My 2022 T4R
Discussion in '5th Gen 4Runners (2010-2024)' started by emacTR4, Apr 23, 2022.
  1. Feb 6, 2024 at 7:37 AM
    #121
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    Hopefully this picture will help better explain what I wrote above. The end with the orange arrow connects to the OEM harness off the DRL bulb, and the end with the green arrow now connects to the new LED DRL bulb. The red and black wires that run between the ends of the new harness have to be cut (remove the wire cover first). Take the black and red wires from the orange end and splice them together, then connect them to the red wire coming off the green end. That leaves the black wire coming off the green end that has to go to ground. It's pretty easy to do, and makes the LEDs for DRLs work like they're supposed to.
  2. Feb 6, 2024 at 10:06 AM
    #122
    blue4r_15
    blue4r_15 New Member
    Iowa
    2022 Limited in Nautical Blue
    I am planning on making this harness this weekend. If it works, I’ll make a spare and I can let you know in case you still want one.
    HBJ32[QUOTED] likes this.
  3. Feb 7, 2024 at 12:23 AM
    #123
    angriswo
    angriswo New Member
    would love to pick up a harness if anyone has an extra laying around! please let me know! thanks!
    does anyone have amber bulb recommendations by chance as well?
  4. Feb 7, 2024 at 5:08 AM
    #124
    bronzestar1
    By amber bulbs I'm assuming you're referring to turn signal bulbs? If so, make sure if you get LEDs, that they have built-in resistors. The first set I got didn't, and they hyperflashed. The next set did, and they blink like normal. However, the LED fronts I'm using aren't dual-element, they're single element like the rears, so they only act as turn signals, not marker lights.
  5. Feb 7, 2024 at 6:18 AM
    #125
    kpmhspirit
    kpmhspirit New Member
    Pete
    North Illinois
    This has links to the bulbs. Front ones have dual-element and all work perfectly so far.
    https://www.4runners.com/threads/turn-signal-switchback-lights.35324/page-3#post-527402
  6. Feb 7, 2024 at 7:12 AM
    #126
    angriswo
    angriswo New Member
    Amber led for the DRL swap.
  7. Feb 7, 2024 at 7:12 AM
    #127
    angriswo
    angriswo New Member
  8. Feb 7, 2024 at 8:01 AM
    #128
    bronzestar1
    I think it depends on the year. On my '23, the DRL is a dedicated bulb, with the low/hi beams being a single bulb in the projector. On mine, the turn signal bulbs will NOT work as DRLs, it's an entirely different bulb (closer to a typical headlight bulb than a turn signal bulb). On my '23, I think the DRL is an HB3 bulb, while the front turn signal is a 7444?
  9. Feb 7, 2024 at 12:59 PM
    #129
    kpmhspirit
    Pete
    North Illinois
    Same on mine. These are the bulbs I used for the DRL replacement. Looks like they only have them in white. Maybe some other source has them in yellow?
    https://www.diodedynamics.com/9005-hp48-led-bulbs.html
  10. Feb 7, 2024 at 1:05 PM
    #130
    kpmhspirit
    Pete
    North Illinois
    Nope. Those are only for front+rear turns and reverse lights. My previous post has the DRL replacement.
  11. Feb 7, 2024 at 2:07 PM
    #131
    blue4r_15
    Iowa
    Auxbeam on Amazon sells amber bulbs for DRL. I have the white ones from them, but they have a very slight flicker on my 2022, it's only noticeable when you're close to the lights and looking at them directly. I was ok with it until I ran into this harness fix. I am waiting for parts to make a harness to see if it fixes the flickering.
  12. Feb 7, 2024 at 3:38 PM
    #132
    bronzestar1
    I ended up using those bulbs, in yellow. Along with the harness mod, they work perfectly as DRLs. I had white LEDs (9005/HB3), I think they were Auxbeams, and they worked fine with the harness mod. I wanted yellow ones for DRLs, so based on what's been posted, I went with the DDHP48s.
    roooo likes this.
  13. Feb 8, 2024 at 8:43 AM
    #133
    james_f
    james_f New Member
    Anybody have a spare harness they would like to sell?
  14. Feb 10, 2024 at 1:21 PM
    #134
    angriswo
    angriswo New Member
    harness done. grounded and just waiting for LEDs to arrive.
    Nubes likes this.
  15. Feb 10, 2024 at 1:42 PM
    #135
    blue4r_15
    Iowa
    I have an extra harness $20. pm me
  16. Feb 10, 2024 at 2:20 PM
    #136
    blue4r_15
    Iowa
    Sold
  17. Feb 10, 2024 at 4:13 PM
    #137
    angriswo
    angriswo New Member
    I also have an extra harness for $20. pm me if you want it.
  18. Feb 11, 2024 at 6:06 PM
    #138
    bronzestar1
    Is it just me, so does this wiring harness mod look strange?
  19. Feb 11, 2024 at 6:49 PM
    #139
    angriswo
    angriswo New Member
    How so? it’s identical. I added more black tubing around the ground cable as well.
  20. Feb 11, 2024 at 7:29 PM
    #140
    bronzestar1
    I see it now, just a lot longer than what I did with mine, and I didn't use wire covers...
  21. Feb 11, 2024 at 7:38 PM
    #141
    angriswo
    angriswo New Member
    Yeah i was lazy and didn’t want to measure and for fear of going too short i Just went long and I may cut it down.
  22. Feb 12, 2024 at 12:27 PM
    #142
    MS1181
    MS1181 New Member
    Marciano
    Houston, TX
    2019 Limited - Barcelona Red
    If anyone has an extra harness for the DRL's change, I am ready to Zelle payment. Let me know, thanks.
  23. Feb 12, 2024 at 12:42 PM
    #143
    angriswo
    angriswo New Member
    I got you! DM me and we can sort out details.
  24. Feb 12, 2024 at 12:52 PM
    #144
    MS1181
    MS1181 New Member
    Marciano
    Houston, TX
    just DM'd you.
  25. Feb 12, 2024 at 4:06 PM
    #145
    bronzestar1
  26. Feb 12, 2024 at 6:06 PM
    #146
    angriswo
    angriswo New Member
    fun project thanks for guidance
  27. Feb 13, 2024 at 5:39 AM
    #147
    MS1181
    MS1181 New Member
    Marciano
    Houston, TX
  28. Mar 12, 2024 at 7:03 AM
    #148
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    I'll have a spare harness soon. Just ordered stuff yesterday. Will post again after I get them made.
  29. Mar 15, 2024 at 10:02 AM
    #149
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
    I've got everything I need minus the ground wire and spade or ring terminal. Did anyone disconnect the battery before messing with the lights/ground post on the body...or don't worry about it?
  30. Mar 15, 2024 at 10:49 AM
    #150
    bronzestar1
    I didn't disconnect the battery when I installed the grill lights or underhood lights (two different days). Just be careful and don't be touching wires where they shouldn't go, and you'll be fine...
    Trees91[QUOTED] likes this.
