My 2022 T4R
Discussion in '5th Gen 4Runners (2010-2024)' started by emacTR4, Apr 23, 2022.
  1. Aug 21, 2022 at 8:14 AM
    #61
    Sctitze22
    Sctitze22 New Member
    Silverdale, WA
    2022 MGM SR5P
    285 Nitto Ridge Grapplers TRD Pro Wheels Prinsu Rack AlphaRex Luxx Tail Lights Ironman Foam Pro Cell Stage 2 Gobi Ladder Westcott Designs Rock Sliders
    True, However the DRL’s are Halogen.
  2. Aug 21, 2022 at 9:16 AM
    #62
    ipnpulz
    ipnpulz New Member
    2023 TRDOR premium T4R
    I had thought they changed that set up from the 21 models like mine....
  3. Aug 21, 2022 at 9:41 AM
    #63
    Culverhouse09
    Culverhouse09 New Member
    Trevor
    2022 TRD ORP
    Yes, they have the LED hi/low beams, but the DRL bulbs are standalone halogens. Wanting to replicate the mod from this thread so just making sure I’m buying the right items.
  4. Aug 21, 2022 at 11:35 AM
    #64
    jev425
    jev425 New Member
    Seattle
    2022 Nautical Blue TRD Off-road
    That is what you need but you'll also need a little extra wire and a small lug to make your harness(3rd picture on post #3 on the first page of this thread)
  5. Aug 21, 2022 at 12:01 PM
    #65
    Culverhouse09
    Trevor
    2022 TRD ORP
    Do I just buy that from an auto parts store?
  6. Aug 21, 2022 at 12:42 PM
    #66
    jev425
    jev425 New Member
    Seattle
    Yes you can do that. Maybe a short amount of wire loom/wrap to protect the short amount of wire.
    Culverhouse09[QUOTED] likes this.
  7. Aug 26, 2022 at 5:04 PM
    #67
    Culverhouse09
    Trevor
    2022 TRD ORP
    I'm attempting this mod currently and running into the same issue with the tight space around the grounding location. How the heck did you guys get this off?
  8. Aug 26, 2022 at 5:57 PM
    #68
    T3PO
    T3PO New Member
    ‘22 TRD Pro
  9. Aug 26, 2022 at 7:59 PM
    #69
    Culverhouse09
    Trevor
    2022 TRD ORP
    Boom... picked one of those up and it did the trick. Successfully installed and both lights working... woohoo! Thanks everyone for answering my questions.
  10. Aug 27, 2022 at 7:39 AM
    #70
    CaNINE
    CaNINE New Member
    Ron
    2022 ORP KDSS
    Hey all - does anyone have a spare harness for this mod? I have a 2022 ORP and thought I’d check if anyone is willing to sell me their spare before I ordered the parts to make my own. Feel free to PM if you have one. Thanks!
  11. Sep 28, 2022 at 2:09 PM
    #71
    Mclain1
    Mclain1 New Member
    I joined the forum because of this thread. Just wanted to Hello and thank you! I built my harness with the easy to follow instructions and now im enjoying my HP48 bulbs on my 2022 ORP! Looks great!
    jev425 likes this.
  12. Nov 4, 2022 at 4:19 PM
    #72
    Capt.Rick
    Capt.Rick New Member
    21 4Runner lited
    emacTR4, can the diode dynamics xp80 bulbs be used in place of the hp48
  13. Nov 4, 2022 at 11:37 PM
    #73
    emacTR4
    emacTR4 [OP] New Member
    You can actually use any bulb, but they will be too bright as DRL.
  14. Nov 25, 2022 at 1:21 PM
    #74
    yormek
    yormek New Member
    did this to my 23 and its awesome.proud of myself too... did window visors,trd rims on oem tires and black badge overlays...between yesterday and today...
  15. Nov 25, 2022 at 11:00 PM
    #75
    atk411
    atk411 New-ish Member
    Orange County, CA
    2022 Barcelona Red Off Road Premium
    The flicker was the main reason I changed the wiring from series to parallel--to get back to 12V.
