Metal oil filter housing
Discussion in '5th Gen 4Runners (2010-2024)' started by banjos-n-beer, Mar 31, 2022.
  1. Nov 16, 2022 at 8:48 PM
    #121
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    Im subscribed to him. I'm sure people seek him out. He's probably a great mechanic. That doesn't mean everything he says is the gospel. Read the comments on that video. You have people emptying out there oil in a panic to swap back the plastic housing because they're worried about engine failure because he said the oil filter housing is trash after the tube removal. That's ridiculous
  2. Nov 16, 2022 at 9:43 PM
    #122
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    I was less convinced by this myself. More concerned about his statement that running the shorter tube has the same effect as activating the bypass valve. That oil won't be flowing through the filter.
    I'd figured (and posted this earlier) that the bypass works by dropping the filter down so it no longer mates to the engine block, and that's how oil can then circulate back to the engine without having to pass through the filter. But he seemed to be saying that the bypass valve acts to drop the tube, and that's what allows the oil to bypass the filter. So a shorter tube accomplishes the same thing.
    I really don't know. Maybe he's wrong. But it does make me want to just go back to the OEM housing assembly. At the moment I'm running the metal one with shorter tube, cause that's what my shop installed when I broke the plastic one -- and they did not swap the tubes.
  3. Nov 16, 2022 at 9:46 PM
    #123
    Potsie
    Potsie New Member
    I'd definitely get the correct tube in it sooner than later but the metal or plastic housing are both fine
    Old Tanker likes this.
  4. Nov 16, 2022 at 10:09 PM
    #124
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Yes, you need that longer tube in there, no matter what the dealer did. If you saved your old housing take it apart and look at the mechanism. It’s really not rocket science to disassemble it then reassemble it with the longer tube. Of if you’re intent on going back to plastic disassemble the metal one and see how it all works. Take pics and let us know your impressions.
    Edit:
    Here’s a reference:
    https://trail4runner.com/2019/04/17/genuine-oem-toyota-metal-oil-filter-with-motivx-tools-wrench/
    Singleminded[QUOTED] likes this.
  5. Nov 18, 2022 at 3:40 PM
    #125
    bulldog
    bulldog New Member
    Prepping to buy New
    Ya, so can't you just take the plastic one apart, install in the metal one and be done?
    Do we know the part numbers for the valve, spring & tube for the 4R or Tacoma?
  6. Nov 18, 2022 at 4:35 PM
    #126
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    You take the tube and spring from the plastic (factory) and switch to the metal.
    kolter45 and Singleminded like this.
  7. Nov 18, 2022 at 6:31 PM
    #127
    bulldog
    bulldog New Member
    Prepping to buy New
    I have a Jowett Performance housing on the way, so that's what I'll be swapping to.
  8. Nov 18, 2022 at 7:35 PM
    #128
    4run2thehills
    4run2thehills New Member
    2021 OffRoad
    5100 Bilstein lift, BFG K02s
    BGH2023 likes this.
  9. Nov 18, 2022 at 7:55 PM
    #129
    57HotrodVW
    57HotrodVW New Member
    Eric
    '18 Cavalry Blue TRD Pro
    Yep, I wrote that article. No need to bend the tabs to swap the center tube. Just a little side pressure, and it pops right out. Reassembly is just as easy.
  10. Nov 18, 2022 at 8:16 PM
    #130
    Potsie
    Potsie New Member
    Good writeup. Bending the tabs is fine though. They're not flimsy and bend right back. I'd say they may be compromised if it's done too many times but this should be a one time deal for most people. You're also not putting any stress on the spring doing it this way it slides out clockwise without any twisting or bending sideways
  11. Nov 18, 2022 at 9:26 PM
    #131
    There's a couple of YouTube videos showing the plastic to metal housing tube swap. Both show bending the tabs to remove the tube. This is one:
    https://m.youtube.com/watch?v=9nNBAnOJbCM
    I'm guessing @57HotrodVW has figured a way to push the tube to the side at the top to avoid bending the tabs, but never having done it myself, I can't say I know for sure that's what he did.
  12. Nov 22, 2022 at 3:18 PM
    #132
    Singleminded
    OEM LED foglights
    I’m posting to validate the Car Care Nut’s concerns about aftermarket oil filter housings.
    My shop installed a Doorman a couple weeks ago when I broke my OEM plastic housing and told them I’d prefer the metal version. (I meant the Toyota metal version). The Doorman is absolute junk.
    I got a new OEM housing and decided to install it myself today because I wasn’t even certain that my shop had used the proper length stand tube.
    Well, first off, oil leaked from the Doorman’s drain valve as soon as I unscrewed the cap. Second, the gasket around the valve fell right off. Third, the drain valve would not accept the plastic drain tool, it just dribbled here and there as I tried to push it in. Fourth, the inner tube assembly fell apart when I pulled off the dirty filter. The tube popped right off the bracket, and the bracket itself had dislodged from the bottom of the housing. I’ve honestly never encountered a crappier automobile part.
