KDSS existing or new owners BEWARE!
Discussion in '5th Gen 4Runners (2010-2024)' started by ColinClive, Jan 8, 2020.
  1. Mar 16, 2023 at 7:09 AM
    #211
    modcat
    modcat New Member
    I realize I'm late to this party, but I had exactly the same issue as the OP here, 2015 Trail premium, 85k, KDSS light on, $9k repair in 2023. Warranty refused to cover it, too rusty. This should be included in the regular maintenance of vehicles fitted with KDSS! Bottom line, they service and check everything else. I am pretty mad. I do not believe that owners should be responsible for taking off covers on the undercarriage and cleaning it. Some people yes, will do it, but on the whole the owner should not be responsible for it. This problem has completely destroyed the value of the truck.
    5six, Late Life Crisis and kmeeg like this.
  2. Mar 16, 2023 at 8:07 AM
    #212
    I doubt Toyota will warranty it. Even if its not rust and started leaking from the rams it will be treated as normal wear and tear and its another hydraulic system like suspension same as they don't cover XREAS. Only difference KDSS is working only under 12mph (if I'm not mistaken), so less duty cycle vs suspension work all the time. If I'm not mistaken if its just leaking from rams it was relatively cost same as high-end suspension job, I think it was $1800 for the part.
  3. Mar 16, 2023 at 8:48 AM
    #213
    Late Life Crisis
    Late Life Crisis New Member
    2023 Luna rock 4runner
    none yet
    and where are the actuator connections?
  4. Mar 16, 2023 at 10:11 AM
    #214
    STrooper
    STrooper Let’s Go Places!
    Is it better to apply "fluid-film" to prevent the corrosion that some people may have? It may also help with the cleaning process for next time as well.
  5. Mar 16, 2023 at 10:26 AM
    #215
    I haven't done this, but I could definitely see the benefit.
  6. Mar 16, 2023 at 10:40 AM
    #216
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    I think it’s reasonable for a vehicle that is routinely and solely serviced at a dealership for its lifespan to have them service this part. But, if a dealer can say to me “we need to change your oil pan because whoever you got your oil change with cross threaded the drain plug”, and tried to get me to shell out $500 when they had serviced my Venza for last 3 years, then I doubt this will ever happen. Some places just can’t be trusted, which really infuriates me.
    Frizzle77 likes this.
  7. Mar 16, 2023 at 1:44 PM
    #217
    Matt83
    Matt83 New Member
    Northeast
    I just pulled the skid off my KDSS valve block, 2019 with 40,000 miles. I have religiously pulled it twice per year and applied Fluid Film and now Wool Wax. My truck lives in Maine so it sees salt/sand and plenty of dirt roads. The unit was dirty with grime from the last Wool Wax treatment but it wipes up clean and there is zero corrosion. So spraying it with an undercoating wont keep it clean but it will prevent corrosion issues for sure.
  8. Mar 16, 2023 at 4:09 PM
    #218
    airup12
    airup12 New Member
    No issues with mine. I wash it regularly and used surface shield. Same as above. There’s grime but it wipes away with no rust. I spray it twice a year. Once after winter and then before winter months. Live in the Midwest where the salt during the winter.
    I have RSG shield. It does not prevent dirt from getting in but is better protection than OEM.
  9. Mar 16, 2023 at 8:11 PM
    #219
    lrizzo
    lrizzo New Member
    Northern New Jersey
    Just out of curiosity did you go through with the repair? If so, was the entire system replaced for the $9k? I’d assume both hydraulic rams, accumulator, and all lines were replaced?
  10. Mar 17, 2023 at 6:18 AM
    #220
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    I totally agree with you. There is no reason why removal and clean up of these important components can't be part of regular servicing in regions where severe service occurs. Toyota just doesn't get it, I guess. Not everyone has the wherewithal or inclination to roll around under their vehicle and perform this important maintenance. And, I can't believe that the whole system failed! Wow, the chances of everything needing replacement at exactly the same time must be the ultimate in planned obsolescence engineering, lol. I'd definitely get another opinion from another dealer, and then just replace the parts that need replacing. Good Luck, modcat.
  11. Mar 17, 2023 at 7:00 AM
    #221
    Is the rust only on the KDSS system? Or, is the entire frame rusting?
    I agree that there should at least be a note in the manual about maintaining the accumulator. Many failures seem to be caused by debris building up in the accumulator skid causing corrosion.
    Overall, I think it's a brilliant concept. But, it certainly could have been executed better. I believe the next version will eliminate some of the hydraulics, so hopefully it will be less likely to fail.
