Mud flap delete
Discussion in '5th Gen 4Runners (2010-2024)' started by GreyRunner808, Jun 4, 2020.
  1. Jan 4, 2024 at 1:18 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey like many have said here, the front you just take off which I believe leaves not much evidence beside empty clip hole.
    The rear has nice mudflap delete kits which are smart, and pretty slick looking.
    @LandCruiser I wish I was naturally more caring about other folks behind me on roads or behind me in line ups. My wife highly dislikes that I have a tendency to fail to naturally consider people - like when someone pays it forward in the drive thru line up I always break the chain and say thanks buddy.
    I haven't seen ppl post it here yet, but I actually took a Milwaukee Sawsall to my rear mudflaps(DELETE COMPLETE lol). Then installed aftermarket Husky Liners Kickback flaps overtop using existing holes!
    But I removed the flaps until I do long highway trips or pull a trailer. My rocker panels be damned!
    raimieb likes this.
  2. Jan 4, 2024 at 1:28 PM
    If you're rubbing behind front wheel:
    -my shop removed front "mud guards" entirely for this
    Then for in front of tire Dremel cut a sliver off bottom of front bumper fender in front of tire
    -I was still rubbing with 285's, so additionally you may have to look at the dreaded body mount chop, as well as hammer bending fender mount tabs (I got em chopped and welded). Also I removed valance/rocker caps and now finally NO RUB baby
    -question is: do you have aftermarket control arms?
    They give you the ability to increase Castor ⁰
    My lower control arms are factory, I want to get their Castor ⁰ checked. My SPC UCA's are around 3.8⁰
    raimieb[QUOTED] likes this.
  3. Jan 4, 2024 at 2:00 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Thanks DJ! To solve the fender flare issue I just ordered THESE. So I'll report back. Love fiddling with the 4R so couldn't help but be an early adopter.
    Yes, Dobinsons Billet UCAs; they are gorgeous too! My 4R is a sleeper with Elka 2.5DCs, Dobs UCAs, Dobs rear springs, superstrings bumpstops, etc. Now it needs some PPF repair and a detail. :)
    djwantke[QUOTED] likes this.
  4. Jan 4, 2024 at 2:02 PM
    Nice dude, quality setup you go goin on!
    I want those rocker caps big time (bookmarked)
  5. Jan 4, 2024 at 2:32 PM
    Mass4runner
    Mass4runner New Member
    2023 TRD ORP
    I've used the revtek deletes on my '19 and '23. Haven't noticed any issues other than a bit more mud thrown up. For the fronts I reinstalled the push clips to cover the holes left behind.
    raimieb likes this.
  6. Jan 4, 2024 at 4:57 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    I noticed you said "try"... :D
  7. Jan 4, 2024 at 6:56 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Hahah. Play nice DJ!!! Hahah
    bassist[QUOTED] likes this.
  8. Oct 15, 2024 at 8:59 AM
    Lettuce
    Lettuce New Member
    Seattle/Tacoma
    2019 Toytoa 4Runner Limited
    N-Fab Side Steps, Blackout badges & grill, TRD Roof Rack,
    I know this an old thread, however , on the 5th Gen Limited edition when removing the factory mud flaps there is already an installed mud flap delete kit installed.
    raimieb and djwantke like this.
  9. Oct 15, 2024 at 9:04 AM
    Ya don’t say. Nice.
  10. Oct 15, 2024 at 10:06 AM
    Knarf
    Knarf New Member
    DFW
    2024 White SR5
    I cut the stock ones, not perfect but it works and covers it up enough
