Is there a more active 4Runner forum?
Discussion in 'Off-Topic Discussion' started by coachhomer, Aug 25, 2024.
  1. Aug 25, 2024 at 12:37 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Just guna say as I've said in other threads. I effectively have TWO sets of Raptor lights. Two...one of them is for you.
  2. Aug 25, 2024 at 1:10 PM
    Lost Woods
    Lost Woods New Member
    waaaay too many people around there who just love having a wank over instagram-ready builds and the 42 daily "joined the club" posts than any real conversation. Nobody wants to hear anything negative no matter how bad the idea is.
    ThomasL, Bob and Thatbassguy like this.
  3. Aug 25, 2024 at 1:42 PM
    @Borracho Loco does have a point. If you just look at the 5th gen forum, the most active forum on 4runners.com, there's just under 260,000 posts since 2014. That is an average of 2,166 posts per month. I don't see a total number of members posted, but I have to believe that if all the contributors to the 5th gen forum averaged less than 4 posts per month (as has the person asking if there is a more active 4Runner forum) this forum would have fizzled years ago. If you want a more active forum, be active.
    Sure there's plenty of redundant questions posted, but no one has to open a thread if they so choose not to.
    I for one appreciate the ability to read and contribute in a community without having to negotiate incessant advertising popups. And more importantly where political discussions are not allowed.
    I spend some time on TacomaWorld, but nowhere near as much time as here. The forum there I frequent, 1st Gen Tacomas, has pretty much become a daily number of requests about how to fix things on a truck that is now 20-27 years old, so it's understandable...
    Thatbassguy and 2Toys like this.
  4. Aug 25, 2024 at 1:59 PM
    I was on TacomaWorld too, and there are threads on that site that I wish we had here, like:
    1) NFL Trash Talkers thread.
    2) What are you watching/streaming on Netflix
    3) The IT section.
    4) Roast my Tacoma (for all generations), that was a brutally hilarious thread.
    5) There was a health/wellness section. Members would share difficulties they went through, and how they got through it. It had some great and gritty stories in it.
    There were a lot of other threads, and I wish we had them here. Maybe some of the moderators can add them?
    Flit04, Thatbassguy, djwantke and 2 others like this.
  5. Aug 25, 2024 at 2:19 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey OP
    You could be mistaken. And you are.
    This forum like it or not is by far the most active and runs the smoothest.
    Most of the fb groups are just noise. This forum and the other guy produce the most expert opinions
    rphillips66 likes this.
  6. Aug 25, 2024 at 2:21 PM
    Grif900
    Grif900 New Member
    Griffin
    08 SR5 4WD V6 75,000 miles strong
    Yeah there is a forum for that; it's call yer local bar, they meet every day.:anonymous:
    Jedi5150 and ChessGuy like this.
  7. Aug 25, 2024 at 2:44 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    I think the forum platform is something of a dying breed any more with the advent of Facebook and YouTube. And that is unfortunate in my opinion.
    I got heavily into one of the forums in the mid 2000s and several other active forums existed as well. But now most of them are gone or ghost towns. Back then we were all writing up and documenting our repairs and mods with pictures not videos and it all had very much a family or club feel to it.
    But now it's hard to compete with a YouTube video of exactly the repair on exactly the make, model, and year you're looking for. So I'm happy to find a spot like this where we can share resources we have stumbled upon.
    Also I agree with some other posts that note that much of the things that can be done, already have been done. As well there are not too many that are going to go crazy modifying their 50k vehicle. Hopefully the earliest 5th gens are now getting to that point where folks are willing to try some more radical stuff.
    I don't follow other vehicles so I can't speak to those forums but I have found this one to be plenty active for my needs.
    J.A. likes this.
  8. Aug 25, 2024 at 2:59 PM
    The forum is a reflection of the customer base of how 4runners buyers/owners behave. I have a tacoma as well and couldn't take the tacomaworld site for example.
    Trail Runnah and 2Toys like this.
  9. Aug 25, 2024 at 3:44 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    lol who peed in your tea?
  10. Aug 25, 2024 at 3:58 PM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    If you get bored....you can always ask for a tire recommendation, how much or what type of lift to get or oil change recommendations. Those topics are very dear to must and generate a lot of ...... :crapstorm:
  11. Aug 25, 2024 at 4:06 PM
    Eubeenhadd
    Eubeenhadd Bit of a derp
    Indianapolis
    2005 T4R 4.7 AWD
    Spartan Locker, OME 885/895w/stiff Nitrochargers, 265/70R17 Encounter AT
    Low effort, high entitlement posts are perfect ways to increase activity, glad to see you're figuring it out.