    I’m happy to be back to the OEM housing, and now I have a good wrench (Motivx) I’m not worried about damaging it.
    https://youtu.be/G_vl2AYe7Yg
  13. Nov 22, 2022 at 5:24 PM
    #133
    Potsie
    Potsie New Member
    The metal toyota housing is an oem part. I wouldn't use an aftermarket housing either
    Spare Parts likes this.
  14. Nov 22, 2022 at 8:15 PM
    #134
    Singleminded
    OEM LED foglights
    Want to be clear here, for the record, that I did not ask my shop to install a Dorman or any other aftermarket part. I asked them to install the metal version from Toyota, and also to swap the tubes. When I followed up for confirmation that they'd swapped the tubes, I learned they'd used the Dorman instead. When that became clear a few days ago I decided to replace it myself with the OEM plastic one, just to be on the safe side.
    It was only when doing that replacement that I realized just how craptastic the Dorman is. I mean, was it basically functioning? Like, was oil getting filtered? I assume so. But that part clearly can't be relied on to work long term. It was in serious danger of leaking from the drain plug, and of having the tube dislodge and thus failing to perform its function. The shop said they've had a good experience with them, but then again how would they know if the thing was not actually filtering properly over 5K or 10K mile intervals? They wouldn't really.
  15. Nov 22, 2022 at 8:17 PM
    #135
    Potsie
    Potsie New Member
    It
    that's something a decent shop should've run by you before installing for sure. What year 4runner?
    2Toys likes this.
  16. Feb 3, 2023 at 2:18 PM
    #136
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    Is this metal oil filter from Toyota? It says OEM. I called my Toyota dealership service department today and they said Toyota doesn’t make a metal one for 4Runner and the advise against using one.
  17. Feb 3, 2023 at 2:20 PM
    #137
    It's from a Lexus. In the end it isn't needed and more of a feel good mod for people that can't not overtighten things.
    Klinsman55[QUOTED] likes this.
  18. Feb 3, 2023 at 2:42 PM
    #138
    Singleminded
    OEM LED foglights
    Like me :frustrated:
  19. Feb 3, 2023 at 3:24 PM
    #139
    I'm guilty as well. I forgot lefty loosy, righty tighty on the oil drain bolt for my ATV. It didn't put up much of a resistance since the housing was aluminum but replacement meant splitting the engine case.
  20. Feb 3, 2023 at 5:14 PM
    #140
    Singleminded
    OEM LED foglights
    Yikes! So sorry!
  21. Feb 4, 2023 at 7:12 AM
    #141
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    I did not bend the tabs on mine to get the tube swapped.
  22. Feb 4, 2023 at 7:13 AM
    #142
    Does the Lexus this filter housing is designed for not require the longer center tube?
  23. Feb 4, 2023 at 7:17 AM
    #143
    What was your method to remove/replace the center tube?
  24. Feb 4, 2023 at 8:25 AM
    #144
    Fisch
    Fisch New Member
    Jacksonville, Fl
    2018 TRD ORP
    Empty wallet
    Its been a few months, but I just remember being able to remove it with applying firm pressure to the tube and using a twist motion to get it out and the same to seat it into the new metal housing.
    I don’t remember which way I twisted but I was surprised I didn’t need to bend those tabs. Sorry it’s not more helpful info.
  25. Feb 4, 2023 at 8:26 AM
    #145
    It does so that’s why you swap the tube but also should probably swap the spring.
  26. Feb 4, 2023 at 8:29 AM
    #146
    No problem. You confirmed it can be done without bending the tabs, thanks.
  27. Feb 4, 2023 at 9:38 AM
    #147
    MAXIM
    MAXIM New Member
    CarCareNut is an awesome mechanic and purist on original design and parts. I'd suspect his cars have no aftermarket mods. If so, too bad and he is missing out a lot. Nothing ventured - nothing gained.
  28. Feb 4, 2023 at 9:25 PM
    #148
    Cowboy59
    Cowboy59 Enjoy the Adventure
    N. Florida
    As others have mentioned, yes get the Motivx tool.
    Below is everything I else purchased to help with oil changes
    Funnel
    https://www.amazon.com/gp/product/B016FVJUX0?ie=UTF8
    Fumoto Drain Hose - when you get it - put in boiling water for 30 - 45 seconds and the straighten. Now it will always stay straight. You can also just go to your local hardware store and get some tubing to fit the Fumoto valve.
    https://www.fumotousa.com/all-products/f-hose.html
    I drain the oil into empty milk jugs and take them to our county recycling center.
  29. Feb 4, 2023 at 11:33 PM
    #149
    tiap
    tiap New Member
    13 Black 4Runner
    FYI, in Florida, by state statute, any place that sells motor oil, MUST accept used motor oil for recycling
    That includes a grocery store, 7-11, Wawa, any parts store. You also need not to have bought the oil there.
  30. Feb 5, 2023 at 1:37 AM
    #150
    Foothills
    Foothills New Member
    Had a look at this trucks plastic filter housing today, still good at 130k miles. If I see that the ears or threads start showing wear I'll change it but will likely just get another oem plastic housing that will last another 15 years.
    Singleminded likes this.
