Is slight steering wheel vibration normal with AT tires?
Discussion in '5th Gen 4Runners (2010-2024)' started by Loco x Toyota, Jul 7, 2022.
  1. Aug 17, 2022 at 6:03 PM
    #121
    peaceloveandtattoos
    peaceloveandtattoos New Member
    ‘22 Army Green ORP
    Trd pro skid plate, roof rack, wheels, tires and lift, predator tubes
    35 all around. And I live in AZ where it’s suuuuper hot
  2. Aug 17, 2022 at 7:18 PM
    #122
    For LT285/70/17's the pressure, based on the recommended OEM pressure and size, is 38. I run 38 on my 285 Toyo AT3's and it seems good.
    For SL (P-metric) it recommends 26, but I don't think I would run that low
    Here's the calculator I'm using:
  3. Aug 17, 2022 at 8:34 PM
    #123
    peaceloveandtattoos
    ‘22 Army Green ORP
    Thanks so much! I appreciate the info!
  4. Aug 18, 2022 at 4:55 AM
    #124
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
    Little off topic by a while ago I think I remember you saying you had a bit of a shimmy with stock tires and when you upgraded it went away? Is my memory true?
  5. Aug 18, 2022 at 5:15 AM
    #125
    Yes. The shitty Dunlops had the standard ~60 MPH wheel wiggle. And, I've only had It with the Toyos and the Yokohamas when I have a clump of mud in a wheel, or when I lost wheel weights "somehow."
  6. Aug 18, 2022 at 5:18 AM
    #126
    Tmiesowicz
    Thanks, calling my tire place now! The time has come.
  7. Aug 18, 2022 at 9:12 AM
    #127
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I'm running 38 in sl rated, so I'd jack your up to 42 and test it out. If its to firm just lower psi to achieve the ride stiffness your after.
  8. Aug 26, 2022 at 4:34 PM
    #128
    Loco x Toyota
    Loco x Toyota [OP] New Member
    Cedar Park, TX
    TRD Pro Solar Octane
    I think I finally got rid of the shimmy.
    I changed Falken Wild Peak AT3W 265/70/17 to 265/65/18 Michelin Defender. I took the wheels and tires to discount tire for road force/dynamic balancing and tipped the tech $20 for taking his time and not scratching my wheels. He told me it's the best he could balance and if the truck still shakes, it's not the wheel balance.
    I drove multiple times on the same highway where I would normally feel shimmy at around 60 mph, it is very smooth now.
    mrmike7189 likes this.
  9. Aug 26, 2022 at 5:11 PM
    #129
    4runningMan
    4runningMan New Member
    New Mexico
    I do not know. Good question. Perhaps that’s why Toyota doesn’t recommend that rotation pattern.
    kolter45 likes this.
  10. Aug 26, 2022 at 5:13 PM
    #130
    Loco x Toyota
    Cedar Park, TX
    But practically every tire shop does it, and other manufacturers recommend that too.
  11. Aug 26, 2022 at 8:30 PM
    #131
    I've been rotating mine so that they change direction on my last 4 sets of tires with great results. They wear evenly, and have great tread life.
  12. Aug 26, 2022 at 10:54 PM
    #132
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    99.99% of the time, all 47 billion "I have a shake on my runner?" Threads and issues are the tires mate. I stopped reading them, and replying to them, as they would get so fucking off the rails, over a out of round/not balanced decently rubber.
  13. Aug 26, 2022 at 11:14 PM
    #133
    Loco x Toyota
    Cedar Park, TX
    It's funny though, the tech asked me what vehicle those wheels go on to, I said a 4Runner, and he commented that he gets a lot of 4Runner vibration complaints and his opinion is that they are very sensitive to imbalance and also non OEM wheel specs.
    That's why I decided to upsize the wheel size from 17" to 18" so that the wheels are easier to balance.
    Also I went from -10mm offset to 0mm, not OEM but closer to OEM offset.
  14. Aug 27, 2022 at 5:30 AM
    #134
    "The best he could balance" doesn't sound very good to me. It's either balanced, or it isn't. I definitely wouldn't take my vehicle back there.
    They definitely are. I'm not sure why, and nobody else seems to know, either. But, if your tires are balanced perfectly, it shouldn't shimmy.
  15. Aug 27, 2022 at 9:43 AM
    #135
    Loco x Toyota
    Cedar Park, TX
    They way he explains to me is that it's more like a range of acceptance in terms of being balanced rather than a yes and no binary choice.
    The following is just my speculation:
    I don't know the specifics, but let's assume that the balancing machine they use has a threshold of 1.5% of acceptable vibration, and most installers in a hurry can balance it to 1.2%, and someone taking his time carefully placing the weights, massaging the beads, can get it to 0.8% something like that. So, to the machine, the 1.2% and 0.8% are both "balanced", but one has less vibration than the other.
    I think it kinda makes sense because the weights they are using are pre-cut, and they can only choose a selection of what's available to best approximate it. For example, if they only have 1, 2, 5 grams weights available, they need to come up with 7.5g, the best they can do is just 7g. So there's always some level of imbalance left.
  16. Aug 27, 2022 at 10:18 AM
    #136
    I get what you're saying. But, I don't think almost balanced is good enough. Maybe some shops are more meticulous than others. Maybe I'm just lucky, but both sets of my tires are perfectly balanced.
    SlvrSlug and 4runGirl88 like this.
  17. Sep 22, 2022 at 2:55 PM
    #137
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    Quick update: Took Frankie back to 4 Wheel Parts (initially installed Bilsteins and tires in Oakland, CA) and had them balance and rotate, all good now. I have no steering wheel shimmy so I guess the other shops just couldn’t balance them correctly, including the $225 road force balance at the dealer.
