My 4runner is so bad on MPG
Discussion in '5th Gen 4Runners (2010-2024)' started by nafees.im, Mar 7, 2020.
  1. Nov 11, 2022 at 1:13 PM
    #211
    I wanna say a fuel system cleaner is recommended at 5000mi intervals…so that might not be a bad idea. Doubt it would change anything though. You could disconnecting the battery for half hour…maybe it the ECU learned something wrong?
    During your trip, it would be good to take a few samples of mileage (as calculated by computer), at one hour intervals, steady state. At least it might help to pick up on any trends.
    Singleminded likes this.
  2. Nov 11, 2022 at 4:32 PM
    #212
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    @snyds has a relatively small sample size. And too many variables. So none of us know what's what. Thus all these good recommendations to take it on some long highway trips and record mileage for stretches of an hour or so, for a couple hundred miles, and for several hundred miles. OP said he is taking a 1500 mile trip soon that is a mix of both highway and city. If the highway portions are long enough, he'll get the sample size and conditions, including a variety of gas, needed to determine if there's a real problem with his truck.
    Any stock 4Runner with anywhere around the recommended air pressure, and even barely reasonable maintenance, should get high teens to low 20s on the highway at speeds in the 60s. That's the bottom line. If it's mid or low teens over hundreds of routine highway miles, something is actually wrong.
    The EPA highway number is a good approximation of real life. It might even be a hair pessimistic. But the EPA city number is optimistic. I don't see how anyone can average 16 mpg in typical city or suburban driving, with stop signs and traffic lights and a lot of 25 mph roads. I'm often getting 12-15. Only occasionally 16 or above. And that's stock with no weird driving habits or conditions.
  3. Nov 11, 2022 at 6:39 PM
    #213
    Yeah, I agree that 16 would be a very optimistic number for purely city. I would say 16mpg better describes “mixed” driving. It’s about what I get on my morning commute, which is mostly 55mph country roads with about 40 percent suburban main roads.
    If I’m driving with lots of stops, in more congested areas, it’s very easy for a trip to yield mPG numbers in the low teens.
  4. Nov 11, 2022 at 6:58 PM
    #214
    Singleminded
    OEM LED foglights
    Per the computer I’ve averaged 17.1 over my first 20k miles. I believe the EPA combined number is also 17. So again the EPA number looks accurate. But a lot of my miles have been highway, where I’ve typically gotten ~20 over extended periods. I’m sure my average would be in the 15 range if not for those highway trips.
    Not that I much mind. I’d be happy with just a bigger tank. The range would be nice with another 4 gallons or so.
  5. Nov 12, 2022 at 7:52 PM
    #215
    MountainMan
    MountainMan New Member
    Pacific Northwest
    Midwest and flatlander mileage is much different than mileage those of us who live in hilly and mountainous areas experience.
    I commute 15 miles each way to work in hilly farmland going about 62 mph in a 55 zone.
    In drive, the transmission has to downshift around half a dozen times on hills to maintain speed.
    I average 16.4 mpg commuting and around town. That's with a lift and 33's.
    I just drove 320 miles across the state of Washington at 65 to 73 mph and averaged 17.5 mpg. I'm very happy with that number.
    SlvrSlug likes this.
  6. Nov 12, 2022 at 8:26 PM
    #216
    Another effective way to increase your MPG is to trade in the 4Runner for a Prius.
  7. Nov 12, 2022 at 9:57 PM
    #217
    blue4runner
    blue4runner New Member
    Geoff
    2018 blacked out Limited
    matching front window tint, chrome delete, TRD off road wheels with 275/R17 K02's
    Don't feel bad I get 12.4 MPG city, 16.8 MPG highway with all the weight I added.
  8. Nov 12, 2022 at 10:02 PM
    #218
    12.4 is really bad. Are you still on stock tires? Do you have a roof rack?
    I have a few hundred lbs of constant weight, and 33.5" MT's and get better than that, usually.
  9. Nov 12, 2022 at 10:36 PM
    #219
    blue4runner
    Geoff
    I have 275s . Roof rack delete. Sliders. And around 400lbs of sound great including the deadening.
    I have a pedal commander set to city 1.
    I only drive 7 miles to work.
