Needle bearing...
Discussion in '5th Gen 4Runners (2010-2024)' started by Elvis4R, Nov 28, 2021.
  1. Sep 4, 2024 at 1:55 PM
    #121
    like2lean
    like2lean New Member
    Got mine put in today. It didn't affect the noise I had just spinning the wheel off the ground, I believe that's normal gear roll, but it's smooth and quiet at 40mph now!
    I saw some people saying their bearing was broken when removed, I think that's happening when the tool gets tapped in place. I noticed a small void in my race and fished the broken part out with a magnet, might be something to consider when a larger piece comes off.
    The only problem I had was getting the cv shaft out. I've removed many in my life but this one hung on for dear life. I noticed the clip on these isn't round like most I've seen, there are 2 lobes on it. when I finally got the shaft (clip) rotated where it wanted to be and kept the shaft level it popped right out.
  2. Sep 4, 2024 at 9:46 PM
    #122
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Ive only had one or two that were so bad that the needle capturing "basket" failed and spit them into the diff. Ive had a few of the needles fall out after pulling the CV also. That is more common. Also that clip can be a BITCH! Good on you not giving up!
    like2lean[QUOTED] and Toy4X4 like this.
  3. Sep 4, 2024 at 10:16 PM
    #123
    backpacker
    backpacker New Member
    2023 TRD ORP
    Are those things less likely to happen if you replace it before there are symptoms?
    MyWyfsRnnr[QUOTED] likes this.
  4. Sep 4, 2024 at 10:55 PM
    #124
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Yeah. The cage that holds the needles will get worse the longer it is getting the vibration. Luckily the axle holds the needles in pretty well so it is not typical for a quick catastrophic failure but the longer it goes the more likely an issue with the needles getting into the diff. Like I said though, I've only had one or two that got that far so it is not very common
    backpacker[QUOTED] likes this.
  5. Sep 5, 2024 at 6:55 AM
    #125
    Curious - does the needle bearing sleeve have different edges front & back like the ECGS bushing, as in, only goes in one way?
  6. Sep 5, 2024 at 7:15 AM
    #126
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Yes. Every bearing I've ever installed has markings (manuf, model, size etc) on one face. This is the face where you apply pressure to install. So in most cases, facing out.
    Jason
  7. Sep 5, 2024 at 10:12 AM
    #127
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    No. It is caged in. Both sides look the same. The outer metal is rounded over (see below). The vibration wears and crushes the retention metal between the needles and allows them to start moving more and not which speeds up the wear. When they open up enough, they are no longer retained. The axle typically holds them in and they fall out occasionally when the axle is removed. I've only seen one or two where the needle has gotten past the outer lip of the bearing and into the diff.
  8. Sep 5, 2024 at 10:23 AM
    #128
    Caged in I don't think so if I'm understanding you correctly.
    That thin piece of metal between each needle is what holds it in. If one side fails the needle can come out. Of course after that it would need to get past the CV but sounds like when it gets real bad the tolerance is so far off the needle can slip by.
    MyWyfsRnnr likes this.
  9. Sep 5, 2024 at 10:33 AM
    #129
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Exactly. When those little retention metal pieces get worn it starts spitting the needles, the axle keeps them trapped for a while but eventually, enough space can be made for them to start getting out. It will take a WHILE (in my opinion). Like I said. I've only seen it one or twice get that bad.
  10. Sep 5, 2024 at 4:35 PM
    #130
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    I paid a shop to do the needle bearing replacement on my 03 Tacoma, over ten years ago, back when ecgs bushing was barely a thing.
    paid the shop $700 to replace the needle bearing with a new needle bearing.. no difference obviously.. I was just desperate and trying things..
    fk you Toyota.
    Toy4X4 and MyWyfsRnnr like this.
  11. Sep 24, 2024 at 7:12 PM
    #131
    Bob and MyWyfsRnnr like this.
  12. Sep 24, 2024 at 8:34 PM
    #132
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    glwood54[QUOTED] likes this.
  13. Sep 24, 2024 at 9:43 PM
    #133
    Already ahead of the game, I see...doesn't bode well for the 6th gen 4Runner, it seems.
  14. Sep 24, 2024 at 10:05 PM
    #134
    Yobruhitsme
    Denver
    Ineos Grenadier
    God damn fking Toyota…
  15. Sep 24, 2024 at 11:38 PM
    #135
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Physically pained me to see what you spent on your needle bearing swap... I do the ECGS upgrade for less than half what you had to spend... Maybe someday I should antique roadshow ECGS bushing installs around the western US! Get some vacation time and help some people out! Haha. I see you're in Colorado so I couldn't help you out but grab a friend and do the ECGS bushing yourself!
