Make us laugh
Discussion in 'Off-Topic Discussion' started by The last breed, Mar 21, 2022.
  1. Apr 2, 2023 at 9:26 AM
    #241
    I just bought my 3rd battery lawnmower. They last about a year.
  2. Apr 5, 2023 at 10:06 AM
    #242
    Property tax went up forty %!
    Wait, I don’t hVe to pay taxes on my 4R.:)
  3. Apr 5, 2023 at 12:54 PM
    #243
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  4. Apr 6, 2023 at 11:44 AM
    #244
    Today is the second day in 6 months I’ve been able to breath fresh air from my neighbors burning trash.:)
  5. Apr 11, 2023 at 11:26 AM
    #245
    Shade trees E01C865F-9A3C-4F6E-8C9C-AB87ED08810E.jpg are nice?
  6. Apr 12, 2023 at 3:49 AM
    #246
    playdixie
    playdixie Missi'ppi Fella
    Jason
    Missi'ppi
    A couple years old, but being from the Magnolia State
  7. Apr 12, 2023 at 6:25 PM
    #247
    Nope, this is one of the new human-doodles.
  8. Apr 13, 2023 at 4:33 PM
    #248
    A jar of Ragu just fell off the top of frig and took out my glass top stove.
  9. Apr 13, 2023 at 4:33 PM
    #249
    One burner’s thermostat was not working anyway. I’m going with traditional metal coil burners.
  10. Apr 19, 2023 at 9:10 PM
    #250
    My AC is too cold I don’t like it.lol
    my new expansion valve is working great!
    and new compressor.
  11. Apr 21, 2023 at 3:11 PM
    #251
    What’s a dishwasher?
  12. Apr 21, 2023 at 4:59 PM
    #252
    Kennythewelder
    Kennythewelder New Member
    Kenneth
    2004 4runner
  13. Apr 22, 2023 at 2:14 PM
    #253
    "That ain't goin' nowhere"
  14. Apr 22, 2023 at 4:45 PM
    #254
    I passed a guy, I asks “ catch your limit” he says “I got one” I says “ That’s nice”.
  15. Apr 24, 2023 at 7:50 PM
    #255
    I’m so freakin itchy right now. My palms and feet are covered.lol
    I can laugh about it I thought I was getting allergic to fish.
    The little tree looking thing was under my maple and smelled almost like a hickory.
  16. Apr 26, 2023 at 7:15 PM
    #256
    Parked next to this dodge, just frickin sent it, screwed his light bar directly to front bumper
  17. May 24, 2023 at 4:46 PM
    #257
    89FC2D64-B88F-4AA1-95FF-20626D97C0DE.jpg I always wanted these when I was a kid. So I got a set for my nephew for climbing.47B09C30-9926-4729-AB99-602D3E8C733E.jpg
  18. May 24, 2023 at 5:11 PM
    #258
    Not funny I know. Atleast I didn’t get him Ninja Throwing Stars.
  19. May 24, 2023 at 5:20 PM
    #259
    Derek's funniest memes of the month
  20. Jun 5, 2023 at 5:57 PM
    #260
    How am I supposed to pay my Amazon bill?
  21. Jun 5, 2023 at 5:59 PM
    #261
    J.O.B.
    Job
    Or
    Bust
  22. Jun 6, 2023 at 4:54 AM
    #262
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    I have one and a coffee maker as well. Her name is Mrs 2018 Limited.
  23. Jun 14, 2023 at 8:33 PM
    #263
  24. Jun 17, 2023 at 7:36 AM
    #264
    My wife says she is going to sell my Camaros for five hundred bucks.
  25. Jun 17, 2023 at 8:17 AM
    #265
    HotelMedicis
    HotelMedicis No Commercial Interests
    A baby snake was crying and the mommy snake asked, "What's wrong dear?"
    The baby snake replied, "It's the snakes next door, they won't let me hiss in their pit."
    The mommy snake replied, "You don't pay any attention to the snakes next door, I knew them when they didn't have a pit to hiss in."
    2018 Limited likes this.
  26. Jun 17, 2023 at 9:08 AM
    #266
    I won my wife in a strip poker game.
    honest
  27. Jun 17, 2023 at 9:23 AM
    #267
    And my friend won his wife too there!
  28. Jun 18, 2023 at 3:10 PM
    #268
    RunningBear
    RunningBear New Member
    2023 TRD ORP, Lunar Rock, KDSS
    Note 4Runner content.
  29. Jun 18, 2023 at 4:06 PM
    #269
    Is it ok if I give her my contact info?
  30. Jun 18, 2023 at 8:16 PM
    #270
    When I croak I don’t care what happens to them.
