Light bar wiring help
Discussion in '5th Gen 4Runners (2010-2024)' started by Xombie2000, Nov 15, 2021.
  1. Nov 17, 2021 at 4:23 PM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    So if the blue relay wire is the positive trigger wire for the relay that is going to terminal 85 on the relay block that is the only wire that will connect to your switch (Red 1) from the relay (and possibly the only wire needed to go through the firewall into the cab depending on your positive source connection point). The green wire on the switch will connect to a 3 amp fused positive source to power the relay coil. The black wire on the switch would go to a chassis ground point inside the cab, the last switch wire RED 2 for the backlighting is sort of optional. The switch will light up when engaged without RED 2 connected it but at night the switch writing will not be lit unless RED 2 is connected to a dimmer switch controlled dash lighting circuit.
  2. Nov 17, 2021 at 5:41 PM
    Xombie2000
    Xombie2000 [OP] New Member
    2016 4RUNNER trail
    Haven’t gotten a chance to put my volt meter on it yet however here is the old switch. B6CB49F1-AC2C-4904-9A00-A34236D979DA.jpg
  3. Nov 18, 2021 at 4:32 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    2FA800AC-69C1-435B-B777-10D0E566A90B.jpg I had my bajadesigns light bar wired up to on board switch.
    Xombie2000[OP] likes this.
  4. Nov 18, 2021 at 7:26 PM
    Xombie2000
    2016 4RUNNER trail
    That’s the switch I bought.
    RusPro17[QUOTED] likes this.
  5. Nov 18, 2021 at 8:55 PM
    DRH
    Dave
    Santa Clarita, Ca
    2020 ORP
    Move the inverter switch down to the empty blank below (wires reach) and you will have three empty slots in a row for new switches.
  6. Nov 19, 2021 at 4:41 AM
    So, the light bar didn't come with a wiring diagram?
    If I recall correctly, our dash lights are either switched negative, or operate at a different voltage than the light bar switch. This makes it difficult to have the switch light up with the dash lights.
    The switch will still light up when the light bar is on without the dash light input. I capped it off in mine.
    Do you have a picture of the wire leads coming off the relay?
  7. Nov 19, 2021 at 5:12 AM
    Xombie2000
    2016 4RUNNER trail
    I can take one. Do you want a picture inside the cab or at the relay?
  8. Nov 19, 2021 at 5:40 AM
    I replied before I noticed the diagram in post #19. I believe @ElectroBoy has you squared away.
  9. Nov 19, 2021 at 5:49 AM
    Xombie2000
    2016 4RUNNER trail
    Thank you.
  10. Nov 19, 2021 at 7:28 PM
    Xombie2000
    2016 4RUNNER trail
    I got it working.
  11. Nov 19, 2021 at 9:21 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Please provide a description of how you did it to help the next person who wants to do this. Thx.
  12. Nov 19, 2021 at 11:08 PM
    Xombie2000
    2016 4RUNNER trail
    • Black to black
    • Green to red
    • Red1 to blue
    • Red2 to fuse box
