Mickey Thompson Baja Boss A/T Load Range
Discussion in '5th Gen 4Runners (2010-2024)' started by ForrestTh4R, Aug 14, 2023.
  1. Sep 12, 2023 at 5:19 PM
    #61
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I think XL would be fine - it's between P/SL and C from what I recall? I have P/SL because I don't hit tons of trails and the ones I do end up being light (no XL or C available in mine). If I were hardcore I'd go E.
    I think it's funny to sell any "all terrain" or "mud terrain" tire that "isn't intended for offroading" but apparently peeps will buy anything.
    There are plenty of examples of these...
    bassist[QUOTED] likes this.
  2. Sep 12, 2023 at 8:23 PM
    #62
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Meanwhile toyo has a tire 5 lbs lighter than the mickey thompson and their web banner reads
    Durability in the Shape of a Tire
    I'm only familiar with passenger tire specs until today. The LT load letters seem useless in practice, except people referencing their E load pressures. We already indirectly estimate strength from the load number. E load'rs have the highest number already.
  3. Sep 12, 2023 at 8:46 PM
    #63
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    Load numbers are based on highest rated pressure. E load rated tires typically have much high max pressures than C rated (eg 80 vs 50 psi).
    pastoreater[QUOTED] likes this.
  4. Sep 12, 2023 at 9:22 PM
    #64
    pastoreater
    Is this real? Specification derating for passenger tires? Why do C tires spec out with lower load index numbers than the dunlops? I am at my 24h limit of understanding.
  5. Sep 12, 2023 at 10:29 PM
    #65
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Want to be more conflicted? Limited trims come with 107 load rated tires stock while a big deal is made out of KO2 Cs being 112 vs. stock 113 rating on other trims.
  6. Sep 12, 2023 at 11:15 PM
    #66
    pastoreater
    That's completely normal o_O and toyota does it on their cars when they upsize the wheels, somehow mysteriously the stiffer sidewalls of the lower profile tires xyz the :p
  7. Sep 13, 2023 at 6:12 AM
    #67
    roc
    roc New Member
    Michigan
    2021 4Runner TRD ORP
    Looks to be a great tire for the 4R.
    ChessGuy likes this.
  8. Sep 13, 2023 at 7:04 AM
    #68
    Eubeenhadd
    Eubeenhadd Bit of a derp
    Indianapolis
    2005 T4R 4.7 AWD
    Spartan Locker, OME 885/895w/stiff Nitrochargers, 265/70R17 Encounter AT
    People aren't running them because they don't look cool, aren't marketed widely, and tires are expensive. My next set of tires will be 255/85R17 Baja Boss AT's or Kenda Klever 35-10.5R17's because they're the only tire in that size and I'm drawn towards AT/RT pizza cutters, marketing be damned.
    I found that my E-Rated Mastercraft Courser CXT's in 255/85R16 rode OK on a stock Tacoma with TRD OR suspension. I don't have any experience with popping tires in either SL or E ratings, and don't personally know anyone who has, but that's my experience and I'm out east where the wheeling is different. IMO, the E rating is the right path, but that's up to you. I can tell you for sure, your desired air pressures are well within what either SL or E rated tires can handle.
  9. Sep 14, 2023 at 5:51 AM
    #69
    like2lean
    like2lean New Member
    I just went Ko2 265c also, 3 days in the wet, rainy, twisty CO mountain roads and they stick like glue. Zero slipping or spinning on pavement, perfect traction in the passes climbing, and so glad I've got the extra sidewall protection! Quiet, smooth, I love em.
    kolter45 likes this.