  16. Jan 31, 2023 at 6:06 PM
    #76
    CaNINE
    CaNINE New Member
    Ron
    2022 ORP KDSS
    Well dang it. I built my harness and tried with the Alla lighting 9005 LEDs. Only the drivers side lights up. 22 ORP. Any ideas?
  17. Feb 19, 2023 at 7:30 PM
    #77
    cmclunar
    cmclunar New Member
    Cason
    2023 4Runner trd orp
    Have an extra harness $20 pm me
  18. Mar 5, 2023 at 10:02 PM
    #78
    SkyRunner1013
    SkyRunner1013 New Member
    Sky
    23' 4Runner TRD PRO
    Cmclunar,
    Do you still have an extra harness? Just picked up a 23' TRD PRO Saturday and already trying to figure out how to get LED's swapped for the halogen DRL's. Thanks
  19. Mar 5, 2023 at 10:18 PM
    #79
    emacTR4
    Your bulbs are probably polarity sensitive. Some LED bulbs, including the HP48, can light up even wired up reversely.
  20. Mar 6, 2023 at 4:18 AM
    #80
    CaNINE
    CaNINE New Member
    Ron
    2022 ORP KDSS
    I rebuilt the harness and now everything works great. I suspect one of my connections was bad. Regardless all is well now. Now onto suspension. Thanks everyone.
  21. Mar 6, 2023 at 6:28 AM
    #81
    cmclunar
    cmclunar New Member
    Cason
    Sold
  22. Mar 10, 2023 at 8:53 AM
    #82
    bama4runner251
    bama4runner251 New Member
    Randy
    2016 4Runner Limited
    I can finally see the light at the end of the tunnel lol I've been up all night reading forms and came across this one. So, I have everything ordered to build my own harness except the black ground wire. What gauge wire did y'all use...16 or 18?
  23. Mar 10, 2023 at 12:02 PM
    #83
    daveeasa
    daveeasa New Member
    David
    '02 Tundra, '05 Tacoma, '16 Tacoma
    So, the Driver side receives the input I assume based on this? And polarity has not changed from 2021 and earlier (that part seems fairly safe to assume but worth asking explicitly as these LED bulbs are not polarity sensitive?)
  24. Mar 17, 2023 at 3:00 PM
    #84
    SilverJester
    SilverJester New Member
    2023 4runner TRD Off Road Premium
    Just finished doing the DRL led conversion. Looks so much better, great work!
  25. Apr 22, 2023 at 11:00 AM
    #85
    Jackmahoffer
    Jackmahoffer New Member
    Spencer
    22 white trd pro
    I finally got around to doing this mod. Congrats to anyone who was able to get to that bolt holding the ground wires without having to unbolt and shift the air pump first. I struggled for 20 minutes trying to get the right combo of extensions and swivels before I stopped being lazy and moved the air pump.
  26. Apr 22, 2023 at 11:38 AM
    #86
    jev425
    jev425 New Member
    Seattle
    This little mod ended up expediting the purchase of some ratcheting wrenches I had planned to get. I ended up using an open end wrench to loosen it enough to slip on a U/fork spade.
  27. Apr 27, 2023 at 11:23 AM
    #87
    SilverJester
    Yeah there's not a lot of space. I was able to get it with a ratcheting wrench.
  28. Apr 30, 2023 at 8:20 AM
    #88
    waldo98
    waldo98 New Member
    Walter
    SoCalli
    2023 ORP Nautical Blue Metallic
    @emacTR4 are you making any more 9005 harnesses?
  29. May 14, 2023 at 7:58 PM
    #89
    SHIH
    SHIH New Member
    Extra wiring harness, it's free.pm me
    END
  30. May 28, 2023 at 8:32 PM
    #90
    TxTRD
    TxTRD New Member
    Tx
    22 TRD ORP
    I have an extra harness available for anyone looking.
    Danielsnlv likes this.
