Mickey Thompson Baja Boss A/T
Discussion in 'Wheels & Tires' started by PVT Pablo, Nov 24, 2022.
  1. May 20, 2024 at 12:41 PM
    #151
    Flit04
    Flit04 New Member
    2024 Ice Cap White TRD
    MT Baja Boss 265/70/17 XL.. loving them so far!
    kolter45, ChristopherAnt, roc and 5 others like this.
  2. May 20, 2024 at 5:49 PM
    #152
    They look good! Are you lifted at all?
  3. May 20, 2024 at 6:50 PM
    #153
    Flit04
    Flit04 New Member
    I am. Accutune 2/1 Fox Lift, Method 701’s 17x8.5 0 offset with the MT’s. I had them on a few days before I installed the lift yesterday, no rubbing with daily driving.
    Trail Runnah and djwantke like this.
  4. May 20, 2024 at 8:54 PM
    #154
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    :wave:
  5. Jun 1, 2024 at 4:26 PM
    #155
    discontinued Baja ATZ 3yrs old
    kolter45, Flit04, JChiz and 1 other person like this.
  6. Jun 1, 2024 at 4:35 PM
    #156
    damn they look brand new. How many miles on them?
    djwantke[QUOTED] likes this.
  7. Jun 1, 2024 at 4:41 PM
    #157
    thanks bud
    35,000
  8. Jun 1, 2024 at 5:52 PM
    #158
    HighSierraGuy
    HighSierraGuy New Member
    Wtf, that's impressive
  9. Jun 1, 2024 at 7:23 PM
    #159
    damn!! I might have to switch up to MTs next round.
  10. Jun 1, 2024 at 7:35 PM
    #160
    *35,000 Canadian miles :p
    (but still)
    ThatOneGuy and TrailSpecial22 like this.
  11. Jun 2, 2024 at 2:26 PM
    #161
    mrb09
    mrb09 New Member
    2022 ORP
    Great thread. My modest contribution: P285/70/17 SL, on RRW R7, Matte Black, 0 offset.
    kolter45, Bend_4R, PJSnow and 6 others like this.
  12. Jun 2, 2024 at 2:38 PM
    #162
    Henry J
    Sacramento Ca
    I’m considering going from 285 to 295, got about 10-15k left on mine. And I’m getting twitchy
    djwantke and mrb09 like this.
  13. Jun 2, 2024 at 2:54 PM
    #163
    Just enough time to cut and chop :p
  14. Jun 2, 2024 at 3:14 PM
    #164
    Henry J
    Sacramento Ca
    Yup!
    already had my bmc, but going back to StellarBuilt this week and might need to do the pinch weld. If they see anything else I’ll just do it early.
  15. Jun 2, 2024 at 5:15 PM
    #165
    man they look massive compared to mine in the same size in Falkens
    djwantke and mrb09[QUOTED] like this.
  16. Jun 2, 2024 at 5:24 PM
    #166
    mrb09
    mrb09 New Member
    2022 ORP
    It's probably just perspective, my lens is lower. Falkens look awesome too. Great choice as well and awesome looking rig!
  17. Jun 2, 2024 at 5:37 PM
    #167
    thank you!!
  18. Jun 15, 2024 at 7:29 PM
    #168
    This Jeep at my grocery store looked so nice.
    Clean on 35” Baja Boss’s
    Matching 5th wheel.
    Must have been 4”-6” lift. Teraflex Falcons
    Picture doesn’t do it justice. How much it cost?
    Made my 4Runner look like a baby @Yotaholic
    That thing had lightyears of space behind the front wheel, unlike 4Rs
    kolter45 and Yotaholic like this.
  19. Jun 15, 2024 at 7:54 PM
    #169
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Believe it or not it's cheaper to modify jeeps, aftermarket is insane
    Smart guy, Willys is the best deal. Believe it or not, that 2024 Willys, has the same exact front Dana axle as the 2023 392 Wrangler Rubicon. You can throw 37-in mud terrains in there, and it will be fine
  20. Jun 15, 2024 at 9:20 PM
    #170
    Yotaholic
    Olympia, WA
    I saw this Willys on 37 in Baja Legend MTZ's few weeks back. Jeep is just a different animal. But our rigs are comfortable and spacious, what are you going to do with this little thing! I can't imagine driving that thing on a long road trip
  21. Jun 16, 2024 at 11:38 AM
    #171
    Yotaholic
    Olympia, WA
    Jeep thing. I am buying this lift kit once I get my hands on a TJ
  22. Jun 16, 2024 at 5:26 PM
    #172
    I have put 4K on the MT so far and they seem ok, they are a bit louder than the faulken wild peaks, but have performed ok. I actually have a hard time distinguishing from one set to another but the MT do look more aggressive and more capable. I just got them rebalanced after this offroad trip and discount tire did notice them a bit off, but they were brand new of course.
    TrailSpecial22 and ThatOneGuy like this.
  23. Jun 17, 2024 at 6:57 AM
    #173
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Had my Duratracs for a few years now (35k+) and they have been awesome in the rain snow and off roading. My initial research paid off!
    But these Baja Boss Look to be similar and have more standard ratings. If they are as good in the rain as my Duratracs i may switch. It sounds like they are just as noisy as mileage goes up, but snow/rain/off road are most important to me. I'm curious how they do over time for you guys. It will be hard to beat the Duratracs.
  24. Jun 27, 2024 at 7:04 PM
    #174
    ChristopherAnt
    ChristopherAnt New Member
    2024 Barcelona Red 4Runner TRD Offroad
    IMG_0612.jpg Baja gang! Got a set of Baja boss 265/70/17. I only have experience with KO2, good tires, not so great in the rain. Ready to get these dirty.:)
    kolter45, djwantke, Garlic and 4 others like this.
  25. Sep 2, 2024 at 8:38 AM
    #175
    How have they been for ya since!?
    ilike4runners likes this.