  12. Mar 17, 2023 at 7:24 AM
    #222
    modcat
    modcat New Member
    Exactly! I don't know if it is the whole system, it could just be the actuator but dealerships always operate that way, replace everything. I have an appointment with my local 4x4 shop and see what he thinks can be done.
  13. Mar 17, 2023 at 7:29 AM
    #223
    modcat
    modcat New Member
    images from the shop
  14. Mar 17, 2023 at 7:31 AM
    #224
    modcat
    modcat New Member
    I did not go through with the repair, seeking other opinions.
  15. Mar 17, 2023 at 8:56 AM
    #225
    Yuck! It looks like the frame rail is pretty rusty also.
    How is the rest of the underbody?
  16. Mar 17, 2023 at 2:51 PM
    #226
    STrooper
    I just saw the picture above and....
    RapidRunners likes this.
  17. Mar 17, 2023 at 5:15 PM
    #227
    modcat
    modcat New Member
    Not good. I'll get a pic sometime
  18. Mar 17, 2023 at 5:17 PM
    #228
    modcat
    modcat New Member
    Apparently all the dirt accumulated in the skid plate is full of hydraulic oil. i asked them if they cleaned they said they didn't want to take off the cover thinking they might break the bolts. I would think they would at least try to clean it out. So this means the actuator is leaking a lot of fluid.
  19. Mar 17, 2023 at 5:57 PM
    #229
    Damn. I'm sorry to hear that. I think if mine were that far gone, I'd delete everything and take slower turns. You could try rinsing it out with a hose, but it seems pointless as the damage is done.
  20. Mar 17, 2023 at 5:59 PM
    #230
    modcat
    modcat New Member
    Although the warning light is on and the system is severely compromised it still drives fine, still handles well with no body roll.
  21. Mar 17, 2023 at 6:01 PM
    #231
    That's good, then. Keep us posted if you decide to get any more quotes.
  22. Mar 17, 2023 at 9:52 PM
    #232
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    Would anyone know if XREAS might have similar problem. If I am not mistaken there is also some kind of reservoir underneath. Anyone would have any idea where under the truck?
  23. Mar 17, 2023 at 10:16 PM
    #233
    XREAS Is similar only in that it is hydraulic. The 4 shocks are all linked by hydraulic lines. This system can be removed and replaced by aftermarket shocks, with no dash light to show up once it is removed. Most replace it if it leaks.
  24. Mar 28, 2023 at 4:28 AM
    #234
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2023 4Runner TRD Off Road Premium
    ADD W1 Oil Catch Can. AFE Magnum FLOW Pro DRY S Air Filter. ARK Splash Guards. Baxter Performance TK-501-BK Oil Filter Adapter. Canvasback Back Hatch. Differential Breather Relocation. Diode Dynamics SS3 SAE Yellow Pro Fog Lights. Dongar Industries Adapter. DRL Mod Harness. Garmin Mini 2 Dashcam. Garmin Overlander. Bulletpoint RubiGrid Dash Mount. Overland Torque Tune. RokBlokz Mud Flaps. SAIS FIlter Mod. Stahlbus Oil Drain Plug. Yokohama Geolandar A/T4 G018 LT265/70R-17. Yota Xpedetion Pro Grille. Yota Xpedetion Valances.
    Just found this thread. Talk about good timing. Just took delivery on a 4R with KDSS.
  25. Mar 28, 2023 at 4:52 AM
    #235
    Nice!
    Congratulations on your new vehicle! Hopefully, with some maintenance, you'll never have to deal with the problems that some people have run into.
    Hilborn[QUOTED] likes this.
  26. Mar 28, 2023 at 4:59 AM
    #236
    Hilborn
    Michael
    Utah
    Thankfully I am no stranger to frame maintenance due to having a 2nd gen Tacoma aswell.
  27. Mar 29, 2023 at 5:40 PM
    #237
    toyotahenry
    toyotahenry New Member
    the rock rail was physically in the way of the KDSS cover?
  28. Mar 29, 2023 at 5:43 PM
    #238
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Yeah, unless you modify it (I haven’t done this, but good idea) you need to loosen the rock rails to fully remove the cover. There just isn’t enough clearance to slide it out of its hole otherwise, as the little wings hang up as the kdss skid runs into the rock rail on the other side.
  29. Mar 29, 2023 at 5:45 PM
    #239
    toyotahenry
    anyone on here have a problem free KDSS and high odometer reading on their 4Runner??
    5thGin likes this.
  30. Mar 29, 2023 at 7:54 PM
    #240
    Not really high yet, but 95K on my '19, and so far no problems. I've definitely been putting it through its paces, too.
