Jacks
Discussion in '5th Gen 4Runners (2010-2024)' started by 2021venture, Jun 6, 2023.
  1. Jun 11, 2023 at 6:24 PM
    #61
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Don’t get me wrong, I find my hi-lift super useful.
    Pulling a rotten fence post & cement.
    Pulling fence pillars plumb
    TrueTexas and ecoterragaia like this.
  2. Jun 11, 2023 at 7:43 PM
    #62
    Henry J
    Sacramento Ca
    Nooooooooooooooooooo
    I did use it on the trail this weekend and hot damn did it get the job done!
    2020 4Runner[QUOTED] likes this.
  3. Jul 1, 2023 at 2:30 PM
    #63
    Cityredneck
    Cityredneck New Member
    2005 RWD 4.0 & '97 4WD 3.4
    Any service jack recommendations? The ones I found @ harbour freight were all too short for my 4th gen SR5.
  4. Jul 2, 2023 at 7:49 AM
    #64
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Harbor freight has some tall jacks that lift 23-1/8 in. How tall is your 4Runner lift? lol
    Cityredneck[QUOTED] likes this.
  5. Jul 2, 2023 at 12:12 PM
    #65
    Cityredneck
    Ok, I'll have to go check again, I could only find 13", which was too short. No lift even, but still couldn't get the jack in a spot that would get the tire high enough to remove. Ty.
  6. Jul 2, 2023 at 12:59 PM
    #66
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    Here's the one I have: I don't off-road, but I've used it many times for pulling posts (game changer for that purpose), and other things like holding up downed trees for cutting when I can't get under them with the chainsaw.
    My dad uses his for putting chains on his tractor so he can plow the driveway in winter. Guy's almost 78 and can manage it pretty well.
  7. Jul 3, 2023 at 10:23 AM
    #67
    Ripper238
    2019 TRD OR
    This will be very safe and high enough:
  8. Jul 3, 2023 at 10:40 AM
    #68
    Has anybody tried these out? I really like the idea.
  9. Jul 3, 2023 at 11:30 AM
    #69
    PJSnow
    PJSnow Always Learning
    PJ
    New York
    2018 Cavalry Blue TRD Pro
    That's what I use (but I think mine is the 6,000lb version?). They work as intended and give that extra sense of security being a 2-in-1 design. I borrowed one from a friend and used the set to install my lift kit.
  10. Jul 3, 2023 at 12:46 PM
    #70
    backpacker
    backpacker New Member
    2023 TRD ORP
    Those look interesting. Many years ago, when I was nursing unreliable cars, my garage had a jack, a stand, and chocks for every corner (plus a floor lift). Vehicles have gotten heavier since then, so I need to replace a few of them.
    On a side note, I thought it might be worthwhile to dry-run a tire change with the OEM jack. I'm glad I did. Getting the jack out under duress would have been exasperating without knowing beforehand that you have to give it about 5-10 twists by hand to free it from its bracket. The bracket design is an interesting way to keep the jack from rattling around in regular use, but I don't like obstacles when I have a tire to change.
  11. Jul 3, 2023 at 2:19 PM
    #71
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    I have the 3 ton version and it works really well. It safely latches like a jack stand and it has a wide base that works well in the dirt.
    Captain Spalding likes this.
  12. Jul 5, 2023 at 8:27 AM
    #72
    I like the idea and have been on the fence buying one more than a few times over the years. Maybe one day lol. What keeps me away is that I seem to have bad luck with seals on hydraulic jacks. But these would be nice especially to get a rear tire off the ground withough having to lift at the pumpkin first.
  13. Jul 5, 2023 at 11:26 AM
    #73
    I have the 6000 lb version, not too useful because the advertised lift range accounts for the 3 holes on the jack insert. The actual hydraulic jack has a small lift range, less than the vehicle's suspension travel. I keep it mostly as a glorified jack stand now.
    mtnslyr likes this.
  14. Jul 21, 2023 at 10:01 PM
    #74
    Henry J
    Sacramento Ca
    Oh, just saw this mount for the badlands. Might be ordering it very soon!
  15. Jul 30, 2023 at 7:45 PM
    #75
    mtnslyr
    mtnslyr New Member
    Agree. Just adding that the total lift range is about 6 inches. So if you start at 11 inches you’ll go up to 17 inches. If you extend the jack insert to 15 inches then at max lift it’ll reach 21 inches. The lift range of 11-21 inches is misleading, no you cannot start pumping at 11 inches and go up to 21 inches
    grizzlypath likes this.
  16. Sep 23, 2023 at 5:57 PM
    #76
    kojak
    kojak New Member
    21 SR5P 4x4
    I have the smaller unijack; it's super handy for service stuff but never found a good spot for it in the rig. Plus it was cheap.
    Check out 911 Motorsports for some nice (and much lighter) alternatives to the Badlands lift. I revived my 8+ year old Pittsburgh 1.5 ton with their wheel kit and threaded saddle adapter+extensions. If I was taking it out of the garage I'd add their skid plate and vehicle mounts.
  17. Sep 24, 2023 at 8:18 AM
    #77
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Definitely agree on using the OEM jack once at home. Really we should be doing this with every vehicle we have, but it's tempting to use the big floor jack all the time if you have one.
  18. Sep 24, 2023 at 10:22 AM
    #78
    I’ve had both my kids do a dry run too. Changing a tire is an important life skill.
    alittleoff likes this.
