IKE Gauntlet: 2025 4Runner Towing Test -- Beats Land Cruiser Again [TLDW Summary]
Discussion in '6th Gen 4Runners (2025+)' started by jwocky, Feb 9, 2025.
  1. Feb 13, 2025 at 9:40 AM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    This rather arbitrary obsession of some Ford owners with insisting on staying in 10th gear at all times is truly baffling, I see it with some superduty owners too, to the point where some people would get 4.30 rear end to tow 3-4k popup trailers just so they can stay in 10th all day with the 7.3 V8s, even if it means spinning at higher than needed RPM when it is not needed. Is it a bravado thing where people consider the motor to be weak if the TCM decides to downshift and use one of the other 9 or 7 or 4 gears?
  2. Feb 13, 2025 at 11:15 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Hmm, interesting approach. I'm sure those trucks aren't at lugging RPMs, but it's gonna be counterproductive in terms of engine stress.
    When making the same horsepower (say, going up a specific grade at a specific speed), the engine running at a higher RPM is actually experiencing less stress (more power strokes, with less work and less pressure during each stroke). I get some people don't like to hear their truck revving to 3000+ RPM at times, but it's definitely backwards as far as the engine is concerned.
    Again, interesting stuff, and you're right I don't have experience with it. But also, it's silly to compare driving characteristics of a TT 3.5 to a low stress, NA 4.0. I think Turd is right, and you should check out the GX 550 instead.
    DougNuts[QUOTED] likes this.
  3. Feb 13, 2025 at 11:21 AM
    FourBelugas
    23 white ORP
    For MPG and emissions purposes most transmissions now are programmed to hold as high of a gear as possible even if it means the engine runs a bit lean or hotter with less fuel to cool the combustion chamber. That's the same reason default throttle mapping on most vehicles feel so lazy and disconnected, and pedal commander is such a popular product.
    For cruising at light load it's okay, but those who tow heavy with class 2B and up trucks would know with gas work horse engines are better to let them downshift and work at 3k-4k rpm instead of trying to keep it in top gear and spin at 2-2.5k if you want to run the motors to 300k-400k. There is a reason F250/2500s and up don't use turbo gas motors yet. Ford, GM and Ram all tested turbo 6s and small v8s extensively and don't find them suitable for heavy towing at this time.
  4. Feb 13, 2025 at 11:38 AM
    DougNuts
    DougNuts New Member
    I certainly don't want it in 10th when towing or when loaded, that's a recipe for disaster. I'll usually put the truck in tow/haul mode when we go on vacations, and it will spend more time in 8th or maybe 9th, very little in 10th.
    The GX550 drivetrain is more my speed, but $70k+ for an Overtrail is an eye watering proposition. :(
  5. Feb 13, 2025 at 11:44 AM
    Schlappesepple
    2020 ORP
    Great, so I'm going to be the guy on forums in a decade complaining that my vehicle never downshifts when I think it should :rolleyes:
  6. Feb 14, 2025 at 4:54 PM
    NoDak
    NoDak New Member
    JR
    North Dakota
    tundra will only do 10th if above 81 or 85 mph
  7. Feb 22, 2025 at 6:08 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
  8. Feb 22, 2025 at 2:43 PM
    FourBelugas
    23 white ORP
    who else on social media is doing as consistent towing tests of various vehicles?
  9. Apr 11, 2025 at 11:06 PM
    gx4604life
    gx4604life New Member
    Friday
    Would be nice to see trans temps during towing…
