Mickey Thompson Baja Boss A/T
Discussion in 'Wheels & Tires' started by PVT Pablo, Nov 24, 2022.
  1. Mar 8, 2024 at 9:09 AM
    #121
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    kolter45, raimieb and TrailSpecial22 like this.
  2. Mar 12, 2024 at 2:34 PM
    #122
    adamsls
    adamsls New Member
    Just got these today. Already like them better than the Nittos we pulled off.
    Stock size. Not the E range.
  3. Mar 12, 2024 at 2:59 PM
    #123
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Debating Baja Bosses in 295/70/17 or Nitto Ridge Grapplers in 285/75/17...
    Tire specs are very similar. I live in North Texas so not too worried about snow performance.
    The RG's offer both C and E load ranges. They are also about 6-7 pounds lighter...
    Any votes?
    djwantke likes this.
  4. Mar 12, 2024 at 4:09 PM
    #124
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Nice man, very tough decision I actually am looking at the exact same size choices for my next tires.
    As for my vote, I can say that I've seen zero complaints about Mickey Thompson's but I have seen complaints about Nittos. 6-7lbs lighter is not a bad thing to consider. Although I completely disregarded that. Not everyone wants to be lugging around a big nasty wheel setup like the @Yotaholic
    Yotaholic likes this.
  5. Mar 12, 2024 at 4:11 PM
    #125
    Welcome here dude!!
    And welcome to the Mickey Thompson family
    You certainly must be smart, and very good looking like the rest of us.
    ThatOneGuy and TrailSpecial22 like this.
  6. Mar 12, 2024 at 4:35 PM
    #126
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I just got a quote for 4.88, front locker, and upgraded CV axles. I may go 37s :rolleyes:
  7. Mar 12, 2024 at 5:04 PM
    #127
    :yes:
    Yotaholic[QUOTED] likes this.
  8. Mar 12, 2024 at 6:23 PM
    #128
  9. Mar 12, 2024 at 6:39 PM
    #129
    adamsls
    adamsls New Member
    The Nitto Terra Grapplers we took off will never be replaced on this truck. Really loud for what they are.
  10. Mar 12, 2024 at 6:46 PM
    #130
    1SilverRunner
    Tejas
    Would you stick with the Baja Boss 295/70/17 E load over the 285/75/17 Nitto RGs C load range? Even with the bajas being a bit heavier
  11. Mar 12, 2024 at 8:52 PM
    #131
    adamsls
    adamsls New Member
    I doubt 6-7lbs is going to make much of a difference. It’s way too early for me to say how I’ll feel about these tires. But they look 10/10 and the ride and noise are much much better.
  12. Mar 12, 2024 at 8:57 PM
    #132
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    When a tire weighs between 40 and 50 pounds, 6-7 pounds is kind of important. 7 pounds per tire could be the difference between 16mpg and 17mpg alone.
    ThatOneGuy and Trail Runnah like this.
  13. Mar 12, 2024 at 10:05 PM
    #133
    Well said
    Ya it's nearly 15% heavier
  14. Mar 13, 2024 at 12:51 AM
    #134
    Trouble24
    Trouble24 New Member
    Steph
    Leavenworth, WA
    2024 4Runner TRD Pro
    Ceramic Tint Prinsu Pro Roof Rack 3” Westcott lift ARB Awning
    Thanks for the detailed information. Very helpful as I'm in central Washington I'm about to purchase tires and was already leaning toward MT's and now can purchase with added confidence.
  15. Mar 13, 2024 at 9:32 AM
    #135
    backpacker
    backpacker New Member
    2023 TRD ORP
    And it's rolling weight, the most impactful kind.
  16. Mar 13, 2024 at 1:24 PM
    #136
    1SilverRunner
    Tejas
    Yup.
    Rotational unsprung weight = The holy grail of weight reduction.
    ThatOneGuy likes this.
  17. Mar 13, 2024 at 1:24 PM
    #137
    1SilverRunner
    Tejas
    Here's a quick comparison of the options I'm considering when I step up to the next size:
    Baja Boss AT -------------------------295/70/17------- Height 33.7" / Width 12.1" / Weight 72 lbs (E load range only)
    Nitto Ridge Grappler AT/MT ---------285/75/17--------Height 33.9"/ Width 11.3" / Weight 65 lbs (C or E load range)
    Nitto Ridge Grappler AT/MT ---------295/70/17---------Height 33.3"/ Width 11.8" / Weight 65 lbs (E load range only)
    Geolander MT G003 -----------------295/70/17---------Height 33.5" / Width 12.0" / Weight 66 lbs (E load range only)
    Geolander MT G003 -----------------285/75/17---------Height 34.1" / Width 11.1" / Weight 63 lbs (E load range only)
    Falken A/T4W ------------------------285/75/17---------Height 34.1" / Width 11.6" / Weight 68 lbs (C or E load range)
    These are all great options and at this point I'm sure I'm splitting hairs.
  18. Mar 13, 2024 at 1:58 PM
    #138
    Can't say I knew these things or put much thought into it when I started running 4x 90lb wheel/tire. Pretty sure crazy man @Yotaholic said he's over 100lb ea?
