Installing aftermarket radio and switch panel! **Pictures!**
Discussion in 'Audio & Video' started by ramonortiz55, Jun 1, 2015.
  1. Jun 1, 2015 at 5:43 PM
    ramonortiz55
    ramonortiz55 [OP] New Member
    Ramon
    As I was doing my daily scroll of tacomaworld I stumbled upon user paranoid56's 6 switch plate that goes under the radio.
    I figured this would be a great location to install some clean switches on the 4runner. I know I have a lot of goodies planned out for my build, so why not?
    In order for this to work I had to get rid of the factory double din radio and purchase a single din aftermarket radio. I had never installed an aftermarket radio, but what the heck, I wanted that switch panel!
    This past saturday I stopped by fry's and picked me up this Pioneer radio with bluetooth. :D
    Ignore the LED bar, that's for a future mod ;)
    Aha! The switch panel came in. It's a nice sturdy aluminum plate, very well made.
    After plasti-derp:
    Next step was to solder all the wiring in the radio harness and OEM adapter harness. This OEM adapter harness allows my radio to be plug and play to the existing OEM wiring the in 4runner. The adapter harness comes with the radio and is provided to me depending on the vehicle application.
    I solder all the wiring, making sure all colors match and use shrink wrap for a nice clean finish.
    Any unused wires were plugged. The blue wire with the flag reads "for remote", I guess this is some sort of antenna for the radio remote.
    The fry's representative told me NOT to connect the orange wires. These are for the dimmer. If I try to dim the radio using the factory dimmer, the radio will flicker. So I just sealed these off with shrink wrap and tape.
    The other blue wire is for an automatic antenna, which I do not have.
    Next comes the fun stuff!
    I grabbed some kitcken knives and wrapped them in tape to not scratch the 4runner's interior.
    Pried on the center trim piece around the shifter:
    Remove and swivel away:
    I did not remove the 4x4 shifter leather wrap. I didn't want to mess with it.
    Next I carefully removed the radio trim. This is very brittle!
    I was careful with the radio trim since there is a lot plugged into it.
    1. three power points
    2. hazard lights
    3. defroster switch
    4. clock
    5. ECT button
    Now I can pull the radio out.
    Notice there is TWO antenna cables. The bigger one is for the front antenna, the smaller one is for the rear antenna.
    I then remove the brackets that hold the radio housing in place. I will need to install these to my Pioneer.
    One thing I noticed was that my radio harness had TWO plugs.
    While the plug that was on the factory radio was one small plug. CRAP!
    No sweat! See that box? That's an amp. I unplugged the wires to the amp, and abandoned the amp in place.
    I pulled the casing off the Pioneer and mounted my brackets.
    Now, I mounted @paranoid56 switch panel:
    The holes were a little misaligned, so I grabbed a drill and fixed it.
    I connected the amp wiring to my radio harness, plugged the front antenna cable (abandoned the rear antenna cable plug) and dropped the headunit back into its location:
    I carefully put all the trim back in place. :D
    Finally, installed carling switch blanks
    BantamEddy, HICSPANIC, hmgt4r and 2 others like this.
  2. Jun 1, 2015 at 7:06 PM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    87 4Runner SAS and other stuffs, 07 Tacoma
    Things and stuff and such
    With some modification, I used the same switch panel in my 1st gen :thumbsup:. I love it
    Mr.P and ManBeast like this.
  3. Jun 1, 2015 at 7:26 PM
    ramonortiz55
    Ramon
    show me a close up of those switches!
  4. Jun 2, 2015 at 8:00 AM
    Ol'Blue
    Ol'Blue New Member
    "Not all who wander are lost"
    Were did you get that panel, I want two of them for my 3rd Gens...
  5. Jun 2, 2015 at 8:57 AM
    ramonortiz55
    Ramon
    www.paranoidfabrications.com
    buy the tacoma version, it fits nicely.
  6. Jun 2, 2015 at 2:45 PM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    My stereo bracket is different, you can see I shaped the sides to mount inside the stereo bracket and drilled new holes.
    I have a "roof light bar" rocker to replace the "offroad lights"
    BantamEddy and seoulja99 like this.
  7. Jun 2, 2015 at 5:39 PM
    ramonortiz55
    Ramon
    are those the v1d1 upper independent carling switches?
  8. Jun 3, 2015 at 2:57 AM
    ajohnson
    ajohnson Glamorous
    Andy
    Charlotte, NC
    They are from otrattw.com, upper independent
  9. Jun 9, 2015 at 8:00 PM
    ramonortiz55
    Ramon
    Thanks
  10. Aug 16, 2015 at 4:11 PM
    Ripcord
    Ripcord New Member
    Columbus, OH
    Very cool! Great place for switches! I was dead set on using a pocket there, but now I just don't know..
  11. Oct 28, 2015 at 7:54 AM
    RussToy
    RussToy New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    I just bought my Kenwood and my switch panel from paranoid fabrications. They've already arrived and yesterday I ordered six (6) switches from Otrattw.com. Talked to Jim...great guy. He allowed me to change a couple of things to personalize my blanks. If your a member of TW you'll get 10% discount. Then to bring all this together...just received my Bussman relay box from Yatomac over on TW. I'm Hope'in to get this all put together in a week or two. I'm Sure @ramonortiz55 will revist this and finish adding his switches!!
  12. Oct 28, 2015 at 8:28 AM
    Ol'Blue
    Ol'Blue New Member
    Looking forward to pictures and install process.
    Blue
  13. Oct 28, 2015 at 10:38 AM
    RussToy
    RussToy New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    I'm just waiting on my switches. I'm Hope'in they'll be here by Friday. Unsure if @ramonortiz55 already has his on not? I've never done a write up with pictures and what not...I usually take one or two pictures than get really into the work and totally forget about taking more pictures until that night when I sit down at the computer...lol!! I'll tried and make it happen this time!
  14. Oct 28, 2015 at 11:44 AM
    ramonortiz55
    Ramon
    I only have one blank left.. hehe
  15. Oct 28, 2015 at 2:37 PM
    RussToy
    RussToy New Member
    Russel Lee
    Granville Ohio
    2000 4Runner SR5
    A Work in Progress
    Ooooooooooo....we've been busy!!
  16. Apr 4, 2017 at 2:05 PM
    giarc1234
    giarc1234 New Member
    Craig
    2006 SR5 4Runner
    None yet. Just purchased it.
    That bracket is pretty sick. I like it. It is a great place for switches. I put mine up top.
    BantamEddy, LadyDriv3n and 2wdrunner like this.
  17. Apr 4, 2017 at 8:03 PM
    ramonortiz55
    Ramon
    I like that!
    giarc1234[QUOTED] likes this.
  18. Apr 4, 2017 at 9:01 PM
    giarc1234
    Craig
    2006 SR5 4Runner
    It was very time consuming to make. It was my first time doing fiberglass work, needless to say I did a lot of sanding...lol. I do like the one you have as well. Might get the bracket for more switches down the road.
  19. Jan 7, 2019 at 3:50 PM
    GigemAgz95
    GigemAgz95 New Member
    Brad
    Houston, TX
    2007 v6 SR5 2wd. 51K mi
    KPMF stealth Tundra vinyl wrap. Interior Led mod. Fog light mod. Jensen deck, Polk DB plus doors. Blackout of chrome - Emblem Delete.
    That Bracket is PERFECT ! Need. Want. Must have. Still available or able to produce ? Please?
    This is my first post, as I have a "newly acquired" 2007, SR5, 2WD, 4.0L - looking forward to reading all these awesome threads.
  20. Mar 2, 2024 at 2:57 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
