New 4Runner TRD PRO (2,200 Miles) Pulls to Right Will Not Hold Alignment?
Discussion in '5th Gen 4Runners (2010-2024)' started by Cuba, Jul 26, 2024.
  1. Aug 1, 2024 at 6:58 PM
    JohnD
    JohnD New Member
    Wrestling with a pig
  2. Aug 2, 2024 at 11:41 AM
    So many of us have dealt with this and other issues around this topic. Endless threads around this. Recommendations
    1. Go to discount tire and do a proper balancing on the tires / roadforce
    2. Identify at what speeds the pull happens
    3. Repeat and iterate as needed.
    4. I suspect the next issue you will face is the famous shimmy/vibration some of us have experienced, but that's another can of...w.
    Hang in there...in retrospect this is minor stuff, the 4R is a good vehicle.
    Cuba[OP] and raimieb like this.
  3. Aug 2, 2024 at 1:22 PM
    Cuba
    Cuba [OP] New Member
    Cuba
    2024 4Runner TRD PRO (Midnight)
    None
    I took your advise and tried to book an appointment at Discount Tires. They are glad to do a tire balance but said he couldn’t do an alignment because Discount tires does not have the specs for 2024 models…
    ChessGuy[QUOTED] likes this.
  4. Aug 2, 2024 at 1:31 PM
    You are on the road to recovery! You will notice a difference after they do a proper balancing. Ask them what numbers they get after the balancing so that you know the settings (high 20's) don't ask me the units as I don't know the machine well, but I have that on mine profile. Many of us have struggled with this stuff. I am sure your alignment is probably fine if it was done properly. Go open a cold one bud!
    kolter45 and Cuba[QUOTED][OP] like this.
  5. Aug 2, 2024 at 1:35 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    When you get a balance done, ask them to give you the road force numbers for each tire. Should ideally be lower teens but no more than 20 for each wheel.
  6. Aug 2, 2024 at 1:36 PM
    Cuba
    Cuba
    None
    All good stuff guys! Thank you! Will keep you posted.
