looking for tire suggestions to replace the OEM junk tires.
Discussion in '5th Gen 4Runners (2010-2024)' started by Dave97, Jan 5, 2025.
  1. Jan 7, 2025 at 10:14 AM
    #61
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    E load is way too heavy for our 4Runners, and a Michelin E load just sounds wrong. lol People can get away with it but i would avoided if you mostly do highway. Definitely a great load for off road only IMO.
  2. Jan 7, 2025 at 10:27 AM
    #62
    Scarif_1
    Scarif_1 New Member
    Oakland
    2020 TRD ORP
    I’ve been happy with my Toyo RT Trails. Excellent off road and quieter than the KO2s I had before. They balance better and are wearing evenly w/ my rotations so far. Any concerns I had w/ rain performance was totally unfounded having been hit a few storms in the area. They were bought specifically for an off road trip so I may dial things down w/ their AT3s next. Or not.
  3. Jan 7, 2025 at 10:28 AM
    #63
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Many manufacturers claim virtually no weight difference between C and E load ranges. Nitto Ridge Grappler for instance claims the E rated 285/70/17 is actually a pound lighter than the same tire in a C load rating. When I contacted them about this they said it was due to the way the plies are laid out in tire.
    They also said sidewall deformation makes a big difference though so I'd agree that E load range is likely overkill for a stock 4Runner... but not because of tire weight.
    Once you add a few hundred pounds of armor/ constant weight E load makes much more sense. C load range will flex a lot when fully loaded. Even during on road driving.
    Ripper238[QUOTED] likes this.
  4. Jan 7, 2025 at 10:29 AM
    #64
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    But we can still get into the weeds of deciding between trying to find some old stock of KO2s, or going with the untested KO3s.
    I also saw Yokohama Geolander AT's weren't mentioned, but it sounds like OP might snub them like the Defenders (effective tire, but doesn't have a wow factor).
    4Hopper[QUOTED] likes this.
  5. Jan 7, 2025 at 10:40 AM
    #65
    1SilverRunner
    Tejas
    This guy did an interesting experiment with some lightweight 35s. One thing he found was his particular rig was too heavy for his C Load AT3's. Too much tire deflection in this particular case. Although I'm sure this is sort of an outlier situation since this is a very heavy rig on a very lightweight C load 35" tire.
    https://www.youtube.com/watch?v=tPc9Hsq4DF8
  6. Jan 7, 2025 at 10:42 AM
    #66
    Acesandeights
    Acesandeights #34
    2024 ORP
    Per OP, 100% street and gravel. Super Swampers?
    BC Hunter, Spare Parts and bassist like this.
  7. Jan 7, 2025 at 10:55 AM
    #67
    TejasRunner
    TejasRunner New Member
    2024 4Runner Off-road Premium
    Unfortunately Michelin discontinued the C load. Really strange.
  8. Jan 7, 2025 at 11:37 AM
    #68
    You guys can debate this until you’re blue in the face, but I’m sticking with my E load tires. After 46k miles, they’ve been quiet, comfortable and knock on wood, I haven’t had a tire failure with many off road excursions over sharp basalt rocks.
    In contrast, I’ve been through nine P-series tires on my Sequoia in the last two years, all street use.
    1SilverRunner, Ksny15 and TejasRunner like this.
  9. Jan 7, 2025 at 12:03 PM
    #69
    The Shandong 3000s are my favorite. :D
  10. Jan 7, 2025 at 12:09 PM
    #70
    Imdav2u
    23 TRD PRO
    I thought you were kidding until I googled it.
  11. Jan 7, 2025 at 12:09 PM
    #71
    It’s too bad that there’s not an objective measurement or rating for sidewall cut resistance. We like to pretend that load rating correlates to cut resistance but it really doesn’t.
  12. Jan 7, 2025 at 12:39 PM
    #72
    Schlappesepple
    2020 ORP
    Can we submit requests for Tinkerer experiments? This seems up his alley.
    BC Hunter and Spare Parts like this.
  13. Jan 7, 2025 at 3:03 PM
    #73
    4Hopper
    4Hopper New Member
    24 Ice Cap 4R TRDOR Prem
    Good news is that they’re real tires. Bad news is that I think they may dissolve in water, so, dry pavement only…
  14. Jan 7, 2025 at 3:50 PM
    #74
    Acesandeights
    Acesandeights #34
    2024 ORP
    Is someone debating your experience with someone else?
  15. Jan 7, 2025 at 6:42 PM
    #75
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    I think the OP is the only one who can call the winner for this tire battle.
    4Hopper[QUOTED] and Slopemaster like this.
  16. Jan 7, 2025 at 7:42 PM
    #76
    Makavelli
    Makavelli New Member
    2024 4Runner V6
    I have Kumho Road Venture AT52 275/70/17 load E and zero issues. Very nice riding tire compared to the stock tires.
  17. Jan 7, 2025 at 8:06 PM
    #77
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    and... in comes the Kumho... forgot about that one
    I'm trying to think of another tire to recommend... :playball::playball::playball:
  18. Jan 7, 2025 at 8:22 PM
    #78
    Imdav2u
    23 TRD PRO
    Nice looking tires. How do they fit, trimming, lift kit, mpg drop?
  19. Jan 7, 2025 at 8:27 PM
    #79
    This has the potential for being another epic tire thread. "In this corner, weighing in at a fighting weight of 49 lbs..." Can you call it a corner if the "ring" has 32 sides...?
    Makavelli likes this.
  20. Jan 7, 2025 at 10:03 PM
    #80
    Has anyone mentioned General Grabbers yet?
  21. Jan 8, 2025 at 1:54 AM
    #81
    Matt83
    Matt83 New Member
    Northeast
    Michelin LTX AT2
  22. Jan 8, 2025 at 3:21 AM
    #82
    TejasRunner
    Definitely my fave. Only available in E load now.
  23. Jan 8, 2025 at 5:18 AM
    #83
    Makavelli
    2024 4Runner V6
    I have Eibach Pro Truck Coilovers 2R so idk how they would fit on OEM suspension.
    also mpg loss, yes being a lot heavier the mpg dropped but then again, I didn’t buy a 4Runner for mpg bought for being so capable and reliable.
