Improve highway ride with suspension mods?
Discussion in 'Suspension' started by Stones, Jan 2, 2025.
  1. Jan 5, 2025 at 7:58 AM
    icebear Recovered Kia Owner
    Legally, the warranty can be void on things affected specifically by modifications but it’s not all-or-nothing.
    They can’t (not to say a dealer won’t necessarily try) claim a lift affected the transmission without evidence but if your CV axles go out, that’s more dicey as their angles in operation would have changed.
  2. Jan 5, 2025 at 8:14 AM
    TrailSpecial22 New Member
    PA
    agreed and thats why i kept all of my lifts at a max of 2”
  3. Jan 5, 2025 at 9:06 AM
    Stones
    Stones [OP] New Member
    Dennis
    Grand Rapids MI
    2024 Black ORP
    I imagine it would be difficult to get such a thing signed 8 months after purchasing. I'm certain you and Ice Bear are technically correct but I'd sooner avoid any legal wrangling. I read a long post on this by someone here who tried. He sounded quite wealthy and (if memory serves) he had a good friend who was also an attorney his company had on retainer. The gist was you can fight Toyota Corporate's attorneys in court if you want to and you may even win. If you have a truckload of money and time you don't mind burning on principle. I prefer to spend my precious free time irritating trout.
    I hope it doesn't sound like I'm trying to be a jerk. Not my intention at all and I appreciate your replies.
  4. Jan 5, 2025 at 10:08 AM
    PA
    i agree you have to choose your battles and no, i didnt get the jerk inpression.
    not sure if this is correct but if anyone knows does the TRD pro suspension add a littlw lift, like 1-1.5”? If yes is the answer then you can lift your vehicle, if you want, to within those limits and be fine bc they cant say your aftermarket 1” lift did more damage than their factory 1” lift. Now if youre doing a zero lift and upgrading the front shock, Toyota cant argue anything, but Im sure they will try.
    Stones[QUOTED][OP] likes this.
  5. Jan 6, 2025 at 8:23 AM
    TxTRD
    TxTRD New Member
    Tx
    22 TRD ORP
    Replacing the standard ORP suspension with the Fox Pro suspension netted me about 1” up front and 1/2” in the back. Measurements from center of hub are 20 7/8” up front and 22.5” in the rear.
    My front measurements were below 20 prior, if memory serves me correct they were 19 3/4” and 19 7/8”.
    I personally would not be concerned adding a mild lift of up to 1.5” whether it be a factory solution or aftermarket. Many 4Runners come from the dealer with lifts already installed.
    I have analyzed suspension options, as many do, and read for months. I happened to find a brand new set of Fox take offs and decided to try that route. I am pleased for the most part. The front coil overs are a bit stiffer. The rears on the other hand, may be a tad softer. Perhaps it’s the extra travel in this setup that makes it seem this way. Or maybe it is a tad softer.
    The problem with suspension is it’s subjective to personal taste. I’m really not sure if a 5100 setup would be too harsh for my liking, but I’ve read some folks think so.
    If I take off the Fox setup I’ll likely be moving over to Dobinsons IMS with 1.5” lift up front and the springs that provide up to .5” in the rear.
    TrailSpecial22 and 1SilverRunner like this.
  6. Jan 6, 2025 at 8:54 AM
    Photon_Chaser 51,023 and counting…
    Sierra Nevada Mountains and the Central Coast
    My buddy’s RAM has a highway mode that lowers (dynamic air suspension) the frame/body and drops an air dam to improve highway handling. It got me thinking numerous times about “what if…”
    My T4R’s handling improved after I upgraded just springs…stiffening up the suspension just enough. I loved not needing to swap out shocks as the factory Fox shocks my rig came with are actually well designed…
    TRD Pro 4Runner Front shocks have 7 bypass zones (4 compression, 3 rebound); rear shocks have 11 bypass zones (7 compression, 4 rebound) and 2-inch piggyback reservoirs plus a unique TRD roost shield that offers additional protection for the inverted shock design in the rear.” -
    ) and
    After numerous trips across the Central Valley (an area known for occasional-brutal crosswinds) I can honestly say that just simply reducing ‘bounce’ with slightly stiffer (K-factor) springs noticeably reduced wandering tendencies. This is a brick of a vehicle and unless you improve aerodynamics under the vehicle you’ll never reduce poor handling due to wind effects to that of a sedan-sized vehicle.
  7. Jan 6, 2025 at 9:16 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Good to know! I'm glad you've got your setup down. I don't have any experience with the Pro's Fox suspension but I hear a lot of good things.
    I went pretty stiff with springs when I switched to the IMS setup and I like it quite a bit
  8. Jan 9, 2025 at 7:15 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    Our family sedan is a late production model Grand Marquis that I outfitted with KYB gas adjusts and rear CVPI sway bar. A little rougher riding with the well damped shocks but now handles like a big mustang, on highways 9,17 and 35 (those who live near the Bay Area would know it) on the twisty parts I have no problem keeping up with far smaller, sportier cars.
    bassist[QUOTED] likes this.
  9. Jan 10, 2025 at 5:20 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I love my trd fox suspension. It was a huge improvement over stock(sr5) and over my eibach stage 1. Just got to search for take offs. I got mine for $400
  10. Jan 10, 2025 at 11:24 AM
    FourBelugas
    23 white ORP
    That's a crazy deal, that means someone bought a TRD Pro and immediately swapped the shocks and struts out?
