LED DRL for 2021 TRD Pro
Discussion in '5th Gen 4Runners (2010-2024)' started by bomtest, Jun 18, 2021.
  1. Nov 18, 2021 at 10:21 AM
    lunar_t4r
    lunar_t4r New Member
    2022 Lunar Rock ORP
    the '21 Pro/Limited and all '22 models are bi-LED projectors, so it only serves as a DRL with no highbeam functionality. for older models, it's prob worth looking into higher end bulbs.
  2. Nov 18, 2021 at 10:27 AM
    matoolie
    Michael
    2021 Lunar Pro
    For 2021 Pros and Limiteds, and now all 2022 models….the halogen bulb is DRL only, no longer high beam as on previous years. As a result, these bulbs are low cost and do the job. I agree, I would not recommend these bulbs for high beam function. I have XD bulbs in my ‘14 that have much better performance, but much more expensive. But for those of us with mentioned models where the halogens are DRL only, these bulbs are just fine.
    Harringbr99 likes this.
  3. Nov 18, 2021 at 12:08 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Good point. I forgot about that. My '21 has the halogen high beam / DRL and I've replaced them with HIR bulbs. Nice little upgrade.
    Amazon.com: ACDelco GM Original Equipment HIR1 High Beam Headlight Bulb : Automotive
    matoolie[QUOTED] likes this.
  4. Nov 18, 2021 at 9:31 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    Now, if only we knew how to make these halogens work as high beams again… does anyone know how to do that?
  5. Nov 19, 2021 at 6:09 AM
    Leeland111
    Leeland111 New Member
  6. Nov 19, 2021 at 6:34 AM
    They are best for those who have DRL & Highbeam on same bulb. Best as DRL mode but not as bright as similar priced ones as a highbeam.
    But for 2021 Pro / Limited where the halogen bulb is just a DRL these are not worth the money IMO.
    I have them on my 2019 and happy with it for its DRL function;
    https://youtu.be/7W3I3PP0QT8
    Pasr519 likes this.
  7. Dec 6, 2021 at 10:06 AM
    j4unner
    j4unner shootz brah..
    j4runner
    nCal
    21 SR5P
    I replaced my 2021 4R DRL w/ LEDs. went with lasfit brand all around for LED swap interior and exterior (brake, reverse, signal and switchbacks)..
    no issues at all and no relay needed. lasfit are all built in with relay..
    LASTLY I did put in the DRL LEDs and they did not turn on.. what I read is that you have to take the e-brake off and put the car in drive to activate the DRL..put it back in park and you're good.. hope this helps..
  8. Dec 6, 2021 at 1:27 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    You must mean “no resistors needed”
    j4unner[QUOTED] likes this.
  9. Dec 6, 2021 at 2:05 PM
    j4unner
    j4runner
    nCal
    21 SR5P
    right on ..
  10. Dec 30, 2021 at 5:30 PM
    peaceloveandtattoos
    peaceloveandtattoos New Member
    ‘22 Army Green ORP
    Trd pro skid plate, roof rack, wheels, tires and lift, predator tubes
    Man, I wish I was super comfortable messing with my new Runner like you guys lol.
    Just took delivery last night, I asked the dealership today about a LED DRL add on and all they had for me was a whole new headlight at $1080 a pop lol.
    Anyone in az wanna come do this mod for me?!
    Hahahaha seriously though, if anyone has any recommendations for a good shop that could do this for less than a million bucks, I would be so appreciative!
  11. Dec 30, 2021 at 5:47 PM
    Keirik
    Keirik New Member
    Keith
    21 Pro Lunar Rock
    YouTube a few videos first. It’s really not too bad. Patience and YouTube. :)
  12. Dec 30, 2021 at 5:56 PM
    I don't know if 2022 ORP got low and high beam in projector housing or the bulb in reflector act as both DRL and Highbeam?
    If the 9005 bulb in reflector act as both DRL and Highbeam you can swap with a good LED bulb with DRL driver like Xenon Depot LED.
    If the 9005 bulb in reflector act as just DRL may be buy something cheap from Amazon like mentioned on Page1 of this thread.
  13. Dec 30, 2021 at 6:01 PM
    peaceloveandtattoos
    ‘22 Army Green ORP
    I’m not sure either. I’ll do more research. Thanks
  14. Dec 30, 2021 at 6:10 PM
    Turn on High beams and see if the bulb in reflector is on or not. If it is on with High beam that mean its used as both highbeam and DRL.
