If you had 1k to spend...
Discussion in '5th Gen 4Runners (2010-2024)' started by Cajunchuck, Mar 24, 2024.
  1. Mar 25, 2024 at 9:55 AM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    And, internals like First Aid Kit, compressor, recovery strap, attachment points, good traction mats etc.
    To be honest, I've rarely used my off-road lights. Maybe a good roof basket (?)
  2. Mar 25, 2024 at 10:16 AM
    TRDSD
    2019 TRD Off Road Premium
    You don't have to hardcore wheel to use and benefit from sliders. They pay for themselves the first time you scrape or hit something as rocker panel body damage is some of the hardest and most expensive to fix. If you see yourself hitting the dirt sooner vs. later, it's a solid choice.
    Stoney Ranger and Trail Runnah like this.
  3. Mar 25, 2024 at 10:42 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I thought this website was big on inclusion, and for guys to do whatever they like to do :p
  4. Mar 25, 2024 at 10:54 AM
    The Moonheads martian army won't take kindly to your comments!
    I've actually downsized the sticker count, stopped/capped the offroad lights lol
    BantamEddy, Marchy and TrailSpecial22 like this.
  5. Mar 25, 2024 at 11:20 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Two rows of raptor lights.. because no one has ever done that before..
    Marchy and brodeyo like this.
  6. Mar 25, 2024 at 11:24 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    If someone ever gets one row to work reliably without spawning other electrical gremlins then maybe they'll add a second...
    BearBio and Borracho Loco like this.
  7. Mar 25, 2024 at 11:53 AM
    Hah! No sweat I got thick skin - didn't take anything as mean I can understand the pro sticker and no sticker gang. Just bustin' ur balls
    brodeyo likes this.
  8. Mar 25, 2024 at 11:58 AM
    sympley76
    sympley76 New Member
    2021 4Runner Limited
    I would put it away towards a Magnus supercharger fund.... 7 more of the 1K's and you have a nice upgrade.
  9. Mar 25, 2024 at 11:59 AM
    Everyone should know it isn't really a thick skin. It's a thick layer of stickers all over his body. :crapstorm::duel:
    Marchy, djwantke[QUOTED] and brodeyo like this.
  10. Mar 25, 2024 at 12:35 PM
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    I say spend it on gas and wheel it as is. Find out through real world experiences off road how it works for your situation and then identify what your limitations are and address them in order of importance.
  11. Mar 25, 2024 at 12:58 PM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Walking Dead this week had zombies in Yellowstone that had "armor" from the calcium in the geysers and hot pools! Rick and Michonne also were drinking "Black Bush"!!!
    djwantke likes this.
  12. Mar 25, 2024 at 1:44 PM
    Some kind of worldwide disease zombie type apocalypse is very possible imo
    We'll see who get's the last laugh then when I have my armored 4Runner equipped with zombie lights in all directions
    TrailSpecial22 and brodeyo like this.
  13. Mar 25, 2024 at 2:04 PM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    And bugs!!! And sharks!!!!
    However, the ultimate plague is not only likely but almost inevitable!
    Just my professional opinion as a retired Wildlife Biologist!
  14. Mar 25, 2024 at 2:56 PM
    That made me laugh out loud
    that is true.
    but, zombies and such could hear the truck as well if it’s on, the zombie lights could be for when they’re right on top of you. What would I do then at that point..I dunno
  15. Mar 25, 2024 at 3:49 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    Not the I Am Legend kind!
    This is why a bicycle is actually the best zombie apocalypse vehicle - quiet and never runs out of fuel
  16. Mar 25, 2024 at 3:53 PM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Be sure to have a GOOD muffler!
    Head shots @ close range: 10-22!
  17. Mar 25, 2024 at 3:55 PM
    TrailSpecial22 New Member
    PA
    you need to get the UV lights? like Will Smith used on his rig in I am Legend. Lol!
  18. Mar 25, 2024 at 3:57 PM
    PA
    phew, glad i got rid of my TRD Pro muffler and swapped in the OEM quiet version. Lol!
    djwantke and BearBio[QUOTED] like this.
  19. Mar 25, 2024 at 4:12 PM
    #49
    ^this!
    Except if the bike operator legs gas out haha
  20. Mar 25, 2024 at 4:20 PM
    #50
    Alright F it, my cap on truck lighting is officially over!
  21. Mar 25, 2024 at 4:33 PM
    #51
    Sliders are good, they can be a practical purchase. Great peace of mind when off-road, they can make a handy step to get to the roof, and they do guard against door dings.
    My other suggestion would be to use that money for trips. Either just going out on your own, or maybe take some guided trips with some overlanding groups or some off-road and/or recovery classes.
    Han4Run, BearBio and djwantke like this.
  22. Mar 25, 2024 at 4:33 PM
    #52
    FN2187
    FN2187 Stormtrooper
    Earth
    For aquarium, indoor or outdoor parties, stage - supplies, Halloween decorations, OR ZOMBIES
    djwantke[QUOTED] likes this.
  23. Mar 25, 2024 at 4:40 PM
    #53
    FN2187
    FN2187 Stormtrooper
    Earth
    Alright, to get on topic, someone suggested saving it until you drive it for a while to figure out what you need. I agree with this and should have taken that advice.
    All I really needed was a decent set of tires - which OP has already done. I started with "because I don't run with groups I need a winch to be safe" and that snowballed into a lot of money and weight. I don't personally mind because I've always wanted to go all out on something and I think the 4runner was the right choice if I was going to do it.
    If I really daily drove it though (I usually work from home) I'd probably kick myself for the mods. It drives great, no complaints there. But I took something not really fuel efficient and made it even less so.
    There is also the mantra of making yourself smile every time you look at it and I certainly do that
  24. Mar 25, 2024 at 4:48 PM
    #54
    100% recovery/wheeling courses, or sliders, for me
  25. Mar 25, 2024 at 4:51 PM
    #55
    Right!? They ought to cut the crap and list that in the description
  26. Mar 25, 2024 at 5:29 PM
    #56
    I love this website. We started out this thread about ideas on how to spend $1k and now we're trying to kill zombies with UV/Laser lights.
    You fuckers sure can derail a thread....and I will continue to encourage you.
    steelevo, seakuv, Manhattan and 2 others like this.
  27. Mar 25, 2024 at 5:34 PM
    #57
    Raptor Lights are the Herpes of mod's. If you get them of have them, you shouldn't tell anyone. Ever. And good luck getting rid of them!
    steelevo and catbrown357 like this.
  28. Mar 25, 2024 at 6:36 PM
    #58
    MKIVBB
    MKIVBB New Member
    2017 Super White 4Runner 4x4 SR5
    Volk TE37 Bronze Replicas, TrailFinder A/T Tires, Custom AV System, Etc
    I like the Trailfinders from Discount Tire. Cheap but good tires.
  29. Mar 25, 2024 at 6:40 PM
    #59
    Hey guys there's one thing you can't knock me on, and that's Raptor lights. Won't do it. Those are for Ford's. My offroad lights at least somewhat have a purpose, and perform very well (at blinding things)
    SlvrSlug likes this.
  30. Mar 25, 2024 at 9:46 PM
    #60
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    My raptor lights and my light bar blacklights serve a purpose. To be bad ass.
    No offense to ford's but my 4runner looks better than a raptor. They all need to retire their raptor lights.
