Max weight on top of the 5th gen?
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Nov 15, 2023.
  1. Nov 26, 2023 at 10:06 AM
    #61
    It's strapped in place. But, yeah, there's always a risk that anything you carry in the vehicle will become a projectile in a collision. Believe me; I've thought about it. At least when I have the rear seats in, the seat back should help hold it.
    OTOH, If it was on the roof, it could go flying and kill someone else.
  2. Nov 26, 2023 at 11:57 AM
    #62
    When the vehicle is still, the loads are straight down into mounts and down the structure of the body. It’s extremely strong standing still. Just like when you stand on one foot on a soda can.
    When it’s moving (dynamic), the mounts, roof body will be subjected to side to side motions. If you’ve ever had your head move hard side to side on undulating roads or terrain, that distance is a little less than the load on the roof will also have to travel. Some side to side motions are smooth, but the forces due to accelerations may result in multiples of that weight being imparted to the roof mounting area and the hardware. A mount that is strong vertically, may act as a lever and magnify bending forces on the hardware and pass-bolts that go into the roof.
    On smooth roads, there are very little additional side loads. But once you get off road, all bets are off. Dynamic loads may not damage the roof all at once, but eventually I can imagine metal fatigue leading to a failure of something.
  3. Nov 26, 2023 at 12:18 PM
    #63
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Relax, I've been wheeling for a good couple of decades. I wasn't rock crawling at that psi. It was a forest road lol.
    Green = 32 psi
    Red = 15 psi
  4. Nov 26, 2023 at 12:19 PM
    #64
    Yotaholic
    Olympia, WA
    Strapped and mounted with a metal plate.
  5. Nov 26, 2023 at 12:27 PM
    #65
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Yes sir, many man's dream, if only it wasn't 3k↑ lol
    One day
  6. Nov 26, 2023 at 12:31 PM
    #66
    I worry about that too obviously the answer is yes. But thats a gnarly crash you're not planning to have, in the big picture. I have a heavy full size 33" on steely that I don't want back underneath, or in the back cargo, and it can't fit in roof under garage lol
    Once again, we find ourselves at the glorious rear bumper tire solution
    Yotaholic[OP] likes this.
  7. Nov 26, 2023 at 2:05 PM
    #67
    Yotaholic
    Olympia, WA
    Henry J likes this.
  8. Nov 27, 2023 at 11:22 AM
    #68
    Henry J
    Sacramento Ca
    Tire swings - $1,200-$1,400
    or the one right above my post!
  9. Nov 27, 2023 at 12:06 PM
    #69
    SuedePflow
    SuedePflow New Member
    paul
    2020 TRD ORP
    Gobi Rack & ladder Custom made swing out spare tire carrier. BA4x4 front bumper w/ lightbar Warn Evo 8-2 winch w/ 200A kill switch N-Fab side steps TRD Skidplate Clearanced front bumper TRD Pro grille OEM rear black valence Wheels/suspension mods: (5) Method 703 Wheels, KO2 tires, 1.25 spacers Body mount chop Bilstein 6112 front lift, 5160 rear w/ 2" icon springs SPC upper control arms Lighting mods: Alpharex Luxx headlights Aiden James LED fog light bezel and cam relocation (7) Baja designs Squadron lights on custom mount.
    Yeah, many manufacturers only rate roof racks for the dynamic load. Static loads are often limited to the roof load capacity of the vehicle itself. I've had 200 lbs on my Gobi dynamically and ~900 lbs statically, and zero issues.
  10. Nov 27, 2023 at 1:10 PM
    #70
    Not in CAD it's not, not with BC taxes it's not lol
    To be clear I'm talking about an entire rear bumper with a tire swing and gas pan holder so like a double swing.
    +plus welding costs and such cuz many aren't installing themselves. Near $3000CAD all that considered; I've looked
  11. Nov 27, 2023 at 1:56 PM
    #71
    Henry J
    Sacramento Ca
    I think we might be using different verbiage. I don’t mean full bumper, I mean a hitch mounted swing/tire carrier.
  12. Nov 27, 2023 at 2:30 PM
    #72
    Ahh sorry brother
    Ya no I don't like those for ground clearance reasons when wheeling. Plus, I think some rattle, some don't, but if I'm gunna carry the tire I just want a tight full bumper that hold the wheel close tight to truck