  15. Dec 30, 2021 at 6:17 PM
    peaceloveandtattoos
    ‘22 Army Green ORP
    Looks like the same bulb for both high beams and normal headlights
  16. Dec 30, 2021 at 6:21 PM
    peaceloveandtattoos
    ‘22 Army Green ORP
    First pic is normal headlights, 2nd is brights
    8DCEC31D-3EB1-4BFE-A814-49E401F67EDF.jpg F4CF9B19-A09B-4151-A133-F219C1AE1449.jpg
  17. Dec 30, 2021 at 6:21 PM
  18. Dec 30, 2021 at 6:32 PM
    peaceloveandtattoos
    ‘22 Army Green ORP
  19. Dec 31, 2021 at 8:51 AM
    #49
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    For those models that have LED projector high and low beams, the halogen DRL bulbs are wired in series so they get 1/2 of the voltage. It seems that Auxbeam bulb @bomtest used is functioning at that lower 6 - 7 volts, but it’s probably struggling, hence the slight flickering you notice.
    The proper way to do it is to wire each bulb to get the full battery voltage and use LED bulbs that are designed for a dimmer DRL output. Using a simple modified sub-harness and Diode Dynamics H7 HP48 bulbs.
    This is described in the other forum that was mentioned in a previous post by @Emmantik:
    peaceloveandtattoos likes this.
  20. Jan 1, 2022 at 1:25 PM
    #50
    RAE129
    RAE129 New Member
    NYC
    2021 Super White 4Runner Venture
    I installed 10th G (aka 10th GEN) Fanless 9005/9006/H10 60W LED on my 2021 4Runner Venture and have had good success with them. They do not not flicker at the lower voltage when the DRL are on and are bright when the high beams are on. Had them on my 2008 Subaru WRX STi and they worked well, so I installed them on the new 4Runner.
    If you do order these make sure to tighten the two set screws, set 180 degrees apart from each other prior to the install into the headlamp housing.
    I believe they also have a 2 Year Manufacturer's Warranty.
    j4unner likes this.
  21. Jan 3, 2022 at 1:04 PM
    #51
    peaceloveandtattoos
    ‘22 Army Green ORP
  22. Jan 4, 2022 at 7:12 PM
    #52
    Burnt Taco
    Tucson, AZ
    '22 ORP, Wife's 2020 SR5
    What LED bulbs did you use for the DRL?
    Thanks.
  23. Jan 4, 2022 at 7:15 PM
    #53
    peaceloveandtattoos
    ‘22 Army Green ORP
    The ones linked on page one. $20ish on Amazon. i will say they are much more dim than I was hoping but they are just DRL so it’s ok. They are very white which I like.
  24. Jan 4, 2022 at 7:30 PM
    #54
    Burnt Taco
    Tucson, AZ
    Thanks. Of course I want a bit brighter and thinking Amber.
  25. Jan 26, 2022 at 3:26 PM
    #55
    T4Rrunning
    T4Rrunning New Member
    Just got around to ordering mine and installing them. I am happy and for the price you can’t beat them.
  26. Jan 29, 2022 at 8:42 AM
    #56
    RACEPACE
    RACEPACE New Member
    Bellingham, WA
    2022 4Runner SR5 4x4
    Has anyone done the Amazon auxbeam led's in amber and have pictures of it?
    j4unner likes this.
  27. Jan 29, 2022 at 9:54 AM
    #57
    Mowerman
    Mowerman New Member
    David
    2020 limited 4Runner
    I think this is a pic from another thread where I saw someone’s truck that has the amber. Could be wrong though lol
    RACEPACE and j4unner like this.
  28. Jan 29, 2022 at 9:57 AM
    #58
    j4unner
    j4runner
    nCal
    21 SR5P
    thanks for sharing! that's what I want amber LED DRL.. I've seen the Auxbeam amber.. feedback on that brand seem good from what I read. If anything, I will put back in my lasfits LED for my DRL.
    I think my all black 4R with amber DRL and possibly amber rap lights would look pretty sick.. maybe it's the SF Giants fan in me, lol..
    RACEPACE and Mowerman[QUOTED] like this.
  29. Jan 29, 2022 at 4:09 PM
    #59
    Mowerman
    Mowerman New Member
    David
    Dumb question and need a little help. Ordered these lights for dtrl. ‘21 limited. Low and hi same bulb. There is a 4 pin female harness that plugs into the male harness but am I missing a tab on the bottom to access the bulb? Any help greatly appreciated. This is what I’m working with
  30. Jan 29, 2022 at 4:18 PM
    #60
    T4Rrunning
    Here you go. This should help I believe it is also a limited model.
    https://youtu.be/iMNfvdGbntM
    Cobra715 likes this.
