LTDSC Build Thread
Discussion in '4th Gen Builds (2003-2009)' started by LTDSC, Apr 6, 2014.
  1. Oct 20, 2014 at 3:15 PM
    #121
    Emelianenkov
    Emelianenkov New Member Vendor
    Alex
    Andover, MA
    2005 V6 Sport Salsa Red Pearl
    I gave up on restraining my rear axle. I just decided to cut off whatever rubs
  2. Jan 5, 2015 at 5:42 PM
    #122
    LTDSC
    LTDSC [OP] Soccer Dad Extraordinaire
    Northern California
    Time for a face lift for my front end.
    Utah likes this.
  3. Aug 16, 2015 at 2:25 PM
    #123
    LTDSC
    Northern California
    got the fenders on. Meant to do the headlights but i need her bulbs for just about everything so i need to do some research on the bulbs and wire in the proper plugs. Fenders fit great, only had to sand one area and the lines are pretty damn good.
    New HID bulbs and these gems came in today. Now I can finally swap over to my 06 headlights
    Got my headlights in. I'm really shocked and disappointed Toyota has the 1156 bulb at the blinker. I remember those from my 68 cougar. Like seriously Toyota? Anyway I love the look of the 06 headlights. The blinker in the light and I love the way the lower filler piece actually clips in!
    I also cranked the front an inch.
    Paint next weekend!
    I pick it up today
  4. Aug 16, 2015 at 2:27 PM
    #124
    LTDSC
    Northern California
    Purchased the long travel progressive rate rear springs. Should be a LOT softer in the rear.
    Also got LT rear link bars which are also double the thickness of OEM so will be a ton beefier.
    Swapped out the rear springs today. I noticed they had a driver side specific spring so that helps with the lean. Hopefully i wont need a spacer to adjust.
    The swap was extremely easy. Basically as soon as the shocks came off the axle drooped enough to dump the old springs. Ride seems a lot softer on large bumps, ill see how it breaks in. It also dropped 3/4" in the rear
  5. Aug 16, 2015 at 2:28 PM
    #125
    LTDSC
    Northern California
    Walked out Sunday morning to see this...
    I went and talked to the body shop, they're going to repair it but they want me to make wheel liners first so a rock wont hit it again and damage it.
    My plan for "custom" liners are get a thinner piece of sheet metal, like a 4x4 sheet and get longer L brackets and mimic the wheel arch from the wheel tub and bring it up to be hidden and then trace the arch on the inner fender. From there ill mount the L brackets and then mark holes on the sheet metal to attach it. It should be strong enough to deflect any rocks and also be hidden from view. Ill be making it this weekend as they want the fenders next week.
    Today's project was to create a fender liner that will protect the fiberglass for once these are fixed and to prevent this in the future.
    Took a trip up to the mountains this weekend and went and explored. My GoPro got turned on during the drive so it was dead and i forgot my cord :fp: So i just have a few pics
    went and explored about 150 miles of logging roads and found a bunch of hidden lakes and relaxed. Was a great trip and the 4runner handled everything like a champ. These rear springs definitely a huge improvement, around 25mph on washboard roads it smooths completely out and glides across the dirt. Was a lot of fun, the 4runner is absolutely disgustingly dirty.
  6. Aug 16, 2015 at 2:29 PM
    #126
    LTDSC
    Northern California
    Installed my lower links this morning in under an hour. Really easy install, high quality products.
    Against stock links
    Installed
    Next up is lengthening my rear sway links to even it out and get the upper links as well.
    Qty 1. Energy Suspension kit (Part #9.8121R) which I got off Amazon.
    McMaster-Carr
    Qty 1. ASTM A193 Grade B7 Alloy Steel Threaded Rod, Plain Finish, 3/8"-24 Thread, 2' Length; Part number 98957A805
    Qty 2. Steel Ball Joint Rod End, 3/8"-24 Right-Hand Female Shank, 3/8" Ball ID, 13/16" L Thread; Part number 60645K341
    Qty 2. Zinc-Plated Steel Washer for Ball Joint Rod End, Fits 3/8" Shank Size; Part number 95034A300
    Lowes
    Qty 2. Grade 8 3/8" 2" length bolts
    Qty 2. Grade 8 3/8"-24 Thread nylock nuts
    Qty 2. Grade 8 3/8"-16 Thread nylock nuts
    Qty 2. Packs of 3/8" grade 8 washers
    Qty 2. 3/8x1/2x1-1/2" Steel Spacer
    Red Loctite
    Pre Assembly
    Stock comparison
    Sleeves for the stock sway bar to protect the threads of the new bolts.
    The overall Eyelet to frame mount should be 6 1/2" so instead of cutting the bushing like others have, i cut the sleeve down a hair. The heims add about an inch if not a little less so you'll need to do one or the other. I refused to cut a perfectly new bushing.
    Measurement for what length you want the sleeve to be
    All combined, back at 6 1/2" like desired.
    Installed (notice its now parallel to the lower link. Definitely an improvement from the OEM link angle.
    Very easy installation and build, i highly recommend them. Im only in this about $40.
    44357 likes this.
