Is there a consensus for the ideal wheel offset to reduce rubbing??
Discussion in '5th Gen 4Runners (2010-2024)' started by MountainMan, Aug 14, 2020.
  1. Aug 16, 2020 at 2:53 PM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Thanks Peter 2772000, I must have missed that! Cool, really cool.
    peter2772000[QUOTED] likes this.
  2. Aug 17, 2020 at 4:55 AM
    ThePnsh3r
    ThePnsh3r New Member
    2020 TRDOP
    Runner,
    How much room is there between the inside of the tire and the control arm? Do you think a 285 will rub? I am looking into ordering 285/70r17 KO2s and keeping stock wheels if possible. Those tires run a bit smaller so I should clear front and back - but someone mentioned that it would rub on the control arm....
    Oldtoyotaguy likes this.
  3. Aug 17, 2020 at 6:34 AM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    Pics of the body mount chop
  4. Aug 17, 2020 at 11:50 AM
    runner4it
    runner4it New Member
    Alex
    2020 4Runner ORP
    I'm parked in my driveway with my nose pointing downhill. I measured on flat surface surface from hub center to top of fender well.
  5. Aug 17, 2020 at 11:51 AM
    runner4it
    Alex
    2020 4Runner ORP
    Let me see if i can get you a couple pictures today at full lock.
  6. Aug 17, 2020 at 12:39 PM
    Oldtoyotaguy
    Hey runner4it, bottom line is whether you're happy with it. As long as it's what you want, its good. Having said that you're measuring mainly lift height. That's a great measurement for fitting larger tires, which is what most guys want out of their lifts. But if you want level, try parking on a hard level surface and put a masons level on the bottom of the frame rail. Even then there are other factors involved and you may have to just eyeball it. Its pretty subjective, where the positive and negative range merge at level 0.
    runner4it[QUOTED] likes this.
  7. Aug 17, 2020 at 1:01 PM
    runner4it
    Alex
    2020 4Runner ORP
    yup, makes sense. My only point really was that ground is not level, nor did I hold the phone level when taking the picture. I mentioned the rake because the rear springs are supposed to be 2" lift to give a "level" stance, but because I went heavy springs the rear was lifted more than the spec'd 2" without adding additional weight to the rear. He ordered the same kit minus the stiffness so just wanted him to realize the difference.
    Oldtoyotaguy[QUOTED] likes this.
  8. Aug 17, 2020 at 4:38 PM
    runner4it
    Alex
    2020 4Runner ORP
    Turned full left and full right. I can about get two fingers between the tire and the upper. With any flex in the suspension and tire wall I'm pretty sure a 285 would rub. Would be close though.
  9. Aug 17, 2020 at 4:49 PM
    ThePnsh3r
    2020 TRDOP
    I think you’re right. And, even if it didn’t rub it would be very close. So a wheel with a a bit more negative offset is all but a must. Or a wheel spacer... now, a dilemma is if I settle for 275/70r17 KO2 in e load - or splurge on a set of wheels to be able to clear the control arm with a 285 tire - but then risk of having to do a BMC. I think that 275 might just be a more sensible option here.
    Thank you for taking the time to take the pictures. It really helps a lot while I am waiting on my kit to arrive. I would really like to get it all done all at once and get it right first time around.
    If you don’t mind me asking - what are your wheel/tire plans?
  10. Aug 17, 2020 at 4:58 PM
    ThePnsh3r
    2020 TRDOP
    Btw ... this is not helping. According to Ironman - 285 will clear :annoyed:
  11. Aug 17, 2020 at 5:00 PM
    runner4it
    Alex
    2020 4Runner ORP
    Mildly indecisive myself. Right now i'm looking at 17x8.5 0mm offset with either 275 wildpeaks or 285 ridge grapplers. A friend of mine has 285 ridge grapplers on 0 offset wheels that i'm going to test fit. I'm not trying to dog down the 4r too much with too large of diameter and weight of wheel/tire combo. I do tow occasionally so that's a major consideration for me. Body mount chop isn't a huge worry to me.
  12. Aug 17, 2020 at 6:01 PM
    runner4it
    Alex
    2020 4Runner ORP
    So go for it. Worst case is you buy thin shim style wheel spacers to run that set of tires and then put 275 on after.
  13. Aug 20, 2020 at 4:55 PM
    MountainMan
    MountainMan [OP] New Member
    Pacific Northwest
    Saw this in town today. I couldn't help but laugh out loud. I think the driver heard me because he sped off in a huff and big blue cloud of exhaust smoke...
    This guy is going to have a bad day when the ISP spots him.
  14. Aug 27, 2020 at 3:18 AM
    peter2772000
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    You gotta wonder sometimes.........
  15. Aug 29, 2020 at 12:41 PM
    ready6delta
    ready6delta New Member
    Jacob
    Finally back in the PNW! Lake Stevens/ Olympia
    2020 MGM SR5 PREMIUM
    DOBINSON 3/2 LIFT, COOPER STMAXX 255/80/17
    This is what im adding to the wife new SR5 premium MGM. Cooper st maxx 255/80/17 same as on my tacoma and i love them. Going with dobinson 3/2 lift for her but debating on 1.25 in bora spacers wit hthe st maxx for a little stance. Pros /Cons? anybody run this setup?
