My 2022 T4R
Discussion in '5th Gen 4Runners (2010-2024)' started by emacTR4, Apr 23, 2022.
  1. Aug 16, 2023 at 2:37 AM
    #91
    Danielsnlv
    Danielsnlv New Member
    @TxTRD I'm interested if you still have
  2. Aug 18, 2023 at 2:47 PM
    #92
    T4R808
    T4R808 New Member
    Any finished harnesses still out there? Interested in buying one
  3. Aug 24, 2023 at 8:34 PM
    #93
    Speedreefer
    Speedreefer New Member
    I made the exact same harness. Installed same but only driver side lights up. The bulbs i installed are: https://a.co/d/gERRSvQ
    is it not working because they are polarity sensitive? Or too high lumen?
  4. Aug 24, 2023 at 10:48 PM
    #94
    Danielsnlv
    Did you use the pic from page 1 of this to build yours or instructions from another thread? If another thread which one?
  5. Aug 25, 2023 at 6:50 AM
    #95
    Speedreefer
    Yes I used the pic from page 1 and ordered the exact same parts off Amazon
    Danielsnlv likes this.
  6. Aug 25, 2023 at 10:07 AM
    #96
    Danielsnlv
    Just asking because I haven't tried yet and want to get as much info before I start. Also I'm curious where the other posts are that show how to wire it up.
  7. Aug 25, 2023 at 10:08 AM
    #97
    Speedreefer
    I’ll update when i receive the DD leds that were specified in the post, the non polarity ones. Try again and see if it works
  8. Aug 25, 2023 at 10:15 AM
    #98
    Danielsnlv
    It would be too easy to find a 6v led bulb that had a the 9005 male end. I can find 6v bulbs for motorcycle but wrong end..
  9. Sep 8, 2023 at 11:52 AM
    #99
    Frank638
    Frank638 New Member
    2023 4Runner Limited, Blizzard Pearl
    Got mine changed over today. Thank you for the advice on the harness! I made mine the same way as OP and have an extra for sale. Post here or PM me if interested. IMG_8014.jpgIMG_8011.jpg
  10. Sep 9, 2023 at 9:36 PM
    #100
    Speedreefer
    Got the DD HP48 bulbs.. built same wiring harness.. put it all together.. now both DRL don't work.. and when I put my old halogen bulbs back in they don't work anymore either! Zero idea how I could've fucked this up... pretty simple thing. Guys have any idea how I can figure out why my DRL's are lighting up anyore?
  11. Sep 10, 2023 at 6:57 AM
    #101
    emacTR4
    emacTR4 [OP] New Member
    You probably shorted the circuit while making the connections. Check your fuses. Then check the harness that you made for any shorted wires. The harness is just a simple way to extend the +wire to the other side as +12V. From factory, each bulbs gets 6v due wired in series.
  12. Sep 10, 2023 at 10:30 AM
    #102
    Speedreefer
    Been trying to figure out which one is the drl fuse
  13. Sep 10, 2023 at 3:24 PM
    #103
    Nubes
    Nubes Toyota Addict
    I believe it is actually a relay and not a fuse. Located in the small relay box next to the main fuse box in the engine bay.
  14. Sep 10, 2023 at 5:08 PM
    #104
    Speedreefer
    So do I replace the relay or something? How do I check if its good
  15. Sep 10, 2023 at 8:31 PM
    #105
    Nubes
    Nubes Toyota Addict
    Not sure on how to check it, yours looks different to mine. I would start with searching the part number for the relay to see if replacing it is cheap. I did read that some people who had issues with DRL going out disconnected the battery for a few minutes and after reconnecting was working again.
  16. Nov 12, 2023 at 6:41 AM
    #106
    Javi34
    Javi34 New Member
    2023 SR5 Premium Mid Night Black
    Hello, new to the 4Runner life I came from a Tundra and liking it so far. Does anyone have an extra harness that I could buy. Thanks
  17. Nov 12, 2023 at 7:07 AM
    #107
    Frank638
    Frank638 New Member
    I’ve still got one. I’ll send you a PM.
