Larger tire size
Discussion in '5th Gen 4Runners (2010-2024)' started by Rockriv223, Oct 24, 2021.
  1. Oct 30, 2021 at 4:27 AM
    #61
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    :rofl:
  2. Oct 30, 2021 at 6:25 PM
    #62
    Xombie2000
    Xombie2000 New Member
    2016 4RUNNER trail
    Good site.
    captrussia253 and Thatbassguy like this.
  3. Oct 31, 2021 at 8:21 PM
    #63
    That's a good website! I've used it for researching and comparing tires, and they have a nice tire pressure calculator for those running a different size or load range than stock.
  4. Oct 31, 2021 at 8:39 PM
    #64
    captrussia253
    captrussia253 New Member
    Ruslan
    This is awesome! Thanks
    Xombie2000[QUOTED] likes this.
  5. Nov 8, 2021 at 5:27 PM
    #65
    captrussia253
    Ruslan
    Ok I got a dilemma.
    The Yokohama MT G003 still have not been delivered. Discount tire said they’d give me the cooper stt pro in 315/70r17 and match the same low price as the yokos. So $400 off the set.
    What do I do? Wait for the Yokohamas or get the coopers?
  6. Nov 8, 2021 at 5:44 PM
    #66
    I hear those are fantastic off-road, but pretty noisy on pavement. I wouldn't want them for a daily driver, personally.
    Are you re-geared?
  7. Nov 8, 2021 at 5:53 PM
    #67
    captrussia253
    Ruslan
    Noise doesn’t bother me. Father in law had the coopers on his Ram and they took a beating. They’re also 3 lbs lighter. But I Yokohamas show up tomorrow I can decide either one for the same price.
    Got a quote from nitro for 4.88s. I’m seeing how the V8 handles the 35s before I commit to a regear, but I’m sure I’ll do it anyways.
  8. Nov 8, 2021 at 6:13 PM
    #68
    Oh, I forgot you're putting them on the GX. based on my experience with 33.5's and the 4.0, you might be fine. I'm looking forward to pics and your review of the tires!
  9. Nov 8, 2021 at 7:24 PM
    #69
    captrussia253
    Ruslan
    35s!!! :spending:
  10. Nov 8, 2021 at 7:41 PM
    #70
    GrantA
    North Carolina
    I wouldn’t say it is about how the engine can handle it as much as the entire drivetrain. Imagine putting a 200lb guy on a kids bike. The gears are going to have a lot of stress.
    I bet a transmission would cost just as much as an engine. Idk what gears you have in there now but heck if you do regear you might as well get front and rear lockers with your regear. I can attest it is nice not having to deal with Toyota lockers and just push a button and boom they are on (ARB for the win).
    Check this out:
    https://www.4wheelparts.com/the-dirt/a-guide-to-gearing/amp/
  11. Nov 8, 2021 at 8:09 PM
    #71
    captrussia253
    Ruslan
    I know a few GX owners running 35s on stock gears without issues and they wheel hard.
    With that said I totally agree with there being more stress on the drivetrain. I will regear for sure but that won’t be right away. I want to see how it handles without it. I tow a trailer and carry a lot of gear (2 and 6 year old haha) so regearing to 4.88s is a must.
  12. Nov 8, 2021 at 8:10 PM
    #72
    GrantA
    North Carolina
    Yeah that is what I have. Probably too much but I am usually loaded down. According to the article 4.88 seems good.
    captrussia253[QUOTED] likes this.
  13. Nov 8, 2021 at 8:11 PM
    #73
    captrussia253
    Ruslan
    Ya 4.56 brings the gears back to stock ratio with 35s for the GX460. But with the weight of the tires plus all the gear I want to step up to 4.88 per nitro recommendation
  14. Nov 9, 2021 at 3:45 AM
    #74
    I get all of that. But, it depends on how you use and drive you vehicle as well. If I towed heavy or often, I would surely be in more of a hurry to regear. I also don't drive aggressively (usually).
    If I was doing 35's with the 4.0, I would certainly regear.
    It's weird that they put a lower geared differential in the GX. My gearing would be almost corrected to stock if I switched to GX gears with these 295's.
    Part of the reason I'm not in a rush to regear is that there don't seem to be options for a 4.10, which I think would be ideal for my setup. I would prefer to use ECGS, and I only see 4.56 and 4.88's on their website. It really seems like a 4.10 would be ideal for folks who are running 285's and maybe a little extra weight.
