Make us laugh
Discussion in 'Off-Topic Discussion' started by The last breed, Mar 21, 2022.
  1. Aug 14, 2023 at 4:00 PM
    #301
    Wait until the gases start coming out the vents from too much oil. O ya believe it baby. Then they say whats that film that builds up on the inside of the windshield?
  2. Aug 14, 2023 at 4:05 PM
    #302
    Oakboro, N.C
    I know have a new Monday night ritual..Keeping up on this thread!\
    Sacrifice the heater core...
  3. Aug 14, 2023 at 4:07 PM
    #303
    It’s not my fault Toyota builds such a good vehicle I don’t need them any more.
  4. Aug 14, 2023 at 4:08 PM
    #304
    Oakboro, N.C
    Does the local dealer have free donuts and coffee?
    Kinda like going to court just to kill time after retiring...
  5. Aug 14, 2023 at 4:09 PM
    #305
    Don’t say anything I take my 4R in to a different Toyota for timing belts. They are good.
    RumHamRunner73 likes this.
  6. Aug 14, 2023 at 4:12 PM
    #306
    Oakboro, N.C
    It gets old being 50 and having to find new things to do to stay busy throughout the week!
  7. Aug 14, 2023 at 4:15 PM
    #307
    Same here. My next vehicle will be a Toyota battery powered.
  8. Aug 14, 2023 at 4:17 PM
    #308
    I already have 220volt outlet in a detached garage.
  9. Aug 14, 2023 at 4:22 PM
    #309
    Oakboro, N.C
    Same here, the first need when we built our last house 5 years ago. Got that outlet covered for future growth, if needed...plus needed it for the Hobart.
    SR5 Limited likes this.
  10. Aug 14, 2023 at 4:26 PM
    #310
    Don’t forget the 90 amp breaker.
  11. Aug 18, 2023 at 10:58 AM
    #311
    Mom says the AC in these 4Runners are too cold she doesn’t like it.
  12. Aug 18, 2023 at 3:58 PM
    #312
    Gamma Ray
    2020 SR5 Barcelona Red
  13. Aug 24, 2023 at 2:27 PM
    #313
    I can’t get this snake shit smell off my hand.
  14. Aug 31, 2023 at 9:44 PM
    #314
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Funny
    pastoreater likes this.
  15. Sep 14, 2023 at 2:04 PM
    #315
    I ate a couple 1/4 pound big bite hotdogs from 7/11 yesterday. Needless to say I ruined two pair of underwear.
  16. Sep 23, 2023 at 9:44 AM
    #316
    Went and worked out at a free session in town. Tried to hit on the instructor by telling her I collect Rolexes.
  17. Sep 23, 2023 at 9:45 AM
    #317
    I almost died
  18. Sep 23, 2023 at 11:02 AM
    #318
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Now I don't care who ya are that's funny right there
  19. Sep 23, 2023 at 12:09 PM
    #319
    My favorite exercise was the pelvic thrust. I think I did well on that one.
  20. Sep 26, 2023 at 3:23 PM
    #320
    I would watch the news but, the last time I did, they just talked about everyone getting shot, and how to nibble a cookie into the state of maryland.
  21. Sep 26, 2023 at 7:09 PM
    #321
    I watched Fast X. I heard they deleted the scene where the repo man comes and takes all their shit? Too many Dodges in it for me.
  22. Sep 28, 2023 at 6:33 PM
    #322
    All work and no play makes SR5 Limited a dull boy. All work and no play makes SR5 Limited a dull boy. All work and no play makes SR5 Limited a dull boy. All work and no play makes SR5 Limited a dull boy. All work and no play makes SR5 Limited a dull boy.
  23. Sep 28, 2023 at 6:34 PM
    #323
    FN2187
    FN2187 Stormtrooper
    Earth
    Watching FMJ?
    Nope, wrong movie. Shining?
  24. Sep 28, 2023 at 6:50 PM
    #324
    Oakboro, N.C
    On the Shining here also..Wife not happy.
  25. Sep 28, 2023 at 6:56 PM
    #325
    I had to learn how to walk again after my sat workout.
  26. Sep 29, 2023 at 5:50 AM
    #326
    Ratmosphere
    Ratmosphere New Member
    Three women see a man lying on the shore of a beach and decide to approach him. The man has no arms or legs. Feeling sorry for the poor man, the British woman of the bunch goes over to him.
    "Have you ever been hugged?" The British woman asks.
    "No." The man replies, sadly. So the British woman goes down to him and hugs him. The man smiles.
    Next, the Welsh woman goes over to him and asks, "Have you ever been kissed?".
    "No" the man replies. So the Welsh woman bends over and kisses the poor man on his lips.
    Lastly, the Scottish woman goes over to the man. At this point the man is very excited, and can only imagine what this last woman will do to him.
    "Have you ever been fucked?" The Scottish woman asks.
    "No!" The man says, excitedly.
    "Well you will be when the tide comes in!"
    Ricphoto and Daddykool like this.
  27. Oct 5, 2023 at 4:12 PM
    #327
    How am I gonna pay my credit cards off?
  28. Oct 5, 2023 at 4:12 PM
    #328
    I’m going to run trim and charge a hundred a hour?
    I’m done working for $8!
  29. Oct 5, 2023 at 4:17 PM
    #329
    Air-drop me and the 4R into Ukraine with my muzzleloader?
  30. Oct 5, 2023 at 4:34 PM
    #330
    Bet $10,000 on the Commanders game tonight? I got my Native American Kill Axe out and my RG III jersey on.