    I got to talking with a chill dude outside the pub couple weekends ago who came up and wanted to chat about my truck parked outside and he told me he has a 1st or 2nd Gen 4R on 40's and beadlocks and lockers and all that good stuff (he said well over a 100lb per wheel)
  19. Mar 13, 2024 at 2:23 PM
    #139
    1SilverRunner
    Tejas
    My current setup is about 86 pounds per wheel.
    285/70/17 Nitto RG's 58lbs
    RRW RR6-H at 28 lbs
    Fuel Mileage is 15-16 hwy, 14-15 city. Which I'm fine with. Didn't get this truck to be a fuel saver.
    I don't have gear hunting issues or trans temp issues. I'm hopeful that stepping up to 34's doesn't ruin the vehicle. I want it to maintain decent on road manners. So weight is definitely a factor worth considering. Not just for mileage, but for stress on the drivetrain, the possibility of breaking CVs and steering components. Power steering will be working harder. Lots to consider there.
    A lightweight but aggressive looking 34" with good performance is what I'm looking for. Don't really want to go narrower than my current 11.5" width as I want as much flotation as possible. My Nittos have plenty of life left so I'm just studying the options at this point.
    djwantke[QUOTED] likes this.
  20. Mar 13, 2024 at 2:36 PM
    #140
    You know what you make some good points, I think I should be considering the same thing you're thinking about for my next tires; lighter weight 34's. No more load E haha
    Or I sacrifice flotation and do 255/85
  21. Mar 13, 2024 at 2:38 PM
    #141
    1SilverRunner likes this.
  22. Mar 13, 2024 at 2:43 PM
    #142
    1SilverRunner
    Tejas
    Funny enough people always talk about load E's being heavier but that's hardly the case. According to most manufacturers specs the load E's are usually the same weight as the C's.
    I contacted Nitto about this and they told me it's due to the tire construction. More layers in the sidewall specifically, not the entirety of the tire. (Pardon the pun)
    I imagine the load rating has more to do with how the sidewall acts at different loads. If you have a very very heavy 4Runner, load D or E is probably right for you. But if you're close to stock weight a load E is likely unnecessary and will ride a little harsher.
    Overland Engineer did a video about this recently. He moved to a lightweight 35" load range C and actually saw a decrease in mileage. He inferred this was likely because the sidewall was not strong enough to handle the weight of his rig.
    https://www.youtube.com/watch?v=tPc9Hsq4DF8&t=27s
  23. Mar 13, 2024 at 2:54 PM
    #143
    Yotaholic
    Olympia, WA
    How much does a stock trd off-road wheel weigh? My KM3 is 67 lb. I think I must be closer to the 100 mark. So far so good, this truck is solid
  24. Mar 13, 2024 at 3:01 PM
    #144
    1SilverRunner
    Tejas
    Probably about 95 pounds altogether.
    How's the road noise at 70-75?
    Not sure why I didn't consider the KM3. It's a mean looking tire for sure.
  25. Mar 13, 2024 at 3:04 PM
    #145
    Yotaholic
    Olympia, WA
    They are way more noisy than the KO2. But the comfort level is pretty decent. Off-road they are kick ass.
  26. Mar 13, 2024 at 4:32 PM
    #146
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Stock trd or and sr5 wheels are around 28lbs.
  27. Mar 15, 2024 at 12:45 AM
    #147
    MountainMan
    MountainMan New Member
    Pacific Northwest
    I found the Holy Grail of AT tires for Washington state. The Goodyear Wrangler Ultra-Terrain AT only sold through Discount Tire. I ran a set on my 4Runner for a couple of years and experienced every conceivable terrain, from black ice and deep wet snow on Snoqualmie, to sharp rocks and deep sand in the deserts of Arizona and Mexico. I daily drove the tire and put around 30k miles on them before I sold the 4Runner. They wore incredibly well, were quiet, no balancing issues, and looked like new. I did the math with the wear so far and they would have gone to 70k miles.
    This a pic of them a couple of months before I sold the 4Runner with nearly 30k miles on them.
    I liked them so much, that I immediately put a set on my new Tundra...
    They are the absolutely best tire I have ran. Their snow performance is just amazing.
    After I first put them on, I put them through their paces in the snow and was so impressed, did a YouTube video of how well they did...
    kolter45 and Ripper238 like this.
  28. Mar 15, 2024 at 12:56 AM
    #148
    PVT Pablo
    PVT Pablo [OP]
    Paul
    Kitsap County, WA
    Mostly joking :D
    It doesn't appear that the Wranglers come in a 285 and standard load range, only 285/E. Which is 10 pounds more per tire (48lbs vs 58lbs) than the Mickey Thompson A/T's.
    PJSnow likes this.
  29. Mar 15, 2024 at 2:32 PM
    #149
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Didn't relies the Baja Boss didn't come in C load, it's way too heavy in E load for a daily driver 4Runner. My Duratracs are only 44lbs.
    Trail Runnah likes this.
  30. Mar 15, 2024 at 2:42 PM
    #150
    RusPro17
    Don
    Pa.
    Both 265 and 285’s both come in stand load. 285’s 4 lbs heavier. I still feel like I’m driving with 265’s.