  15. Nov 9, 2021 at 3:55 AM
    #75
    GrantA
    North Carolina
    It is true. If you have a pavement princess that doesn’t go off-roading, doesn’t tow anything, and just gets you back and forth to work you are “probably” fine. But I would not recommend going off-roading, towing much, or adding a ton of weight with stock gears. Then I would argue I wouldn’t make any modifications at all. Leave it stock tire size or maybe go a tiny bit bigger (surely not 35”) because the wear and tear on other components (suspension, brakes, power steering, etc) will suffer.
    At any rate I am looking forward to seeing the ride when you are done. When are you getting the 35’s @captrussia253?
    brownersd likes this.
  16. Nov 9, 2021 at 4:23 AM
    #76
    Pavement Princess, lol!
    I probably off-road as much or more than most folks here. Full armor, sliders, a few hundred LBS of constant weight. I'm closing in on 70K miles, 40K with mods. No signs of any issues yet.
    295's are only ~6% larger than stock. The 4runner was built to tow and haul. Everything is engineered for a little extra stress.
    An article explaining why I MUST regear, written by a company that sells parts to regear might be a bit biased. Just my thoughts.
    I'm not trying to say people shouldn't regear. Especially folks who beat on their vehicles.
    But, I'm pretty sure that my drivetrain can handle tires that are a little bigger than stock. I'm willing to bet there are numerous 4runner owners who have run 285's on stock gears long term without any issues. If it were a real problem, there would be threads here about failures.
  17. Nov 9, 2021 at 6:34 AM
    #77
    captrussia253
    Ruslan
    Just go 4.56 in case you bump up to 34-35s haha
  18. Nov 9, 2021 at 6:34 AM
    #78
    captrussia253
    Ruslan
    Hopefully today.
  19. Nov 9, 2021 at 6:59 AM
    #79
    That's what I'd probably do. I want to go 35" for my next set of MT's, but still run 285's in Winter. So, I would prefer to find something that's a good compromise.
    :woot:
  20. Nov 9, 2021 at 7:18 AM
    #80
    Mtbpsych
    Mtbpsych New Member
    I see old toyotas all the time on a stock 22re power train with 35”+ tires screaming across town. I think my rig will be okay with oversized tires (to a point):rofl:
  21. Nov 9, 2021 at 7:43 AM
    #81
    captrussia253
    Ruslan
    I just talked to a buddy that has a 1st gen 4runner running 35s and a 80s toyota pickup on 37s. But then again those things were built bulletproof back in the day
  22. Nov 9, 2021 at 1:22 PM
    #82
    captrussia253
    Ruslan
    Well after over two weeks of waiting Discount Tire called to say fedex has "lost" my Yokohamas...
    With that said they offered 315/70r17 stt pros and matched the yokos price! Getting them on tomorrow morning!!!
    Time to save up for a re-gear hahaha
    #82
    GrantA likes this.
  23. Nov 9, 2021 at 7:33 PM
    #83
    Oof! Hope the Coopers work out.
    #83
  24. Nov 9, 2021 at 7:55 PM
    #84
    captrussia253
    Ruslan
    If they magically show up tomorrow I have a choice between the two which would be nice to see them next to each other.
  25. Nov 10, 2021 at 4:38 AM
    #85
    GrantA
    North Carolina
    Ouch… looking forward to seeing some pics.
    #85
  26. Nov 10, 2021 at 7:44 AM
    #86
    captrussia253
    Ruslan
    Yall ready for this one? haha got a text this morning from fedex saying that tires were found and will be delivered today to discount!!! I'll get a chance to put them next to the coopers and compare before I make my decision. What a wild turn of events :rofl:
  27. Nov 10, 2021 at 4:18 PM
    #87
    captrussia253
    Ruslan
    And the 35x12.50r17 Yokohamas are on!!! Had to remove rear mud flaps and trim another 1” of plastic.
  28. Nov 10, 2021 at 4:49 PM
    #88
    :yes:
    Looks NICE!
    How do you like them so far?
  29. Nov 10, 2021 at 4:53 PM
    #89
    captrussia253
    Ruslan
    Ya pumped they both showed up at the same time to compare.
    So far feels just like the 33s power wise but haven’t been up crazy hills. I do feel like I sit 10’ higher haha.
  30. Nov 10, 2021 at 6:43 PM
    #90
    captrussia253
    Ruslan
    Just drove around town and the acceleration is nice with the V8. Still plan to regear with 4.88s for sure.
