LTDSC Build Thread
Discussion in '4th Gen Builds (2003-2009)' started by LTDSC, Apr 6, 2014.
  1. Feb 21, 2016 at 6:44 PM
    #181
    LTDSC
    LTDSC [OP] Soccer Dad Extraordinaire
    Northern California
    Weekend Recap
    wnelax04sr5 likes this.
  2. Feb 21, 2016 at 8:14 PM
    #182
    LTDSC
    Northern California
    Heres my pictures from this weekends trip to Pismo.
    ajohnson and wnelax04sr5 like this.
  3. Mar 9, 2016 at 8:38 PM
    #183
    LTDSC
    Northern California
    Just picked up my coilovers from a rebuild. I must have been really low on nitrogen because these are a LOT higher than before with the same springs and same exact collar adjustment as before. I need to decrank a bit I'm maxed out.
    06HAOLE likes this.
  4. Mar 18, 2016 at 10:24 PM
    #184
    LTDSC
    Northern California
    Tonight I tackled my LED gauge cluster swap.
    You can see here I have two LEDs that aren't working. I attempted to fix and then ran out of PLCC-2s so I ordered more. But I need to drive so here's where I'm at until those come in.
    I'm very happy with it.
  5. Mar 19, 2016 at 4:37 AM
    #185
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Sub'd so I can keep up with your mods......
  6. Mar 25, 2016 at 5:00 PM
    #186
    LTDSC
    Northern California
    Did my steering wheel control LEDs.
  7. Mar 28, 2016 at 2:04 PM
    #187
    LTDSC
    Northern California
  8. Mar 28, 2016 at 5:59 PM
    #188
    HHIRunner
    HHIRunner New Member
    HHI, SC
    2003 V8
    When are they going on?
  9. Mar 28, 2016 at 6:06 PM
    #189
    LTDSC
    Northern California
  10. Mar 28, 2016 at 7:51 PM
    #190
    LTDSC
    Northern California
    RonT4R likes this.
  11. Mar 28, 2016 at 8:04 PM
    #191
    HHIRunner
    HHI, SC
    2003 V8
  12. Apr 2, 2016 at 4:54 PM
    #192
    LTDSC
    Northern California
    Trimmed up my cab mount some more and got rid of the sharp corner of the pinch weld. Also opened up the rear fender on the bumper cover for more clearance.
    And I washed it finally
    RonT4R likes this.
  13. Apr 3, 2016 at 5:06 AM
    #193
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
  14. May 1, 2016 at 3:26 PM
    #194
    LTDSC
    Northern California
    Had a ton of fun this weekend, found a lot of snow surprisingly.
    Coopers did great, scrubbed just a little. Real happy with my set up, we got through some deep snow and ice as well as the usual trail dirt.
    drunner likes this.
  15. May 4, 2016 at 3:09 PM
    #195
    LTDSC
    Northern California
    Finally got my rear bump stop extensions
    Instead of mounting the stock hard rubber bump stop to the bottom like most. I'm going to drill a hole in the proper location and mount a super bump like I did in the fronts. A little softer impact when I bottom out.
  16. Jun 4, 2016 at 10:01 AM
    #196
    LTDSC
    Northern California
    Bought some washers and nuts for the bump stop set up. Here's how I did it.
    HHIRunner likes this.
  17. Jun 4, 2016 at 10:53 AM
    #197
    Kelvin
    Kelvin New Member
    Bout damn time
    Been so out of the loop I didn't even know they stopped making the aluminum bump spacers
    LTDSC[OP] likes this.
  18. Jun 4, 2016 at 10:54 AM
    #198
    LTDSC
    Northern California
    This was 100% on wheelers and their ridiculous turn around time.
  19. Jun 10, 2016 at 7:28 PM
    #199
    LTDSC
    Northern California
    Installed my OEM sport hood tonight. It's unpainted but for now I'll leave it. It went on easy and fast. I need to remove the vinyl piece off the fender still. I'll do that over the weekend. It was leaving glue residue and I didn't want to deal with it tonight.
  20. Jun 15, 2016 at 6:17 PM
    #200
    LTDSC
    Northern California
    Got the scoop insert today. Just in time for the rain.
  21. Jun 15, 2016 at 7:41 PM
    #201
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Matt
    Los Angeles/Santa Barbara
    '16 4Runner SR5 4x4
    Looks killer man. I miss the hood scoop. I want one on my rig.
  22. Jul 11, 2016 at 11:32 AM
    #202
    LTDSC
    Northern California
    Look what has arrived
  23. Jul 12, 2016 at 3:21 PM
    #203
    SixthSnail
    Matt
    '16 4Runner SR5 4x4
    That was quick. When is install?
  24. Jul 12, 2016 at 3:22 PM
    #204
    LTDSC
    Northern California
    took them two weeks lol
    Saturday install!
    SixthSnail[QUOTED] likes this.
  25. Jul 16, 2016 at 5:42 PM
    #205
    LTDSC
    Northern California
    Installed them today.
    Greased and placed the bushings, had to clean out the PC on the zerk hole threads but they went in. Had to grind off my steering stops on the lower OEM mount so they wouldn't destroy the LCA. Torqued the uniball and ready for install.
  26. Jul 20, 2016 at 3:38 PM
    #206
    LTDSC
    Northern California
    My bump stop bolts came in today. I love when you order a "custom" bolt and they're actually correct!
  27. Jul 21, 2016 at 6:37 PM
    #207
    LTDSC
    Northern California
    Got home and installed these and checked the torque on everything. The lower uniball wasn't loose at all after 400 miles so that's good to see.
    Bump extension is 1" it looks like a ton but it's no different than before, the arms are just angled more so the bump location is lower. TC includes a machined bump stop extension at just under 1" but the bolt on the super bumps doesn't work with it. So I made my own extensions from UMHW and a 3" hole saw. Came out great I think. I ended up using the M10x1.25x60 bolts in place of the x70 I ordered as well.
  28. Aug 8, 2016 at 8:13 AM
    #208
    LTDSC
    Northern California
    Some of you know i went to Pismo this past weekend. Here's a few pics from my travels. Along with my blown coilover. Which is being taken to be rebuilt tonight.
  29. Aug 8, 2016 at 8:14 AM
    #209
    LTDSC
    Northern California
    Had to remove my washer bottle reservoir because I finally wore a hole in it in pismo and dumped all my fluid. So much more room now. Need to find a small square reservoir and see if I can put behind the headlight under the hood.
  30. Aug 8, 2016 at 8:15 AM
    #210
    LTDSC
    Northern California
    While I had my Icons rebuilt because they blew AGAIN in pismo I purchased some King 2.5 extended travel resi coilovers. King sent the wrong resi mounts so they're still zip tied for now.