  18. Dec 1, 2023 at 5:43 PM
    #108
    so2315
    so2315 New Member
    Iowa
    2022 TRD ORP Nautical Blue
    I will have an extra harness available in a couple of days. Just waiting on the LED bulbs to show up and verify that the harness I made will fit and work. Thats if anybody is still looking for one.
    **SOLD**
    Powerstroke likes this.
  19. Dec 2, 2023 at 6:00 PM
    #109
    emacTR4
    Today, I added a vinyl hood scoop decal to help reduce the glare. I also added custom printed TRD Pro decal on each side.
    ToyotFan and Newfy like this.
  20. Dec 19, 2023 at 12:44 AM
    #110
    sluhdude
    sluhdude New Member
    Nic
    ‘22 4Runner TRD Pro
    If anyone has an extra harness, I’d love to pick one up. Please PM me for info.
    HondoX10 likes this.
  21. Dec 27, 2023 at 6:41 AM
    #111
    HondoX10
    HondoX10 New Member
    Tyler
    2023 Silver TRD OR Premium
    Same, I'd like to get my hands on a harness as well.
  22. Dec 29, 2023 at 11:00 AM
    #112
    Newfy
    Newfy New Member
    Point Pleasant Beach, NJ
    2023 White TRD Pro
  23. Dec 31, 2023 at 9:05 AM
    #113
    emacTR4
    I got the vinyl from Amazon. The TRDPro decals, I made them at home using a vinyl cutter.
  24. Jan 18, 2024 at 11:04 AM
    #114
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    So if I'm seeing these harnesses correctly, the blue one goes to the bulb itself, the other side connects to the harness, yes? And it looks like the two wires off the harness connector are spliced together into the one wire on the bulb socket, and the other wire is to ground?
  25. Jan 19, 2024 at 4:02 PM
    #115
    emacTR4
    It depends on the bulbs that you're going to use. If they are polarity sensitive, you need to treat the PINK wire as positive and ground the other wire. Actually, the original bulb connector on passenger side carries just 1 signal which is +12V. We are just extending it to the other side to eliminate the series circuit. Hope the diagram below helps.
    MeefZah and Nubes like this.
  26. Feb 1, 2024 at 12:08 PM
    #116
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    Where did you get the hood scoop decal at? I need to get this as I know it will be an issue this summer.
  27. Feb 4, 2024 at 8:55 PM
    #117
    HBJ32
    HBJ32 New Member
    Interested in a harness if someone has a spare
    blue4r_15 likes this.
  28. Feb 5, 2024 at 11:02 AM
    #118
    bronzestar1
    If you're talking about one of these, that folks use to upgrade the halogen DRLs to LEDs, you'll probably be better off just getting a pair from Amazon. I have an extra, but I'm planning on using it on my daughter's '23 TRD ORP to upgrade her DRLs to LEDs.
    Amazon.com: iJDMTOY 9005 HB3 9145 H10 9006 HB4 Extension Wiring Harness Sockets Wires Compatible with High/Low Beam or Fog Lights Use : Automotive
  29. Feb 5, 2024 at 9:07 PM
    #119
    HBJ32
    HBJ32 New Member
    So the blue connector goes to the new led bulb and the other connector goes to the back of the current wire coming out of the oem bulb? I’m not seeing where the current wiring would disconnect anywhere else.
  30. Feb 6, 2024 at 7:00 AM
    #120
    bronzestar1
    Do a search for the DRL harness, there's some good info about how to wire up the add'l harness. If I remember correctly, the connection at the engine side is "normal", just plug it in, same goes for the bulb end. But you have to cut the red and black wires in-between the new harness, splice together the red and black wires coming from the engine side of the connector, and connect them to the red wire coming off the bulb. That leaves the black wire coming off the bulb, which you put to ground. This way only the new harness gets cut up, the OEM harness is left alone (but plugged in to the other end of the new harness). Doing this supposedly increases the power going to the DRLs, so that LEDs will work like they're supposed to. All I know is it works, I have yellow LEDs that I'm using for DRLs.
