How To: 5th Gen LED interior conversion
Discussion in '5th Gen 4Runners (2010-2024)' started by jester243, Sep 5, 2016.
  1. Nov 2, 2018 at 5:51 AM
    #61
    MeanDean
    MeanDean New Member
    Dean
    Rainier, WA
    '18 4R Limited - Magnetic Grey
    Yes, and yes. There's a big difference in brightness. IMO the SDM2 bulbs would be too dim but I didn't try them. The HP5's worked great in the doors though.
    4runningMan likes this.
  2. Nov 2, 2018 at 3:19 PM
    #62
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    Anyone having any issues with interior leds in newer runners? Just curious as I wanna swap mine out- little paranoia since I know 3rd gen Tacoma’s are finicky about them
  3. Nov 2, 2018 at 4:12 PM
    #63
    4runningMan
    4runningMan New Member
    New Mexico
    As a precaution, make sure the socket is powered off before changing any bulb. Powered sockets are what typically causes blown fuses.
    scottalot[QUOTED] likes this.
  4. Nov 2, 2018 at 5:26 PM
    #64
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    Right on- good idea :)
    Also, @jester243 i just ordered all my bulbs from Chris :) / jumper
    Got new reverse too- I like to see when I back up lol
    jester243[OP] likes this.
  5. Nov 2, 2018 at 5:51 PM
    #65
    jester243
    jester243 [OP] rabble rabble rabble
    Dan
    Spokane, WA
    I need to do the reverse lights too
  6. Nov 2, 2018 at 5:56 PM
    #66
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    I’ve had them in my Tacoma’s and always noticed a prettty big difference.
    jester243[QUOTED][OP] likes this.
  7. Nov 2, 2018 at 9:06 PM
    #67
    4runningMan
    New Mexico
    Has anyone tried this style of reverse bulb in the 4runner housing?
    6C862B32-19FC-402B-B93F-FD38D8104E11.jpg A562EDAD-F199-41FD-95CB-B211677F993A.jpg
  8. Nov 2, 2018 at 9:23 PM
    #68
    4runningMan
    New Mexico
    Amazon Prime 20% off coupon right now on the Philips Ultinon bulbs. (Just click the coupon in the app on the bulb's page).
    These 168's are awesome bulbs. Very bright. I installed them in my license plate sockets and they're almost too bright for that location, although they actually help at night for the backup camera head unit display.
    I just ordered 8 more for lower door panel lights and for the side-view mirror puddle lights and map lights.
    Here's the de3175 for the dome light, as well as the two lights on the inner tailgate. Haven't tried this bulb yet but will report back when I get them.
    I prefer this type of bulb over the generic looking ones with exposed LED's. The quality just seems all around better. And I've never had one throw a code or quit working.
    scottalot likes this.
  9. Nov 10, 2018 at 7:30 AM
    #69
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    All leds interior wise are now done :) as always it’s a huge improvement in light output as well as aesthetically. The stock bulbs look so dated and like someone smoked in the truck for years by how yellow they are
    This thread was a perfect way to follow a step by step for the job. I will add that the map lights were a .02 second job to swap by simply removing the cover and using a pair of needle nose players with a little tape on the end for cushion. Hardly any pressure on the bulb at all and a slight pull down and they pop right out
    Lastly, wtf is up with my luck haha I swear every single bulb I swapped had to be removed and spun 180* to make work
    WallyT4R and jester243[OP] like this.
  10. Nov 10, 2018 at 12:19 PM
    #70
    4runningMan
    New Mexico
    So I just completed all interior conversion to led. Something to note: when I turn off the truck, I notice that the two lights on the rear hatch door remain lit VERY dimly.
    There are three settings for that switch.
    -OFF
    -ON WITH DOOR OPEN
    -ON
    When I put the switch in the OFF position, the bulb is completely off. In the ON position it's bright.
    But in the ON WITH DOOR OPEN position, the light is bright with the door open, but extremely dimly lit with door closed. You can't even tell unless it's almost pitch dark, but it's dimly lit nonetheless. When I move the switch to the OFF position, that dimness goes away completely.
    It's like there's a trickle charge to the switch in that position.
    Any ideas what's going on here??
    Also, the map light flickers when starting the truck...
  11. Nov 10, 2018 at 12:22 PM
    #71
    4runningMan
    New Mexico
    I also did the puddle lights. Once you actually get to the bulb (careful you don't break any tabs), I can tell that moisture is reaching the sockets (new truck).
    When I twist the socket to get the socket out of the housing, there's moisture on the rubber gaskets (both sides). Might want to use some bulb grease on these sockets.
  12. Nov 10, 2018 at 2:16 PM
    #72
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    I wonder if that ever so slight glow would be gone a while later.. I’ve seen some fluorescent bulbs have an ever so slight glow a while after being turned off. Can’t recall if I’ve seen leds do so
    As for the flicker I’d be curious as to the bulbs themselves . Where did you purchase them from?
  13. Nov 10, 2018 at 4:37 PM
    #73
    4runningMan
    New Mexico
    Bulbs are all Philips Ultinon from Amazon. Good quality.
    I wondered about the residual "glow" going away after a bit too, but when i flip the switch to the OFF position, the glow disappears immediately. That makes me think there's actually some current there. Hmm.
  14. Nov 11, 2018 at 5:13 AM
    #74
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    Ah yes, missed the part about complete shut off.