    Like i mentioned on the freeway i get almost 17mpg.
    Its just getting the beast off the line that sucks the gas i guess
  10. Nov 12, 2022 at 10:39 PM
    #220
    That makes sense. Weight hurts more in the city. Things like roof racks hurt more on the highway.
    Even my "city" driving is mixed, as I'm in a semi rural area.
    blue4runner[QUOTED] likes this.
  11. Nov 12, 2022 at 11:58 PM
    #221
    Singleminded
    OEM LED foglights
    Computer says I got 21.5 mpg on a 100 mile round trip today, and that was running on my AT tires, not the stock Duelers. But it was almost all at 40-60 mph, only a few stoplights, mostly flat and mild weather.
    mrmike7189 likes this.
  12. Nov 13, 2022 at 9:45 AM
    #222
    I wonder if the gas used regionally makes a difference. I just filled up the other day and hand calculated 18.6 mpg. I have my dash fuel display turned off, and have since probably 6 months into ownership, so mine has never been reset since new. I randomly turned it on a while back, and the running average says 19.1. I hand calculate every tankful just for information's sake, and I usually get 18.6 - 19.5 with an occasional 20.5. My 4R is used almost exclusively in the city with an occasional trip out of town.
    I attribute the recent 18.6 to the inevitable switch to winter blend.
  13. Nov 13, 2022 at 1:42 PM
    #223
    Singleminded
    OEM LED foglights
    What is "city" for you? I don't see how this is possible with frequent stops at intersections and inconsistent speeds due to traffic. Which is what I think is meant by city. If it's 25/35/40 mph roads but they're country roads with few stops or slow downs, then definitely the MPG will be good. But again that's not city driving.
  14. Nov 13, 2022 at 2:02 PM
    #224
    I'm not sure about regional fuel quality, aside from winter blend as you mentioned. But, I'll say that the environment (Elevation, climate, etc..) seems to have a big impact.
    I also think it plays a part in how much people like the 1GR. Today I was reminded that when the temperature drops to freezing, it seems to lose a significant amount of power. I was driving on backroads at 60, and in D it couldn't stop downshifting. I ended up in S4.
  15. Nov 13, 2022 at 3:45 PM
    #225
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I also wonder about regional variations in gasoline when driving from CA to AZ and UT. I always get around 20-21 MPG on UT and AZ highways even at 70-80 MPH. Getting back to CA I get 17-18 MPG.
    Maybe the clean air formulation, winter blend, more ethanol. Also could be temperature, elevation effects.
  16. Nov 13, 2022 at 9:50 PM
    #226
    City is where I live. Mostly trips to work & back, about 3 miles each way, with 9 traffic lights between home and there, with average speed limit of 35 mph. Then around the city after work to various destinations, with some interstate driving to reach the other side of town quicker, but rarely. I don't see country roads with few stops unless I take an out of town trip.
    It's usually me alone or with my wife. I don't haul a lot of stuff around.
    Albuquerque is at an elevation of 5000 ft, so our regular gas is 86 octane. I get it at Costco. Factor? IDK...
    I also have a Sprint Booster, but don't think that plays any role in mpg. I set mine at one setting and left it. I did do several tankfuls when the SB was new with it on, then several with it off, then back on again, over a couple of months, with little difference in mpg, so I left it on. I did a thread on that some time ago.
    Singleminded[QUOTED] likes this.
  17. Nov 14, 2022 at 12:33 PM
    #227
    MountainMan
    Pacific Northwest
    I got an exceptional 17.4 mpg on my 308 mile drive across Washington state to visit my kids in Seattle. And that was with the last two hours and 20 miles in 1st gear on the 405 barely inching along.
    For the trip back, I filled up on the Air Force/Army base at $4.49 a gallon, then tried inflating the tires from 38 psi to 45 psi.
    No stop and go traffic, no wind, but the temps dropped to freezing. My mileage plummeted to 15.5 mpg on the trip back.
    Going down a long 4% grade, with the cruise set at 73 mph, I was struggling to get over 20 mpg.
    That dramatic of a drop had to be crap gas bought on base.
  18. Nov 16, 2022 at 1:54 PM
    #228
    I typically get 18-19 around home. After my recent cross country road trip. I averaged 14 mpg. Crossing the Rockies and battling a 20+ crosswind and headwind made the cruise control worthless.
