Maintenance tools...(jacks, jackstands, etc)?
Discussion in '5th Gen 4Runners (2010-2024)' started by mainerunr, May 9, 2024.
  1. Aug 1, 2024 at 2:42 PM
    Shanky
    Shanky New Member
    I weigh about 265 and am nearly 65 and as “Husky” as I am, I can still slide under the truck and complete an oil change, diff fluids, prop shaft greasing/ transmission fluid without jacking up it up. A couple of hints.
    1). I cannot use a creeper, I must be on the ground with a cruddy T-shirt.
    2). Be strategic with your inhales and exhales. I do have to exhale to clear some areas, I don’t park your body under those spots.
    3) My 4runner is not lifted, but I do have 32” tires. (255 / 75’s).
    4) Don’t panic if you feel stuck. Proper exhales and patience with get you back out.
  2. Aug 1, 2024 at 2:46 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    You are definitely bigger, older and probably taller than me. Maybe it's my severe claustrophobia.i am on stock tires.
  3. Aug 1, 2024 at 5:13 PM
    coachhomer
    coachhomer New Member
  4. Aug 7, 2024 at 3:46 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    which big red floor jack did you buy? Amazon? or where?
    I just saw this one on sale
    https://www.amazon.com/BIG-RED-TAM830003XL-Economic-Aluminum/dp/B0BFDW4Q2C
    my HF jack failed, lucky for me I was only lifting 60 pound sliders at the time,
    when I tried to lift the truck with it after it collapsed holding the slide...it was just spouting hydraulic fluid
    ColoradoTJ[QUOTED] likes this.
  5. Aug 12, 2024 at 5:57 AM
    ColoradoTJ
    ColoradoTJ I drink...and I know things. Staff Member
    Chris
    I actually purchased the 4ton version.
  6. Aug 12, 2024 at 7:46 AM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
  7. Aug 12, 2024 at 8:24 AM
    San Angelo
    San Angelo New Member
    Get the 6ton jack stands or larger. They have a larger base and higher lift ability without having to extend the arms so high.
    Using a 3ton extended all the way up is just asking to have an accident and looking to win a Darwin award.
  8. Aug 12, 2024 at 8:38 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    You can get an award for using a 3-ton jack? I'm in!
    nova likes this.
  9. Aug 12, 2024 at 9:17 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    nova likes this.
  10. Aug 13, 2024 at 6:36 PM
    T in Texas
    FEMA Region 6
    thanks, I looked at that one...
    2024 4runner is the highest, heaviest vehicle I will lift...
    I went with the 3 ton aluminum version cause it had handles and had a 30% off coupon
    It got delivered today, and box looked like it had been drug behind the truck
    I was gonna return it to Amazon, they offered 1/2 off to keep it, I opened it and checked function...
    it worked, so I kept it and after their discount, I got a big red 3 ton aluminum jack for $77
    I bought this jack stand, got it...
    then figured out it was $75 EACH...so had to buy another one
    but the ESCO jack stands look pretty good, got some smaller aluminum ones too
    https://www.amazon.com/dp/B0019JVIPM
  11. Aug 13, 2024 at 7:17 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Lmao this is an old thread but this dude said “don’t go with that Chinese shit from harbor freight” then proceeds to recommend a brand made in China.
