Make us laugh
Discussion in 'Off-Topic Discussion' started by The last breed, Mar 21, 2022.
  1. Jan 3, 2024 at 7:50 PM
    #361
    Yotaholic
    Yotaholic New Member
    Olympia, WA
  2. Jan 11, 2024 at 8:03 AM
    #362
  3. Jan 11, 2024 at 12:51 PM
    #363
    OMG a woman was driving on the wrong side of the road. I stopped. Then down the road a car was in the trees!
  4. Jan 11, 2024 at 12:52 PM
    #364
    LOL The violence!
  5. Jan 11, 2024 at 1:49 PM
    #365
    Remember that power plant they built in Pa? The govenment told them it was OK but people would go on jogs and their skin would fall off?
  6. Jan 19, 2024 at 9:53 AM
    #366
    For all those ladies out there looking for a new hair-care product? IMG_9670.jpg This has twice the conditioners in it!
  7. Jan 20, 2024 at 4:17 PM
    #367
    I finished my final OTDR testing after
    the Howard St. tunnel wreck in the Raven's parking lot for 8 dollars a hour.:)
    GO RAVENS!
  8. Jan 25, 2024 at 2:22 PM
    #368
    Im convinced all media and new movies are filmed with a cellphone? Cause Im watching 90's VHS and its bada$$!
  9. Jan 25, 2024 at 2:26 PM
    #369
    AND my neighbors are'nt burning trash? They want more wood I says OK just stop throwing dog shit and trash on it.:)
  10. Feb 5, 2024 at 5:57 PM
    #370
    Partys over Credit Card dont work!:eek:
  11. Feb 5, 2024 at 6:01 PM
    #371
    Pentangler
    Pentangler Happy Member
    XXL Shackle (just in case)
  12. Feb 5, 2024 at 6:26 PM
    #372
    Yotaholic
    Olympia, WA
    Ricphoto and BS67 like this.
  13. Feb 19, 2024 at 8:55 PM
    #373
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    for sale right now on FB in Utah, $42,000 she's all yours guys!
  14. Feb 20, 2024 at 8:32 AM
    #374
    djdaves
    djdaves New Member
    SEPA
    2015 4runner SR5
    lift, wheels, tires, stuff.....
    Its been almost 112 years and the pool on the titanic still has water in it!! #Themoreyouknow
  15. Feb 20, 2024 at 10:45 AM
    #375
    My sister had a boob job done. Doctor messed up.....made one a B cup and the other a D cup. She was pretty bummed about the outcome until she entered into a wet tshirt contest at spring break...she won both 2nd and 3rd place!!
    PhantomTweak likes this.
  16. Feb 20, 2024 at 11:32 AM
    #376
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    brownersd and BS67 like this.
  17. Feb 21, 2024 at 3:30 AM
    #377
    Rob41[QUOTED] likes this.
  18. Feb 21, 2024 at 3:56 AM
    #378
    Leonardfrann
    Leonardfrann New Member
    Frann
    TRD Off Road Premium
  19. Feb 23, 2024 at 4:53 PM
    #379
    Is fifty pre-elderly? There are some 65 year old retired marines that work out with my wife. Maybe Im just out of shape.
  20. Feb 23, 2024 at 4:55 PM
    #380
    The Major General is coming over tomorrow. I spent the day cleaning the house.
  21. Feb 23, 2024 at 5:00 PM
    #381
    Or I'ld be fishing!
  22. Feb 23, 2024 at 5:29 PM
    #382
    Dog finally woke up....After sleeping for 20 hours!
  23. Feb 23, 2024 at 8:25 PM
    #383
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
  24. Feb 23, 2024 at 8:27 PM
    #384
    bronzestar1
    BS67 likes this.
  25. Feb 23, 2024 at 8:28 PM
    #385
    bronzestar1
  26. Feb 23, 2024 at 8:29 PM
    #386
    bronzestar1
  27. Mar 4, 2024 at 8:36 AM
    #387
    We got a new speed camera in town. That thing will be destroyed.
    BS67 likes this.
  28. Mar 4, 2024 at 8:51 AM
    #388
    Guess I cant ride wheelies there anymore.
  29. Mar 25, 2024 at 7:29 PM
    #389
    Mending the Line: I cried and blew a bunch of snot out of my nose.
    The whole movie!
  30. Mar 25, 2024 at 7:38 PM
    #390
    Feakin guys at the trout pond told me the stock truck came early and I dont think it came yet, so I left, and I remember them giggling!lol
