Led headlight and fogs
Discussion in '5th Gen 4Runners (2010-2024)' started by titan34, Dec 28, 2016.
  1. Dec 30, 2016 at 1:04 PM
    titan34
    titan34 [OP] New Member
    Hawaii
    Thank you!..I really appreciate you helping me out with this!
  2. Dec 30, 2016 at 1:17 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    No problem man, here's what it looks like removed so you can get an idea of how to pull.
    Vernsstar likes this.
  3. Dec 30, 2016 at 1:41 PM
    titan34
    Hawaii
    Cool..I was not sure how to take it out or if it was screwed down. I'm known for breaking things..lol
  4. Jan 1, 2017 at 10:48 PM
    titan34
    Hawaii
    I installed the fogs. I can see that it does not fit flush but its fine..It does look better then the stock fogs. I was not sure if I insert those 2 brackets where the inner brackets of the stock fogs uses.. It did fit but not fully so I did not insert it in there. Hope I installed it correctly.lol
  5. Jan 1, 2017 at 11:15 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Are you talking about the two little arms opposite of the arms you screw down? Those are supposed to slide into slots.
  6. Jan 1, 2017 at 11:27 PM
    titan34
    Hawaii
    Yeah..It has a hard time fitting into those slots..Seems like it does not fit right..but I will try tomorrow..
  7. Jan 2, 2017 at 7:17 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    It will take a little bit of muscle but they'll go in.
  8. Jan 2, 2017 at 3:13 PM
    titan34
    Hawaii
    I adjusted them and put the fogs into the stock slots. Here are some pics
    fastBoat likes this.
  9. Jan 2, 2017 at 3:25 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Nice looks good! Especially on a black 4Runner. See what I mean about the gap? It doesn't look out of place at all.
  10. Jan 2, 2017 at 3:39 PM
    titan34
    Hawaii
    Thanks man!.. I see it. It looks fine. I like the look of these over the stock fogs. I really appreciate your help! I should get my xd hids tomorriow. I hope the install goes much more smoother then the fogs..lol..I probably will be here making sure I did things right. I dont use the relays right?
  11. Jan 2, 2017 at 3:58 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    The HID's are super easy. Its all plug and play, and the relays are not used. The only "hard" part is drilling the dust cap. I used silicone sealant on the wiring going through the dust cap to make sure nothing would get in.
  12. Jan 2, 2017 at 4:00 PM
    titan34
    Hawaii
    Cool...I will get some silcone sealant
  13. Jan 4, 2017 at 2:00 PM
    titan34
    Hawaii
    Got my xd hid kit..How do you know the bulb is 5000k? I guess when its turned on. Just want to make sure .
  14. Jan 4, 2017 at 2:53 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Mine werent labeled either.
  15. Jan 4, 2017 at 3:14 PM
    titan34
    Hawaii
    Ok..I guess I have wait and see when I put them in..lol.
  16. Jan 4, 2017 at 3:39 PM
    titan34
    Hawaii
    Does the 5000k give a crisp white? You notice any blue hue?
  17. Jan 4, 2017 at 4:48 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    There is a noticeable blue hue on startup, and the most faint hint of blue warmed up. They should pretty much be white after about 60 seconds.
  18. Jan 4, 2017 at 5:58 PM
    titan34
    Hawaii
    Nice..
  19. Jan 4, 2017 at 5:59 PM
    #49
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    You get em' installed yet?
  20. Jan 4, 2017 at 6:08 PM
    #50
    titan34
    Hawaii
    Either tomorrow or Saturday I will install them. Did you use the 3mm tape that the ballasts came with?
  21. Jan 4, 2017 at 6:24 PM
    #51
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Yep, I mounted the ballasts under the plastic thats on each side of the engine bay.
  22. Jan 4, 2017 at 6:39 PM
    #52
    Dark Knight
    Dark Knight Get off my lawn
  23. Jan 4, 2017 at 6:40 PM
    #53
    titan34
    Hawaii
    I might have to adjust my fogs a little. I need it to shine more ahead. on the road. I cant really see it .
  24. Jan 4, 2017 at 6:41 PM
    #54
    titan34
    Hawaii
    Very nice install! I was thinking of doing the same
  25. Jan 4, 2017 at 6:56 PM
    #55
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Nice that's exactly what I did.
    I had to adjust my fogs slightly up.
  26. Jan 5, 2017 at 11:55 AM
    #56
    Jason73
    Jason73 New Member
    Jason
    2021 4Runner TRD
    Question about LED foglight bulbs. The stock halogens are 19w. However, most of the replacement LEDs on ebay and other sites are 50w or 80w. Will it cause any harm to switch to a greater wattage bulb since it is a LED???
    Thanks
    #56
  27. Jan 5, 2017 at 3:54 PM
    #57
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Don't bother with Ebay LED's. Get yourself some Morimoto XB's for 130.
    #57
  28. Jan 5, 2017 at 5:09 PM
    #58
    Jason73
    Jason73 New Member
    Jason
    2021 4Runner TRD
    Thanks for the suggestion, but I just want to switch for a LED bulb for about $30.
    #58
  29. Jan 5, 2017 at 6:00 PM
    #59
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Well they're going to have horrible light output and glare. So you're throwing away 30 bucks, on a $40k vehicle.
  30. Jan 5, 2017 at 6:26 PM
    #60
    Jason73
    Jason73 New Member
    Jason
    2021 4Runner TRD
    Thanks for ur opinion.
    Anyways, back to my original question. Would the higher watt LED bulb harm the existing system running the 19watt factory halogen bulb?
