No Auto Lights?
Discussion in '5th Gen 4Runners (2010-2024)' started by coachhomer, Sep 2, 2023.
  1. Sep 4, 2023 at 10:42 AM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    On mine, you can select how sensitive you want before the headlights turn on. On the most sensitive setting , they’ll turn on automatically if it’s overcast. So most definitely if it rains enough to be a safety concern, you can have the light automatically turn on
  2. Sep 4, 2023 at 10:45 AM
    Sorry, I’m in the camp of if you don’t want to turn on your headlights yourself when it gets dark, you have no business driving at night.
    307WY, Borracho Loco, 2Toys and 4 others like this.
  3. Sep 4, 2023 at 10:50 AM
    semprenissart
    semprenissart Mèfi
    That’s got nothing to do with auto headlights. If anything, taillights also come up with headlights so all these people you’re talking about that drive with no taillights are the one that don’t have auto headlights (or have it but chose not to use the auto on/off feature)
    Trail Runnah likes this.
  4. Sep 4, 2023 at 10:55 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    You obviously have never had to do a high speed run with a car loaded with moonshine, hoping to avoid the revenuers.
    I mean, I haven’t either, but…
  5. Sep 4, 2023 at 10:59 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    All vehicles should have the selectable auto/DRL headlight feature on the headlight stalk.
    Putting only on Limited trim > makes no tech sense
  6. Sep 4, 2023 at 11:06 AM
    semprenissart
    semprenissart Mèfi
    It doesn’t mean it’s wrong. I’ve seen way too many people driving with no headlights on when it’s fairly dark (most of them in older cars). I wish we could rely on people not being dumb, unfortunately we can’t and I’d rather all these people that forget to have the option for the car to do it for them. just like blind spot monitors. I’ve read so many people complaining about it and how unnecessary they are. I can tell you, riding a motorcycle, I never feel safer than when I see the little lights on the mirror. Of course we can’t fix stupid, and I’m not gonna lie and say that no one with BSM ever merged in my lane but I can count it on one hand. However there are 100 times more people without BSM that merge into my lane when I’m on the bike. Sure they most likely didn’t see me and didn’t check their blind spots, but that’s why I feel safer being next to a car that has BSM. Anyway I digress…
  7. Sep 4, 2023 at 11:14 AM
    My 2006 GTO has auto lights but I’m not sure if they come on with wiper use. I have it set to early on and late off but if they’re not on I just flick them on.
    semprenissart[QUOTED] likes this.
  8. Sep 4, 2023 at 11:16 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Once in a while I'm that guy who forgets to put his lights on right away in the dark. I mean that's on me. The daylights are always on. What I could definitely concede to enjoying is an auto taillights feature, cuz that's where it's most dangerous when one forgets headlights.
  9. Sep 4, 2023 at 11:18 AM
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    In my opinion if there's a selector that doesn't reset, then you have the scenario where one driver sets the lights to something different than the other drivers are used to. So it should be auto setting on vehicle startup with a button that behaves like the stability control button so you can manually turn lights on/off/ running light. And I would want this auto system to magically select running lights and headlights.
  10. Sep 4, 2023 at 12:04 PM
    Oakboro, N.C
    Aint from North Carolina, Are ya?
  11. Sep 4, 2023 at 12:05 PM
    bassist
    bassist New Member
    Only one generation removed from it!
  12. Sep 4, 2023 at 12:09 PM
    semprenissart
    semprenissart Mèfi
    Yes I had an older car with auto headlights and they would only come on when it was dark (right after the sun sets), not when it was overcast or slightly dark
  13. Sep 4, 2023 at 12:10 PM
    Oakboro, N.C
    Nice.....:toast:
    bassist likes this.
  14. Sep 4, 2023 at 12:26 PM
    pastoreater
    He's probably suggesting people drive with their lights auto on, in poor visibility conditions, and if it's bright enough their lights stay off when he wishes the driver turned on running lights.
    Ripper238[QUOTED] likes this.
  15. Sep 4, 2023 at 12:57 PM
    semprenissart
    semprenissart Mèfi
    I’m not sure I understand you? If it’s bright enough and setting is on auto headlights then headlights should turn off and DRL turn on (which is what it’s meant to do)
  16. Sep 4, 2023 at 2:04 PM
    I see that often as well. Those are daytime running lights. Auto headlights turn on tails as well.
    People forgetting to turn on headlights because of DRLs is a great argument in favor of auto lights.