    Sounds like there’s is a little current still flowing. I honestly wouldn’t sweat it but that’s just me. It’s such a low amount that it’d likely never affect the battery . I’d be curious if you got a super slight glow from the oem bulbs.. that said- maybe this just shows that the LEDs just take that much less juice to light up and the “leak” had been there all along but only now noticeable with a more efficient technology in place
  15. Nov 11, 2018 at 8:17 AM
    #75
    HarveyElmore
    HarveyElmore New Member
    Harvey
    Offroad TRD 17'
  16. Nov 11, 2018 at 9:02 AM
    #76
    4runningMan
    New Mexico
    Either of those would be fine. But if you have a local auto parts store, the Sylvania Zevo 194/168 are really nice bulbs. Most stores carry them now. You should be able to get a pair for about $14 I think.
  17. Nov 12, 2018 at 5:37 PM
    #77
    d.dodge
    d.dodge New Member
    Nor-Cal
    2018 4Runner 4x4 SR5 White
    -Ceramic Window Tint -SheerComfort Seat Covers -Teton Workshop Shifter -Trail Standard Off-road White Pro Grille -Tactilian Flag Magnets -Toyota Black Badge Overlays -Method Race Wheels NV305’s -Nitto Ridge Grapplers 285/70 -Bilstein 5100 Rear Shocks -Bilstein 6112 Front Coil Overs -Camburg Racing UCA’s -Revtek Suspension Mud Flap Delete Kit
    So what’s the outcome on the bulbs? I want to switch my dome and door lights to LED but all this talk about small current flows and what not. I’m confused. I want my lights to operate properly. On means On, Off means Off.
  18. Nov 12, 2018 at 5:38 PM
    #78
    4runningMan
    New Mexico
    The Philips Ultinon and Sylvania Zevo leds all work just fine.
  19. Nov 12, 2018 at 5:41 PM
    #79
    4runningMan
    New Mexico
    Here's my Bulb list:
    Headlight lo-- H11
    Headlight hi-- 9005
    Fog-- H16
    Reverse-- 921
    Dome- DE3175
    Tailgate- DE3175
    Door-- 168
    Map-- 168
    Puddle-- 168
    License plate-- 168
    (Although there might be a .5w difference, believe 168/194 LED’s are interchangeable— Zevo’s are listed as 168/194 on the package itself)
    DPD327, erfer1 and WallyT4R like this.
  20. Nov 13, 2018 at 8:03 AM
    #80
    jester243
    Dan
    Spokane, WA
    I've had no issues at all since I changed them, they all turn on and off or dim out as they should
  21. Nov 13, 2018 at 2:42 PM
    #81
    kje22kje
    kje22kje New Member
    2017 4Runner TRD Off Road
    Running Boards, LED inside and out, logo overlays, wheel overlays, bug deflector
    Sorry for the silly question but...is there a trick to getting out the reverse light fixture? I tried to swap it out last night and felt like it wouldn't pull straight out and didn't want to turn. I was in a hurry so I didn't want to rush it and thought I'd ask. Thanks.
  22. Nov 15, 2018 at 6:38 PM
    #82
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    No sweat. You have to turn the plastic fixture . It twists about 1/3 of a turn and then pops right out
  23. Nov 15, 2018 at 8:20 PM
    #83
    4runningMan
    New Mexico
    Do you have to remove the tail light housing to replace the reverse 921 bulbs? Or are they accessible from inside?
  24. Nov 15, 2018 at 9:44 PM
    #84
    WallyT4R
    WallyT4R New Member
    Accessible from the inside. https://www.youtube.com/watch?v=SZudKp1R6gg
    jgcaps and 4runningMan[QUOTED] like this.
  25. Nov 16, 2018 at 6:45 AM
    #85
    kje22kje
    kje22kje New Member
    Thanks. It didn't seem like it wanted to turn but it was about 15 degrees so maybe it just wasn't wanting to cooperate. I'll wait till it warms up a minute and give it another go. Appreciate it.
  26. Nov 16, 2018 at 3:28 PM
    #86
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    Maybe push in a little as you twist to relieve the pressure :)
    jgcaps and kje22kje[QUOTED] like this.
  27. Nov 16, 2018 at 5:41 PM
    #87
    4runningMan
    New Mexico
    Those twist and pull sockets can be hard to get out the first time. I think the rubber gasket kinda seats itself on the very first insertion at the factory. Then that fresh rubber sticks and kinda locks it up. After you get it out the first time and break that initial seal. successive times will be easier. Just make sure you're twisting the right direction.
  28. Nov 16, 2018 at 6:05 PM
    #88
    HarveyElmore
    Harvey
    Offroad TRD 17'
    It's also very easy to remove the entire light fixture if needed. I dropped the bulb so I had to take it off to get the bulb out.
  29. Dec 2, 2018 at 1:59 AM
    #89
    NkedFatWhiteGuy
    NkedFatWhiteGuy New Member
    2018 TRD Off Road
    I finally got my map lights both replaced thanks to this thread! I have been going nuts with only one LED in for a couple of months because the darn bulb wouldn’t go in! I took the CRAWL control module out and was able to remove the console so I could replace the bulb from the backside (I wish I would have done this first instead of trying with tape and needlenose).
    Anyway, quick question: did anyone have trouble getting the CRAWL Control box back in tight? I can’t seem to get it to “click” back in place... it is up and functioning just fine, but is not fully clipped in on the front (closest to windshield) and I am worried it is gonna drop while I am driving on rougher roads.
  30. Dec 2, 2018 at 3:40 AM
    #90
    scottalot
    scottalot Stockalot
    Scott
    Charleston SC
    2018 T4R offroad
    To be determined
    I don’t understand what the issue is with removing and installing those bulbs :laugh: it’s a 2 minute job and removing that entire console is way overkill/unnecessary
