Method Race Wheels MRW316
Discussion in 'Wheels & Tires' started by gburd, Aug 17, 2020.
  1. May 29, 2021 at 10:49 AM
    jesqui4
    jesqui4 New Member
    2017 Toyota 4Runner SR5 4WD
    Flowmaster FlowFx, Nfab step bars, BFG K02 265/70/17
    Yes. Used factory tpms, no issues with that.
    Toy4X4 likes this.
  2. May 30, 2021 at 4:53 AM
    Same here.
  3. Nov 6, 2021 at 4:42 PM
    Dohc97
    Dohc97 New Member
    Just ordered these wheels yesterday with Conti TerrainContact AT in 265/70/17. What kind of tire pressure are you guys running with 265/70/17?
  4. Nov 7, 2021 at 3:06 AM
    275-70-17's here @ 36 psi. cold
  5. Dec 7, 2021 at 8:31 AM
    Dohc97
    Dohc97 New Member
    Hub centric means you did not have to use hub or centering rings? I have the same wheels and 3 of them came with hub rings. I am still waiting for a ring to be mailed in by Method wheels.
  6. Jan 16, 2022 at 6:53 PM
    pastorea
    pastorea New Member
    Tony
    2019 Metallic Gray SR5 Premium 4Runner
    Pedal Commander BFG KO2 265/70/17 Method 703 Matte Black 17 x 8.5 0 offset
    BFG KO2 265/70/17 on Method 703 17 x 8.5 0 offset. They guy that installed mine said that the hub rings didn’t fit but with the ET lugs there was no problem with the install. 1FCF6B82-FF39-4F5A-8C32-267C8580B8E4.jpg
  7. Mar 2, 2022 at 6:40 PM
    4X4T4R
    4X4T4R New Member
    2021 TRD ORP
    I ran 265 K02's on them with no lift for awhile. No rubbing at all. I'm on 285's with 2.5" lift in front, I had to trim about 1" off front and I get a little mudflap rub at full lock in reverse.
  8. Mar 28, 2022 at 5:33 AM
    4X4T4R
    4X4T4R New Member
    2021 TRD ORP
    Re-read my post. I stated no rubbing at all.
    I sold the 265's because I moved up to 285's.
    Yes, some rubbing with 285's.
  9. Aug 29, 2022 at 6:53 PM
    appleseed518
    appleseed518 New Member
    2015 SR5
    Gobi Rack, Rigid Lighting
    @gburd I ended up buying 316s myself after finding this thread a few weeks ago. I appreciate you posting the info! I went with the Titanium. 2B9F1850-2CC0-4A07-9F4E-F8DA57B5A99F.jpgA6F0720F-76A9-4B68-B809-C8E001675ECD.jpg8EADE1DF-B864-4515-B573-542CAA6666EB.jpg
  10. Sep 6, 2022 at 9:10 AM
    Midlife72
    Midlife72 New Member
    Looks really good against the dark blue. Bought the same titanium and I like the look/fit. I did a 2inch front lift & 1 inch back with Bilstein/toytec. Had to do slight work for rubbing but nothing major. Been thinking about rock rail/step. I see you dont have one. Thoughts?
    appleseed518 likes this.
  11. Sep 6, 2022 at 9:12 AM
    Midlife72
    Thinking i like the look without the step….will see how long my wife will jump in without protesting…
    GtownRunner likes this.
  12. Sep 6, 2022 at 9:48 AM
    appleseed518
    2015 SR5
    @Midlife72 that looks great! And yeah my wife and I are both pretty damn short and we’re going to tear the edge of the seats the way we’ve been climbing in and out. I’ve looked into a few sets of sliders, although I probably won’t push this thing hard enough to need them. I like the really flush looking 20 degree sliders but they obviously don’t work as well as
    steps. I also don’t really like the way the kick-outs look on most sliders but understand the reasoning for them.
    Just saving up for some at this point!
  13. Sep 6, 2022 at 10:06 AM
    Midlife72
    At 6 feet I can step in the drivers side fine but it is gonna cause problems for me as my daily driver. I am doing the same and looking at options for low profile with enough step I dont get the stink eye anymore. I’m not planning on crawling boulders either. Just looking to get back far enough to avoid the crowds.
  14. Sep 6, 2022 at 12:20 PM
    appleseed518
    2015 SR5
    @Midlife72 I’m right there with you on that note. Would love some updates on what you end up going with, because I’m likely going to have to order something this fall considering the lead times. Or find a used set when someone parts out.
    On a side note, your paint looks great. I detail and do paint correction on about 75 cars a year. Haven’t had the chance to get to mine yet, I’ve only had it about a month. Previous owner did okay all things considered, but theres plenty of room for improvement. Did you do yours?
  15. Sep 6, 2022 at 12:36 PM
    suaveflooder
    suaveflooder New Member
    Those are clean!!! I like them a lot
  16. Sep 6, 2022 at 4:00 PM
    Midlife72
    Thanks. It’s a 2022 limited so the paint is fairly new and I bought it as a program car with 8k miles on it. I think the paint job had a special aftermarket coating but would need to verify. It gets run through the wash every few days as well. I like a clean car…. It’s the magnetic grey and i assume its the same as other trim levels. Living in Houston the vented seats and remote start were a must thus the limited.
  17. Sep 6, 2022 at 5:38 PM
    appleseed518
    2015 SR5
    @Midlife72 in that case try to hit the touchless wash when possible. I correct vehicles all the time because of swirls from the brushed tunnel wash
  18. Mar 25, 2024 at 2:55 PM
    Wawa 4runner
    Wawa 4runner New Member
    2024 4Runner ORP
    Got mine installed today :)
    Toy4X4, jev425 and TrailSpecial22 like this.
