Howling noise at highway speed
Discussion in '5th Gen 4Runners (2010-2024)' started by ROB, Mar 7, 2019.
  1. Mar 11, 2019 at 10:46 AM
    ROB
    ROB [OP] New Member
    2018 SR5 PREMIUM
    NONE
    I still drive my truck they said it is safe to drive
    7385, HoBoDanny and WallyT4R like this.
  2. Mar 11, 2019 at 4:21 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    Thanks for your feed back . yes sometimes sh*t happens .. post back how Toyota handles this for you .. again as I have posted .. check all the drivetrain fluids for level and condition .. when you get the new diff do not do long drives under 500 miles .. just short runs like 20 miles .. gear oil will get hot and the gear teeth may also crack because this is a breakin period ..drive it easy also first 500miles..
  3. Mar 11, 2019 at 6:54 PM
    WallyT4R
    WallyT4R New Member
    That "World Class" multi-point inspection sounds pretty awesome!
    7385 likes this.
  4. Mar 11, 2019 at 11:12 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Is a rear diff replacement a pretty straightforward job? Like, is it a job that any dealer can do and probably do a decent job?
    I guess what I'm asking is... if the local dealer isn't what you'd consider to be "top notch", should one travel to another dealer farther from home? Or is a diff replacement something that probably isn't gonna be screwed up?
  5. Mar 12, 2019 at 3:34 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    If you can’t trust them with a diff. I wouldn’t trust them with anything. Dealerships should have Toyota certified techs so they should be able to technicaly do them but that doesn’t mean you have to trust them. The dealership here lost my trust with dishonesty, I wouldn’t pay them to change a bulb now. It’s all up to how you feel about the dealer.
  6. Sep 14, 2024 at 10:14 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Use a flat palm and run across the face of your tires. If there's high spots, criss cross rotate to even them out and do every other rotation
