Let's talk about Viper Cuts!
Discussion in '5th Gen 4Runners (2010-2024)' started by Borracho Loco, Jan 1, 2025.
  1. Jan 1, 2025 at 6:53 PM
    mac1usa
    mac1usa New Member
    If you went through with Viper cut would you have remaining issues in these areas? Are these areas damaged also from the accident or maybe it’s just the pic I am seeing?
    Thacrow likes this.
  2. Jan 2, 2025 at 3:46 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    My experience begs to differ!
    I have scuffs right where a viper cut would be that weren’t due to some large rock.
  3. Jan 2, 2025 at 3:48 AM
    bassist
    bassist New Member
    If you pay cash, you can get that fixed for $500, maybe less - at least for what is clearly visible.
  4. Jan 2, 2025 at 6:06 AM
    Borracho Loco [OP] My 4Runner identifies as a Prius!
    Thanks. I'll give that some thought too. I'm weighing all my options right now, and I'm in no rush to get it fixed.
    bassist[QUOTED] likes this.
  5. Jan 2, 2025 at 6:34 AM
    tk421
    Tyler
    DFW Texas
    2023 Limited 4Runner
    What is that thing in the circle under the hood?
  6. Jan 2, 2025 at 6:36 AM
    mac1usa
    mac1usa New Member
    If you live close to Shortys I would take a drive down there just to bs and get some ideas. I wish I had someone like him up here.
  7. Jan 2, 2025 at 6:59 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Klein Tools magnetic bt speaker
    :rockband:
    tk421[QUOTED] likes this.
  8. Jan 2, 2025 at 7:54 AM
    andrewtheadventurer
    Hates a little rub that can be painted over but willing to unforgivably cut half the bumper off .. hmmm
    hossler1788 likes this.
  9. Jan 2, 2025 at 9:54 AM
    vthoky New Member
    Suggestions from out here in the sticks:
    1. Put a Band-Aid over it and enjoy the laughs.
    2. Consider going to one of the wrap shops and finding a vinyl that matches the color and have it wrapped?
    Man, I'd be scared to death to cut into that. ;^)
  10. Jan 2, 2025 at 10:01 AM
    It is scary AF indeed!
  11. Jan 2, 2025 at 10:14 AM
    java
    java fauxrunner
    2023 ORP ice cap
    Viper Cut does not look good without a lift imo. I have one with no lift.
  12. Jan 2, 2025 at 10:23 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I'd agree with this.
    Without some big tires and offset to match it looks funky.
    A viper cut is a compromise. A compromise of aero and water intrusion in favor of clearance for your tire and clearance for obstacles.
    When I see stockish rigs with high viper cuts... Well it's not a look I'd go for.
    McSpazatron likes this.
  13. Jan 2, 2025 at 10:28 AM
    1SilverRunner
    Tejas
    Here’s mine for reference.
    On 34s with -38 offset
    Mild viper cut... maybe garden snake cut? lol
    -38 offset required this. It does help with obstacles though.
    Harringbr99 likes this.
  14. Jan 2, 2025 at 10:38 AM
    You've all made some great points and suggestions.
    I'm going to rule out a viper cut for my ride. Because for my use case, it's not only unnecessary, but it would look weird (dumb). That also means adding a full steel bumper is out. Again, I don't have a lift or larger tires, so slapping a big, and very heavy bumper on would seem....well, dumb.
    My ride is purely a pavement princess and it crawls really hard at the mall. It's definitely the toughest and coolest looking ride on my street and in my company's parking garage.
    I thought the idea from @vthoky was pretty funny, and I may do that.....until I decide to pay out of pocket to get it fixed/repaired correctly and put back to stock. This is why I love this site. I had an idea that I thought would be awesome, but after getting some feedback (positive & negative) I realized my idea was terrible. I usually have terrible ideas on Wednesdays so I'm not that shocked.
    Harringbr99, NE Runner, Saker and 5 others like this.
  15. Jan 2, 2025 at 10:50 AM
    I have terrible ideas every day.
    1SilverRunner likes this.
  16. Jan 2, 2025 at 11:01 AM
    1SilverRunner
    Tejas
    I'm glad the forum talked some sense into you. That damage is not bad. Get some touch up paint.
    When you start wheeling and need some 35's hmu and we'll cut up your rig!:headbang:
    Harringbr99 and djwantke like this.
  17. Jan 2, 2025 at 11:53 AM
    35's are for rookies. When I upgrade, I'm gonna get 37's or even 40's. This is Texas, son. Go big or go home.
    NE Runner and Saker like this.
  18. Jan 2, 2025 at 12:05 PM
    1SilverRunner
    Tejas
    Sure. ;)
  19. Jan 2, 2025 at 12:07 PM
    #49
    Oakboro, N.C
    Would that be the Cobra cut?
  20. Jan 2, 2025 at 12:08 PM
    #50
    1SilverRunner
    Tejas
  21. Jan 2, 2025 at 1:17 PM
    #51
    LOL
    This dude is one of the largest 5th gens I’ve seen in canada so far
    original_3e5c1423-1ac0-4f0b-8c23-5e236814d9dc_Screenshot_20230815-200043_Original.jpg
  22. Jan 2, 2025 at 1:32 PM
    #52
    Photon_Chaser 48576 and counting…
    Roger
    Sierra Nevada Mountains
    I’m not against the high clearance look but everyone I see one I can’t help seeing this…
    Don’t get me wrong, I appreciate the purpose behind high clearance mods it’s just that I don’t see myself running class 4 and above trails anytime (I do enjoy watching others run em!)
  23. Jan 2, 2025 at 1:58 PM
    #53
    Another option is to just remove the front bumper and fenders all together.
    djwantke, java and RumHamRunner73 like this.
  24. Jan 2, 2025 at 2:07 PM
    #54
    Oakboro, N.C
    I get it Baja 500 Vibes..
  25. Jan 2, 2025 at 2:14 PM
    #55
  26. Jan 2, 2025 at 2:33 PM
    #56
    Actually, I was being sarcastic. If I encountered an obstacle that required trimming the front bumper, then I would simply drive around it. But I get it, driving around an obstacle doesn’t have the same cool factor. ;)
  27. Jan 2, 2025 at 2:41 PM
    #57
    Saker New Member
    21 Black T4RORP
    I came to the same conclusion when thinking about a "garden snake cut" on mine!
  28. Jan 3, 2025 at 10:46 AM
    #58
    tk421
    Tyler
    DFW Texas
    My issue was the stupid Limited trim. The roads where I go trucking in the summer are too narrow, the rocks sometimes too big, or the angle too much to go around them.
  29. Jan 3, 2025 at 10:49 AM
    #59
    1SilverRunner
    Tejas
    There isn't always an option to go around. :stirthepot:
  30. Jan 7, 2025 at 2:55 PM
    #60
    I had my bumper repaired (paid out of pocket). The before/after picture. I think the guy did a great job, plus he came to my work.