  16. Sep 27, 2024 at 10:35 AM
    #136
    Wow, really?!? Just curious, did the customer complain about noise on the 4th gen Tacoma, or was it a pre-emptive job?
  17. Sep 27, 2024 at 11:20 AM
    #137
  18. Sep 27, 2024 at 11:58 AM
    #138
    I had one question on that clocking of the bushing, which I think @MyWyfsRnnr already answered, but I cannot find it...what exactly is meant by the 7 / 30 position?
    Edit: never mind. I found it in the comments on the YT video. He meant the 4-5 o'clock position.
    One other question when reinstalling the CV joint - does it matter if the opening in the C-clip is on the right or left side?
  19. Sep 27, 2024 at 3:53 PM
    #139
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    The opening position does not matter at all when reinstalling, I just like it straight down because that seems to balance the clip out a little bit so that it compresses a little easier. It really doesn't matter though
  20. Sep 27, 2024 at 3:54 PM
    #140
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Same vibration issue. Dealer installed 2" spacer lift, less than 2000 miles, stock tires
  21. Sep 27, 2024 at 3:56 PM
    #141
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    Yeah... I'm an idiot and said 7:30... Should be like 4-5.... Digital age! Haha. Filming that was so much pressure! Also that stupid bump stop wouldn't come out of that truck! Haha
    McSpazatron likes this.
  22. Sep 27, 2024 at 3:58 PM
    #142
    Yobruhitsme
    Denver
    Ineos Grenadier
    lol what a pos.. I am looking fwd to be out of this Toyota game.. hoping the ineos’ test drive goes well tomorrow. I am bringing the 4R’s title in anticipation.
  23. Sep 27, 2024 at 4:27 PM
    #143
    MyWyfsRnnr
    Chris
    Citrus Heights
    2018 4Runner TRD
    I still really like Toyota for sure! It just seems like they're cashing in their reliability reputation to make money now. There's just a few things like the needle bearing and then rushing these latest engines etc that make you wonder long-term. It's sad when a Chevy 5.3 LS motor is doing as well as Toyota. I have 18 cars right now so I'm not a brand ambassador for any but I do love our 4Runner. I'm just a little disappointed with how Toyota is managing their business and their shortcomings
    McSpazatron and Toy4X4 like this.
  24. Sep 27, 2024 at 4:49 PM
    #144
    Yobruhitsme
    Denver
    Ineos Grenadier
    lol 18 cars. Which is your fav?
  25. Sep 28, 2024 at 3:59 PM
    #145
    Yobruhitsme
    Denver
    Ineos Grenadier
    4R has been traded in! Someone else’s rumble to worry about
  26. Sep 28, 2024 at 5:25 PM
    #146
    Don’t bury this in the needle bearing thread!!!! You owe it to everyone to give us your impressions! At least to the folks that want to dream of the Grenadier.
    Which model did you get? Triple locked? What are your plans with it?
  27. Sep 28, 2024 at 5:30 PM
    #147
    Yobruhitsme
    Denver
    Ineos Grenadier
    Triple locked!
  28. Sep 28, 2024 at 5:39 PM
    #148
    Ok seriously, PICS!!!! New thread!!! Give us a comparison to the 4runner in terms of utility, function, etc! PICS ! PICS! PICS!
    Especially back seat and cargo area. I’m curious how hard it would be to convert to an elevated flat floor over the battery. Not that I could afford one, but a guy can dream!
    Yobruhitsme[QUOTED] likes this.
  29. Sep 29, 2024 at 9:47 AM
    #149
    Yobruhitsme
    Denver
    Ineos Grenadier
    Will do a write up once a get a feel for the new rig.. some pictures from a joyride this AM.
    I had the subwoofer dialed too strong. One of the song I played started to rumble the driver seat, immediately triggered yota needle bearing PTSD.. :eek: I had to turn down the music to make sure it was just bass.
  30. Sep 29, 2024 at 10:17 AM
    #150
    golfpilot
    golfpilot New Member
    David
    Switzerland
    2019 TRD Off Road Premium
    I really like the grenadier technically, but they all look too good/boring.
    Show me one with lift and big wheels, somthing that looks a bit more aggressive.
    You find many badass looking Landrover Defenders or G Wagons, so why not the grenadier? Or are they still too young / new.
