Lionel trains....
Discussion in 'Off-Topic Discussion' started by SR5 Limited, Dec 28, 2018.
  1. Oct 29, 2023 at 7:10 PM
    #121
    SR5 Limited [OP] New Member
  2. Oct 29, 2023 at 8:29 PM
    #122
    Powhatan Arrow!
  3. Oct 29, 2023 at 8:33 PM
    #123
  4. Oct 29, 2023 at 8:56 PM
    #124
    This is the only “J” Class engine left. There were people stopped on all the roads we passed filming and waving!IMG_9464.jpg
  5. Oct 30, 2023 at 2:40 PM
    #125
  6. Oct 30, 2023 at 3:54 PM
    #126
  7. Jul 13, 2024 at 1:13 PM
    #127
    Im going to beat on this Hudson! IMG_0502.jpgIts already run. Its from 1997. Has a broke rail no biggy.
  8. Jul 13, 2024 at 2:15 PM
    #128
  9. Jul 13, 2024 at 4:06 PM
    #129
    I got a great price! The newer ones have alot of stuff I cant access without the remote control.IMG_0504.jpg
  10. Jul 15, 2024 at 4:14 PM
    #130
  11. Jul 16, 2024 at 11:21 AM
    #131
    Im attempting to run 5 trains at once. My Challenger Marine Corps train is 11 1/2 feet long cars are from the fifties. My Standard gauge 400e is pulling 10 feet of 1920's cars. I already had a derailment no damage.
    djwantke likes this.
  12. Jul 17, 2024 at 10:26 AM
    #132
    The new Hudson has already gone up in value. I got it for $400. First car is a wooden flat with two IMG_0517.jpg Sherman Tanks! Its pulling 12 cars.
  13. Jul 17, 2024 at 10:43 AM
    #133
    IMG_0519.jpg My tracks are 24 feet and I engineered the radius inside one another.
  14. Jul 17, 2024 at 11:41 AM
    #134
  15. Aug 2, 2024 at 6:19 PM
    #135
  16. Aug 9, 2024 at 4:35 PM
    #136
  17. Aug 9, 2024 at 4:41 PM
    #137
    Extending my 20th Century Limited set with this old 24 inch car. Should track on my 50 inch wide curves. IMG_0637.jpg
  18. Aug 9, 2024 at 4:43 PM
    #138
    They have cameras mounted now its called "Vista Vision".
  19. Aug 9, 2024 at 6:45 PM
    #139
    All the good people of the world. Riding a modern form of transportation. To work, ugh.IMG_0638.jpg
  20. Aug 9, 2024 at 6:50 PM
    #140
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Funniest thing I’ve seen all day. That is funny. There’s 5 more pages of thread!? :p
  21. Aug 9, 2024 at 7:01 PM
    #141
  22. Aug 9, 2024 at 7:02 PM
    #142
  23. Aug 9, 2024 at 7:03 PM
    #143
  24. Aug 10, 2024 at 10:11 AM
    #144
    :eek: May be possessed. I cant find any info on the 24" car. Im thinking pre-war when they started molding plastics, or better wood.
  25. Aug 11, 2024 at 7:05 PM
    #145
    Found some info: Walthers wood kit that you build, sand, and paint. This is what the kit consists of.IMG_0653.jpg
  26. Aug 11, 2024 at 9:40 PM
    #146
    Check out these track layouts. This is from a 1946 Walthers catalog.IMG_0656.jpg
  27. Aug 14, 2024 at 12:26 PM
    #147
  28. Aug 14, 2024 at 1:40 PM
    #148
  29. Aug 15, 2024 at 12:53 PM
    #149
  30. Aug 15, 2024 at 1:05 PM
    #150