  17. Sep 4, 2023 at 2:09 PM
    pastoreater
    Yes and you'll be driving in light rain for example with no tail lights illuminated
    Is this all canada's fault for mandating drls only in front?!?!?
    Ripper238 likes this.
  18. Sep 4, 2023 at 2:44 PM
    LaHh
    LaHh New Member
    First world problems..
    djwantke likes this.
  19. Sep 4, 2023 at 3:07 PM
    #49
    backpacker
    backpacker New Member
    2023 TRD ORP
    Thanks! It works well at 30 sec.
    HuskyMike[QUOTED] likes this.
  20. Sep 4, 2023 at 3:50 PM
    #50
    joshdub
    joshdub New Member
    2020 TRD ORP
    How about you take some personal responsibility and know how to safely operate the vehicle you're driving rather than impose more useless mandates
    gomiami and 2Toys like this.
  21. Sep 4, 2023 at 5:39 PM
    #51
    coachhomer
    coachhomer [OP] New Member
    Your comment falls in the “you can’t rationalize with crazy” bucket. It’s not about what I need to take responsibility for. It’s what I don’t trust our error prone species with more distractions than ever to be responsible for. Give some thought before you post if you really want to continue a constructive discussion.
  22. Sep 4, 2023 at 7:09 PM
    #52
    Guys,guys lol
    @coachhomer you just showed up here and now ur calling Josh crazy, doesn't sound that crazy to me my man.
    I've never even owned a vehicle with auto headlights or blindspot mirrors or anything, and I'm almost 35. How old are you dude
  23. Sep 4, 2023 at 7:25 PM
    #53
    15 minutes after and I find myself still shaking my head thinking about your attitude. You bought the truck dude. You could have googled the answer. You got the answer in the first comment. You made yourself that bed, now you gotta sleep in it.
  24. Sep 4, 2023 at 8:32 PM
    #54
    joshdub
    joshdub New Member
    2020 TRD ORP
    Maybe instead of mandating auto headlights to protect those that can't remember to turn on their light when it's dark we make obtaining a driver license significantly harder to weed out those idiots
    2Toys likes this.
  25. Sep 4, 2023 at 9:23 PM
    #55
    FourBelugas
    FourBelugas New Member
    23 white ORP
    My 24 year old Camry has auto headlights. My 20 year old Corolla CE with manual windows and locks has auto headlights. But my 23 TRD ORP with power everything, moonroof, along with heated seats and steering wheel and pushbutton start, doesn't. Makes zero sense.
    Or maybe Toyota is saying the Limited and TRP Pro drivers cannot be trusted to operate headlights on their own hence why it's included on those two trims...
    LuLu likes this.
  26. Sep 4, 2023 at 9:27 PM
    #56
    Hmm that's interesting, yeah I wonder why
  27. Sep 4, 2023 at 9:41 PM
    #57
    Both my 2013 Corolla and 2015 Rav4 didn't have auto headlights.
  28. Sep 4, 2023 at 9:45 PM
    #58
    backpacker
    2023 TRD ORP
    My 2010 Subaru and my 1997 Subaru both had auto headlights.
  29. Sep 4, 2023 at 10:41 PM
    #59
    coachhomer
    To answer your question first, I am 50. The only car I have owned that did not have auto headlights prior to this 4Runner was a 1984 Honda Accord. The reason I said Josh’s COMMENT falls in the crazy bucket is because he said…
    I know how to safely operate my vehicle. That was never the issue. But people don’t read or pay attention anymore which is a huge reason why our country is where it is right now. Nevertheless, to call requiring the OPTION (because that is all it ever has been, meaning at some point the responsible individual behind the wheel has to make the conscious responsible decision to engage the auto lights) a “useless mandate” is crazy. If you read a majority of the posts in this thread, most think the OPTION to turn them on would be a move toward a safer driving experience for the population. That was my point.
    I would have bought the truck regardless of the option because again, as narrow minded as you might choose to be in this discussion, my comments were not about me. My choice to not buy the truck would have 0 impact on whether or not someone else operates the vehicle incorrectly. I posed the question to make sure I wasn’t missing something because somewhere just after 35 years of age I realized I don’t know everything.
  30. Sep 4, 2023 at 11:03 PM
    #60
    coachhomer
    Making obtaining a driver license more difficult is the most brilliant comment made in this thread. Unfortunately, that is not economically beneficial to any number of big business entities such as insurance companies, municipalities, oil producers, etc. And less drivers on the road would lessen the economic viability of small businesses so we have to work with what we are dealt. But I like the way you’re thinking.