  12. Aug 25, 2024 at 4:23 PM
    scottiezilla
    scottiezilla New Member
    I thought @djwantke started one here
    Well, since you brought it up…
  13. Aug 25, 2024 at 4:27 PM
    Rupp1
    Rupp1 New Member
    NC
    2017 SR5 Premium RWD Starlight Black
    I hage out here and the Tacomaworld page. Have to admit I’m way more involved over there. Maybe you need a Tacoma?
    jeepster09 likes this.
  14. Aug 25, 2024 at 4:31 PM
  15. Aug 25, 2024 at 4:34 PM
    scottiezilla
    Haha
    Honestly I though it was him but somebody started something recently…along the lines of “bash me” or “official roast”
    side note:
    Condolences @djwantke
    https://www.4runners.com/threads/roast-me.38521/
  16. Aug 25, 2024 at 5:30 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Could seem more negative due to the downvote button. That doesn’t exist here so you get likes or people who disagree so whole heartedly they will comment. The ones who downvote on Reddit are the type to not like a user’s comment here and just move along because they have no meaningful contribution and/or can’t form their own opinion without an “influencer” telling them how to feel. There’s also the relative anonymity of the site. It doesn’t tell you who upvoted and who downvoted like it does here (for likes). On this forum, and others like it, your “reputation” can be influenced by what you like and comment. On Reddit, you can downvote and contribute to a toxic, instagram-wanking environment without anyone seeing your username or knowing you are doing it.
  17. Aug 25, 2024 at 5:58 PM
    LOL I didn’t start that thread you tagged me about, but @Borracho Loco capitalized on a free opportunity to get a dig in! :p
  18. Aug 25, 2024 at 6:30 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    i am planning on getting tires in the spring and have almost 3inches of lift, what do you recommend.:ohsnap:
  19. Aug 25, 2024 at 6:31 PM
    #49
    Daddykool
    Depends on what oil you're running.
    2Toys and Thatbassguy like this.
  20. Aug 25, 2024 at 6:37 PM
    #50
    Bald Michelins
    Bald Michelins New Member
    21' SR5P
    "Get off my lawn...."
  21. Aug 25, 2024 at 6:41 PM
    #51
    Spare Parts
    Southern Maine
    22 LR ORP
    Depends on what’s on sale at Wally World :nuclear:
    Thatbassguy and Pentangler like this.
  22. Aug 25, 2024 at 6:44 PM
    #52
    Daddykool
  23. Aug 25, 2024 at 6:48 PM
    #53
    40 inch Mickey Thompson Baja Boss. Go big or go home.
  24. Aug 25, 2024 at 7:01 PM
    #54
    Spare Parts
    Southern Maine
    22 LR ORP
    What off set will I need?
  25. Aug 25, 2024 at 7:24 PM
    #55
    You have the power to make your wishes come true...
    Thacrow likes this.
  26. Aug 25, 2024 at 7:26 PM
    #56
    40's are for amateurs...
    You know they make DOT approved 54's, right?
  27. Aug 25, 2024 at 7:27 PM
    #57
    Supertech FTW!
    Spare Parts[QUOTED] likes this.
  28. Aug 25, 2024 at 7:33 PM
    #58
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I was sad to see that thread die so quick. Was hoping it would catch on
    2Toys likes this.
  29. Aug 25, 2024 at 7:40 PM
    #59
    Pavo
    Pavo New Member
    Tacomaworld is the sister site to this one but they’re the complete opposite, there’s a ton of knowledge on that forum and they have answers to the most random obscure problem. Not trying to bad mouth this forum but it’s just a very select number of members who post here regularly and honestly there’s like a loose zero actual useful knowledge on here that you can’t get from anywhere else online
    there’s t4r there extremely knowledgeable when it comes to issues but their website is so extremely shitty (bloatware, always crashes etc) I won’t even attempt to go on it anymore
    Pentangler, Steve Berman and Thacrow like this.
  30. Aug 25, 2024 at 8:31 PM
    #60
    Kezin
    It’s unfortunate T4R.org was/is the de facto site for most people. This one is so much easier to navigate and doesn’t cause my phone to overheat when trying to open a thread. Started out on there and found my way here after I got fed up with the constant captcha tests to access a poorly optimized site
    djwantke, crob42, 5thToy and 4 others like this.