    It seemed to me that wind is the biggest affecting factor.
    nimby, glwood54 and Thatbassguy like this.
  19. Nov 17, 2022 at 6:33 AM
    #229
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    I did something similar. Traded my 4R for a CRV. I will own a 4R again someday.
  20. Nov 17, 2022 at 11:33 AM
    #230
    Singleminded
    OEM LED foglights
    You get really surprising mpg for those conditions. It’s very close to the EPA highway number. I can’t even imagine how you manage 18.6 with short trips and multiple stoplights etc. It’s unfathomable for me. I might equal that once in a blue moon, when everything lines up right, but typically I’m around 15 — and often lower. Amazing!
  21. Nov 17, 2022 at 1:26 PM
    #231
    AllTerrainT4R
    AllTerrainT4R New Member
    Chris
    Northern California
    2014 4Runner Trail Premium & 2014 Tacoma TRD Sport DCSB MT
    Kings 17x9 Ray 10's C4 Skids RCI Sliders Prinsu TSO Grille Morimoto Headlights
    I am right there with you. I average 13.5 MPG with mixed driving and living in the foothills.
  22. Nov 17, 2022 at 3:06 PM
    #232
    It is that, I agree. I used to have a Fuelly account for my 2013 Tacoma, but let it lapse after I sold the truck. I may revive it so I can graphically see the progress, or lack thereof, of mpg readings over the 3 years since new. That is also an easy way to track fuel expenses. The one thing I remember with Fuelly is it was easy to see the drop in fuel mileage during the winter when the 'winter blend' hit the pumps...
  23. Nov 17, 2022 at 9:32 PM
    #233
    Spjs86
    Spjs86 New Member
    2022 MGM 4Runner TRD Pro
    I really baby my 4Runner and average around 17-19 MPG mixed driving. Try make sure that Eco light is on.
  24. Nov 18, 2022 at 12:41 PM
    #234
    MountainMan
    Pacific Northwest
    I had a friend on FB comment on a photo of my dash showing the Eco light on. He also has a 5th gen and said that the first mod he did was disable that setting.
    I never did ask him what that was about. Reminds me to search for it on here since I have never seen it come up in the threads.
  25. Nov 18, 2022 at 12:54 PM
    #235
    You can disable it by driving in S mode. Or, just drive super aggressively all of the time. :D
    MountainMan[QUOTED] likes this.
  26. Nov 18, 2022 at 1:13 PM
    #236
    MountainMan
    Pacific Northwest
    Turns out you can just turn the light off by going into the display setting menu. I guess it's never bothered me enough to do so. Now I will probably notice it all the time and get annoyed, lol.
  27. Nov 18, 2022 at 1:22 PM
    #237
    ToyotaRDie
    ToyotaRDie New Member
    I just bought the "Fuel Save Pro", people seem to rave about it. I'll post results when I get mine.
  28. Nov 18, 2022 at 1:24 PM
    #238
    QStune
    QStune New Member
    Chester Co., PA
    2021 Black Tacoma OR DCLB
    Elite Performance tuned AE manifold spacer Bed Lights Seat Jackers Spiker Eng. single hood strut
    You should consider getting your 4Runner tuned. The new KDMAX Pro-9.0 tune increases mpg as well as HP and torque.
  29. Nov 18, 2022 at 1:39 PM
    #239
    SnowBunny56
    SnowBunny56 New Member
    North Texas
    1999 3rd Gen
    Toyo tires with Fuel wheels, Carhart seat covers, getting started with some suspension mods
    As a longtime tech at a new car & truck dealership I've learned to only used what fuel is recommended by the manufacturer, it will be shown on the instrument cluster or in owners manual, the engine control module is calibrated for a particular octane rating for that vehicle, high performance vehicles are calibrated for premium fuel, in most cases you're wasting your money running a higher octane fuel and in some cases it can cause driveability issues
  30. Nov 18, 2022 at 3:01 PM
    #240
    Haha! I always forget about it, because I use S4 pretty much all summer. It doesn't bug me, as I'm already accustomed to ignoring the TPMS warning on the dash.
