Metal oil filter housing
Discussion in '5th Gen 4Runners (2010-2024)' started by banjos-n-beer, Mar 31, 2022.
  1. Apr 3, 2022 at 2:10 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Yes, I feel good about being able to turn it without being concerned it’s going to break.
    ValK83, peter2772000 and ecoterragaia like this.
  2. Apr 3, 2022 at 3:24 PM
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    My first vehicle with a composite filter housing was a '07 VW GTI, and the only way to remove it was a 19 mm socket. It cracked on my second oil change because the diameter of the "nut" was less than half that of the housing.
    It's all about gearing, and I think on the 4R, Toyota did a good job with the design and requiring that the least amount of pressure be applied to the housing to remove it. I really think the composite housing will easily last the life of the vehicle.
  3. Apr 3, 2022 at 8:33 PM
    ridgeline001
    ridgeline001 New Member
    Too many….Is that a thing?
    I have used them for years on all my log trucks and every personal rig I’ve owned since I found out about them and never had an issue.
  4. Apr 3, 2022 at 8:40 PM
    ridgeline001
    On my Tacoma with full skids, I just had a hole directly below the valve. I used the one with a nipple and added a few inches of clear tube that I could tuck back up into the skid. Have the same setup to install on the 4Runner when I do the first oil change.
  5. Apr 3, 2022 at 11:16 PM
    Works fine with the right tool.
    Bgdv1 likes this.
  6. Apr 4, 2022 at 3:58 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    To each is their own, I know when I first used the brand new tool I bought from Toyota to change the oil on my Tacoma, I was concerned about the plastic, so I replaced with the metal housing and am no longer concerned.
  7. Apr 4, 2022 at 4:02 AM
    banjos-n-beer
    banjos-n-beer [OP] New Member
    Steve
    Maine
    2018 Pro
    i bought my 4Runner used. i've seen enough mention of them being damaged by incompetent techs that i figured $30 is worth it for peace of mind.
    peter2772000 likes this.
  8. Apr 4, 2022 at 4:50 AM
    Bald Michelins
    Bald Michelins New Member
    21' SR5P
    I have the metal filter housing ready to go. Just in case. If or when I need it it's on the shelf. I'll keep on with the stock housing until there is a problem. Even a spare plastic housing might not a bad thing to have sitting around.
  9. Apr 4, 2022 at 5:11 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Yeah, if the original looks to be in good shape I'll just store it in the basement.
  10. Apr 4, 2022 at 10:01 AM
    I like your thinking. Do you think a similar setup (the oil filter housing nipple that comes with a new filter and a short length of clear tubing to prevent messes when draining the filter housing) would be useful if left in the vehicle for the next oil change?
  11. Apr 6, 2022 at 4:14 PM
    ridgeline001
    I’d be interested in seeing the parts you are thinking of using. I’m only at 4K miles, so I haven’t even looked at the filter set up yet.
  12. Apr 7, 2022 at 6:53 AM
    I figure that if the oil filter package comes with a nipple to drain the filter, you could get some clear tubing to put on it to direct the oil without it just dropping straight down and splashing...
    ridgeline001[QUOTED] likes this.
  13. Apr 7, 2022 at 7:16 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    the filter element does come with the plastic nipple. i might add tubing to it when the time comes to prevent spillage. i've got a ton of extra i use with my brewing/kegging equipment.
  14. Apr 7, 2022 at 8:39 AM
    Do the non-Toyota filters, i.e. STP, also come with that drainage nipple?
  15. Apr 7, 2022 at 8:41 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    no idea. i think an OEM filter is like $10. i'll just grab one from the local toyota dealer before i do the change in the next month or so.
  16. Apr 7, 2022 at 12:41 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    ValvoMax Drain valve.
    https://www.valvomax.com/products/m...inless-drain-tube-knob?variant=33149381771373
    (To install, remove the Valvomax external rubber o-ring and dust cap tether, use a deep 24mm socket to torque at 16-18 ft-lbs. Then re-install the o-ring and tether/cap). Also, they supply a metal gasket to use instead of the typical OEM fiber one.)
    Motivx Filter drain valve.
    https://www.motivxtools.com/products/toyota-lexus-oil-filter-drain-tool?variant=16794858950
    Motivx Oil filter removal tool.
    https://www.motivxtools.com/products/toyota-2-5l-5-7l-oil-filter-wrench/?variant=15321139142
  17. Apr 7, 2022 at 1:11 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    So, do I still have to swap out the center piece from the plastic housing?
    985C0CD2-B44C-4AB0-9C75-078DAB7EB727.jpg E96B6677-6D26-4C7A-A1D5-67CB49BCBB1D.jpg
    kolter45 likes this.
  18. Apr 7, 2022 at 2:22 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Never mind. I forgot the 4Runner’s tube is taller.
    Spare Parts likes this.
  19. Apr 7, 2022 at 3:43 PM
    #49
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Yeah, not really worried about oil volume/displacement. More about structure/support for the element.
  20. Apr 7, 2022 at 3:56 PM
    #50
    ridgeline001
    So I dug out my new filter, new metal housing and a spare fumoto valve. If they make one with the correct thread size, it will work. BUT NOT WITH THE NIPPLE………….. With the nipple you would not be able to get the socket tool on to remove the housing. I’m going to do some research on the one listed above to see how it is locked closed. The lock on the fumoto and that I have used them on engines that cost as much as a new 4Runner is why I trust them so much.
  21. Apr 7, 2022 at 4:09 PM
    #51
    Spare Parts
    Southern Maine
    22 LR ORP
    You talking about putting a fumoto valve on the oil filter housing?
  22. Apr 7, 2022 at 6:08 PM
    #52
    I am wondering the same thing…
    A&P likes this.
  23. Apr 8, 2022 at 8:17 PM
    #53
    ridgeline001
    Correct
  24. Apr 8, 2022 at 9:06 PM
    #54
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  25. Apr 26, 2022 at 6:09 AM
    #55
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    @Thatbassguy @Jynarik
    When you installed the Fumoto valve did you dry fit the washer/gasket? I know to apply some oil to the o-rings for the filter housing.
    thx!
  26. Apr 26, 2022 at 7:35 AM
    #56
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Shoot, it’s been almost 3 years. Can’t say I remember
  27. Apr 26, 2022 at 7:44 AM
    #57
    Same as @Jynarik
    I'm not certain either way. Sorry.
  28. Apr 26, 2022 at 7:47 AM
    #58
    banjos-n-beer
    Steve
    Maine
    2018 Pro
  29. Apr 26, 2022 at 8:23 AM
    #59
    Brandonium
    Brandonium New Member
    I installed the Fumoto and metal filter housing this past weekend. Fumoto went on dry as it has on my other vehicles. No leaks at all.
  30. May 21, 2022 at 9:50 AM
    #60
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    I installed the Fumoto valve and metal oil filter housing a few weeks ago. Luckily no bolts had been stripped and the original plastic housing looked good. I saved the plastic housing even though I’ll probably never need it now.
    I probably didn’t need to swap out the taller center piece for the oil filter element, but did so anyway. The height difference was almost negligible.