  7. Aug 16, 2015 at 2:30 PM
    #127
    LTDSC
    Northern California
    went up to the mountains this past weekend, wheeled a bit. Suspension is perfect, theres parts where i was 60mph+ and it was smooth as glass offroad. Very impressed. Now i just want to strap the front and add a better bump stop up front.
    [video=vimeo;132767351]http://vimeo.com/132767351[/video]
  8. Aug 16, 2015 at 2:31 PM
    #128
    LTDSC
    Northern California
    Started building a box today. To fit comfortably within the side of my cargo area. I've had the 8" in factory location which I explained and showed in the beginning of my build. It was time to move on to bigger and better but still not take up a lot of space because I use my cargo area almost daily.
    I got half way through this before I decided I should take pics so this is all I have.
    Tomorrow I'm going to carpet it to match existing tan carpet. Also going to close off the box a bit, take the cubic feet down a touch as the sub only needs 0.80 (minimum)and its sitting around 1.25 right now. Maximum is 3.0
    Finished up today. Very happy with how it turned out. I closed off the box to 0.90 cubic feet for optimal sound. Carpeted it up and fully secured it. I'm happy with it.
    I put a cover on it to protect it from moving cargo.
  9. Aug 16, 2015 at 6:29 PM
    #129
    HHIRunner
    HHIRunner New Member
    HHI, SC
    2003 V8
    I think you might be taller than me now
  10. Aug 16, 2015 at 9:41 PM
    #130
    LTDSC
    Northern California
    Maybe, but you still look way bigger.
    Ill be going up to 285/75/17s eventually which will raise me a bit.
  11. Aug 17, 2015 at 9:23 AM
    #131
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    Not going real wide?
  12. Aug 17, 2015 at 9:26 AM
    #132
    LTDSC
    Northern California
    theres really no tires available that i like in a 305/315 and 33/12.5s are too damn heavy.
  13. Aug 17, 2015 at 3:40 PM
    #133
    HHIRunner
    HHI, SC
    2003 V8
    What tires do you want?
  14. Aug 17, 2015 at 3:42 PM
    #134
    LTDSC
    Northern California
    preferably my Toyo AT2s again but in extreme tread. I like the Toyo RT's but they're 13lbs heavier than my AT2s EACH TIRE.
  15. Dec 2, 2015 at 11:00 AM
    #135
    LTDSC
    Northern California
    Installed new hubs/bearings as well as new CV axles. It got rid of my vibration an upgraded my equipment so no big loss.
    Recently got stock spindles as a spare set. I'm going to gusset and paint those then install. Will greatly improve strength.
    ajohnson likes this.
  16. Dec 2, 2015 at 4:17 PM
    #136
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    87 4Runner SAS and other stuffs, 07 Tacoma
    Things and stuff and such
    Have you reinforced your LCA cam tabs?
  17. Dec 2, 2015 at 5:56 PM
    #137
    LTDSC
    Northern California
    Not yet I haven't. It's on the list for sure.
  18. Dec 3, 2015 at 4:55 AM
    #138
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    They bend pretty easy. Some dumbass tech bent one on my Taco during my last alignment :annoyed:. I think I'm just gonna cut the one off and weld some 1/4" in place, and weld the back side on the others.
    LTDSC[QUOTED][OP] likes this.
  19. Dec 7, 2015 at 3:28 PM
    #139
    LTDSC
    Northern California
    These things are beef
  20. Dec 8, 2015 at 12:19 PM
    #140
    wnelax04sr5
    Ethan
    CT
    every damn time i go on your build, i get about two words in and then its like "TIME TO LOAD PHOTOS"
  21. Dec 8, 2015 at 12:21 PM
    #141
    LTDSC
    Northern California
    hahaha im waiting for it to skip to the next page.
  22. Dec 8, 2015 at 1:05 PM
    #142
    wnelax04sr5
    Ethan
    CT
    ill reply again and move you one step closer
  23. Dec 8, 2015 at 1:23 PM
    #143
    LTDSC
    Northern California
    spindles and gussets are getting dropped off at CaliFab Saturday.
  24. Dec 12, 2015 at 5:11 PM
    #144
    LTDSC
    Northern California
    Califab hooked it up and spit these out quick today. Now I need to find time to install.
  25. Dec 12, 2015 at 8:11 PM
    #145
    wnelax04sr5
    Ethan
    CT
    i don't know whats more impressive, the beads on your spindles or paint when it rains
    LTDSC[OP] likes this.
  26. Dec 19, 2015 at 3:37 PM
    #146
    LTDSC
    Northern California
  27. Dec 19, 2015 at 3:46 PM
    #147
    HHIRunner
    HHI, SC
    2003 V8
    I wish I had those spindle gussets today, think I may have bent mine a bit
  28. Dec 19, 2015 at 3:59 PM
    #148
    LTDSC
    Northern California
    I was shocked I hadn't bent mine yet to be honest
  29. Dec 19, 2015 at 4:03 PM
    #149
    HHIRunner
    HHI, SC
    2003 V8
    Came down hard after using skinny pedal to get over a big obstacle and hasn't felt right since.
  30. Dec 19, 2015 at 4:16 PM
    #150
    LTDSC
    Northern California
    Didn't just funk up your alignment?