    If only I realized there was a 4WP here when I moved I would have gone their first.
  18. Sep 23, 2022 at 8:03 AM
    #138
    Tmiesowicz
    Keep us updated, every time I had a rebalance it was fine for the next day or so and came back like a stray cat you keep feeding.
  19. Oct 13, 2022 at 4:49 PM
    #139
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    Frustrating problem! I get the 60mph vibration on the highway only occasionally, and I cannot figure out why. I live with it but, wish I could figure it out.
  20. Oct 13, 2022 at 6:28 PM
    #140
    kolter45
    Denver
    Inferno Pro & BRM Sport
    My Tacoma had the vibes. Turns out, my tires were shit
    mrmike7189 and RingSteel like this.
  21. Oct 14, 2022 at 2:09 AM
    #141
    Matt83
    Matt83 New Member
    Northeast
    I fought these issues for a long time, stock Dunlops, KO2s, General Grabber. Nittos in stock size then worked at first but the wobble came back.
    Michelin LTX AT2 solved my problems. That and a small shop with a good tech and the proper 6 lug adapter.
  22. Oct 15, 2022 at 2:42 PM
    #142
    MAXIM
    MAXIM New Member
    I had one bad tire that caused vibration at 65mph. Once located and replaced - no vibration. Bad tire had high spot on it even though it was perfectly balanced. Watch them spin in balancer. If they wobble manufacturer will give you new one due to defect. GL
  23. Oct 18, 2022 at 7:08 AM
    #143
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Ever since I got my tires properly balanced 2k miles ago, no vibration.
  24. Oct 26, 2022 at 4:05 PM
    #144
    kolter45
    Denver
    My Wildpeaks on the Tacoma have bad luck. 2 flats & only 2 years old. I’ve patched one & replaced one. First was a brass drill bit then a large screw on the edge of the tire.
    My 4Runner has duratracs. 2 years old & there loud as shit. Both sets r 265/70/17
    RingSteel likes this.
  25. Oct 26, 2022 at 5:02 PM
    #145
    I am starting to feel the same way about the wildpeaks...on my 4R. I seem to have to go to discount tire every 5K to get them rotated and road forced balance and then the vibration goes away. I was there today....and took this picture and thought of the gang!
  26. Oct 29, 2022 at 7:06 PM
    #146
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    My nitto grapplers are great when the pressure is right. 33+ cold and I am fine. 32 and I get shakes between 50 and 60 mph. Got it back from getting my 20k and a torn axel seal replaced, shimmy. Checked pressure…sure enough 32. Added my air back in and bang…no shimmy. Been that way since I got it.
  27. Oct 29, 2022 at 7:15 PM
    #147
    Accelerator
    Accelerator New Member
    Chris
    Satellite Beach, Fla
    2022 SR5 Super White 4Runner #3
    Yeah, it’s weird. Seems like a lot, not all but a lot of 4Runners have a certain psi sweet spot when it comes to tires. My ‘10 Limited had a range with Michelin Defenders (which seem to be the least troublesome) and now my ‘22 with Toyo OC AT3’s also has a certain range that it likes. It appears that if I get my “cold” psi dialed in, it doesn’t matter if it’s 95 or 65 outside it’s fine from the start. Similar, on the flip side, if I’m not dialed in for my cold psi, it sucks through any temperature range.
    b0bbyj0hnny likes this.
  28. Oct 30, 2022 at 1:19 PM
    #148
    Rock-N-Roll
    Rock-N-Roll TRD Amateur
    2021 T4R ORP w/ KDSS
    I hope my story helps some people out.
    I lifted my 4R with 2,000 miles on it. No shimmy until about 14,500 miles. I did an alignment and 2 tire balances with no luck. Took it back to the shop that did the lift and they found that my drivers side UCA was messed up so that was replaced. Still had the shimmy. Did another balance with no luck. Took it back to the shop and they put it up on the lift and ran it in 4WD to look at the shape of the tires. One tire definitely had a wobble to it. They put the wheels and tires on it from another 4R and the wobble went away. Took it back to Discount Tire and they said it was no big deal and balances the tires again. I convinced them to change out the tire in question since I had a cert on the tires and was able to verify that another set of tires resolved the issue. It had to be the tires. Once they replaced the one tire, the issue completely went away.
    If someone can't seem to fix the wobble with multiple road force balances, I would suggest trying the wheels and tires from someone that doesn't have the issue to see if it goes away. Discount Tire can balance an out-of-round tire properly and not really notice that it's out of round enough to make a difference. To them, all tires are not perfectly round and if it balances, it's not a defective tire.
  29. Oct 31, 2022 at 10:28 AM
    #149
    YetiMtnBkr
    YetiMtnBkr New Member
    Frederick, MD
    2021 LR Pro
    None
    I have a 21 Pro with the stock Terra Grapplers. It is 18 months old with 30,000 miles and I recently returned from a 20 day / 5,400 mile road trip out west from MD. I have only noticed the shaking steering wheel on two occasions going around 60 mph and it seemed like a brief spell. Maybe I am very lucky in that I apparently don't have an issue or I am just tone deaf to the vibrations. My mountain bike handlebar shimmy's pretty good thru the rock gardens and downhills - maybe that is why I think the 4R is good to go!
  30. Oct 31, 2022 at 11:56 AM
    #150
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    If your having this shimmy issue, try rotating the tires(yes you'll still have a out of balance tire) but you'll might be able to tell which tire it is.
