    semprenissart Mèfi
    Aren’t running lights and DRL synonymous?
    What’s auto DRL? isn’t that just DRL aka running lights. I’m really confused now lol
  22. Sep 5, 2023 at 4:37 PM
    #112
    The fact that some can't even tell that their lights are not on is a bigger problem. Shouldn't have a license.
  23. Sep 5, 2023 at 4:54 PM
    #113
    pastoreater
    I don't know what Toyota calls it and I don't know how the lights on your rig are set up. I expect that the 4runner has nothing illuminated on the rear end during clear conditions in auto. Is that true?
    I edited/changed my post above btw.
  24. Sep 5, 2023 at 5:24 PM
    #114
    semprenissart
    semprenissart Mèfi
    From what I understand these are my options:
    Auto= DRL on (or off if chosen to do so in the menu settings), taillights are off as far as I know. Then headlights/taillights will turn on automatically when sensor senses darkness (sensitivity can be programmed in settings so lights turn on if either overcast, raining, dawn/dusk, dark)
    DRL OFF= everything stays off until manually changing it
    Parking lights= DRL, tail lights, marker lights (the orange ones)
    Headlights= low beam and taillights (maybe marker lights too? I’m not sure, I never paid attention)
    pastoreater[QUOTED] likes this.
  25. Sep 5, 2023 at 5:32 PM
    #115
    It's not that I don't care for the auto headlights even, it's that I don't care for OP's over the top theatrics about how dangerous it is while dragging by beloved 4Runners through the mud on the topic.
    Then, he said to me "he can’t rationalize with insanity" and that me, and my friends here, are irrational. Didn't care for that.
    And I mean all this for a thread that was answered by Google in one second and answered from the first comment. That's all
    5thToy likes this.
  26. Sep 5, 2023 at 5:34 PM
    #116
    Haha, watch out buddy, OP is gunna declare "Your comment falls in the “you can’t rationalize with crazy” bucket.
  27. Sep 5, 2023 at 5:42 PM
    #117
    I mean @Lou is actually a genius, not only for claiming the best most simple member name, but for bringing up a good point that if I keep my headlight stalk clicked to ON all the time, and the 4R auto turns off - I essentially have had myself some of them fancy auto headlights all along. Even on my knuckle dragging kickass '16 Trail
  28. Sep 5, 2023 at 5:47 PM
    #118
    Any second now, I'm gunna have my ass handed to me by @shooter1231 :p
  29. Sep 5, 2023 at 5:48 PM
    #119
    backpacker
    backpacker New Member
    2023 TRD ORP
    As a guy who nursed only 4 vehicles (two of them used) through 42 years, I have a practical reason for liking auto that hasn't been mentioned. Every one of my vehicles has eventually suffered multiple switch failures, some of which were major pains to fix. For example, two many key-turn cycles eventually doomed the ignition switches on my '76 Nova and '86 Accord. The former developed a bad neutral safety switch and turn signal switch, and the latter had issues with radio control buttons, climate control switches, and, of course the headlight switch. My '97 Subaru and '10 Subaru both had radio control issues, the latter with the lever buttons on the steering wheel.
    The fewer times I have to operate any switch, the better. The next best thing to Auto for me is always-on.
  30. Sep 5, 2023 at 6:12 PM
    #120
    Daddykool
    I’ve never wanted or liked automatic headlights. They’re annoying if you have no way to defeat them. I know how and when to turn them on.
