How To: 5th Gen LED interior conversion
Discussion in '5th Gen 4Runners (2010-2024)' started by jester243, Sep 5, 2016.
  1. Mar 30, 2017 at 8:23 AM
    jester243
    jester243 [OP] rabble rabble rabble
    Dan
    Spokane, WA
    I agree, Toyota should have sent them from the factory with the LED interior lights. Check with @Dark Knight, I'm pretty sure he changed headlights but I'm not sure on his fogs, maybe pop in his build thread and see. I had a little too much fun last night and I can't seem to remember the brand he went with right now.
  2. May 27, 2017 at 1:28 PM
    44357 New Member
    Eric
    2010 AC Taco - 2017 ORP Quicksilver
    :thumbsup: Great write up!
    @inocoma https://www.4runners.com/threads/what-have-you-done-to-your-5th-gen-4runner-today.2261/ #632
    jester243[QUOTED][OP] likes this.
  3. Jul 1, 2017 at 6:12 PM
    HarveyElmore
    HarveyElmore New Member
    Harvey
    Offroad TRD 17'
    Great write up, thanks
  4. Jul 6, 2017 at 3:53 PM
    Webfoots
    Webfoots New Member
    2016 Sky Silver SR5 4Runner 4x4
    Great write up. Just did my SR5. I removed the upper console for the map lights. Be aware with no crawl control, there are 2 screws holding the console up. They are in the sun glass holder.
  5. Sep 14, 2017 at 5:42 PM
    HarveyElmore
    Harvey
    Offroad TRD 17'
    Enraged Medic and jester243[OP] like this.
  6. Sep 16, 2017 at 1:06 AM
    Enraged Medic
    Enraged Medic Amberlamps Driver Man
    2017 T4R OR
    I switched out my interior lights with LED's from superbrightleds.com and used them before when I had my turd gen taco and also used them on the wife's Camry. Reasonable prices, lots of different light models, and fast shipping.
    My question is, did anyone have any issues using the 31mm festoon for the dome light and tailgate lights? I used a 30mm but didn't realize it was only 17 lumens, so basically, it sucks. Other festoon options are 67 lumens and 95 lumens but are 31mm. I remember having to jimmy/squeeze in a 31mm on the Tacoma but it seems like the T4R can handle it as the 30mm festoon's seemed loose in the dome and tailgate lights.
  7. Sep 16, 2017 at 5:43 AM
    HarveyElmore
    Harvey
    Offroad TRD 17'
    These below fit fine in the rear rear and the center dome. A little more difficult getting them in the dome but fine.
    Festoon: Morimoto XB LED 2.0 LED-M-FESTOON 3
    Festoon Size (+/-1mm)
    1 x 31mm Festoon: Morimoto XB LED 2.0 $15.00
    Ordered the map light bulbs last night.
    Enraged Medic[QUOTED] likes this.
  8. Sep 16, 2017 at 2:41 PM
    Enraged Medic
    2017 T4R OR
    Thanks for letting me know the 31mm fit in the domes and rear. The map lights and doors are super bright for me so it was the dome and rears that were really lacking.
    I also highly recommend for anyone to use these plastic pry tools so you don't damage your doors or housing for the lights. KINGLAKE® Portable 4Pcs Auto Car Radio Door Clip Panel Trim Dash Audio Removal Installer Pry Tool https://www.amazon.com/dp/B00U8OTU3Q/ref=cm_sw_r_cp_apa_wOzVzb1MEXZEH
    MrPhilip likes this.
  9. Sep 20, 2017 at 5:11 PM
    HarveyElmore
    Harvey
    Offroad TRD 17'
    Question: when you say twist it up you mean tighten it tighter to the bulb so you can pull them out? I assume they pull directly down ?
  10. Sep 20, 2017 at 5:41 PM
    HarveyElmore
    Harvey
    Offroad TRD 17'
    https://www.precisionled.com/video-chart-list
    Good install video my problem is the bulb had black tape goo on it so the clear tape would not stick. I guess I could clean the bulb with alcohol or remove the console.
    Update: took 5 minutes to pull down the crawl control, change the bulbs, and put back. I suggest this method. Just follow the instructions in prior posts. Very easy, just after you easily pry down the crawl control button panel and unplug it and take the two screws out pull down the back side which is just held by two pins that come out with just a little force.
    jester243[OP] and Enraged Medic like this.
  11. Sep 20, 2017 at 11:25 PM
    Enraged Medic
    2017 T4R OR
    I'm assuming you used regular scotch tape? I used packing tape (clear tape used for closing up cardboard boxes) that was purchased from the post office. It has much more adhesive. Also you have to tear off just the right amount of tape to get it around the entire bulb. Press firmly on the tape and tug. Bulb should pop right out. This process worked for me on my Tacoma and 4 Runner.
  12. Sep 21, 2017 at 3:51 AM
    alext2280
    alext2280 On Instagram as Jerzydevil_4Runner
    Alex
    Whiting NJ
    2016 Trail Magnetic gray
    LEDs, hidden grill light bar, HIDs 5000k, Rhino roof rack
    Does anyone know if the light in the glove box is replaceable?
  13. Sep 21, 2017 at 9:57 AM
    allthescottsweretaken
    allthescottsweretaken New Member
    Scott
    16 Trail
    Let me know how the puddle mirror light swap goes. I've been wanting to do that on mine too.
  14. Sep 21, 2017 at 5:55 PM
    HarveyElmore
    Harvey
    Offroad TRD 17'
    I think I got too much glue from the other suggestion of electrical tape. I did you packing tape but it would not grab. It was real easy to drop the console.
    jester243[OP] likes this.
  15. Nov 3, 2017 at 8:48 PM
    sjd78
    sjd78 New Member
    Sean
    2018 White 4Runner Off-Road
    Those of you who used the PrecisionLED lights did you use the premium or standard LED's?
  16. Nov 4, 2017 at 9:56 AM
    Rector15
    Rector15 New Member
    2018 4Runner TRD Off Road Premium
    TRD rims, front and rear black valances, black badging, LED interior lighting
    I used standard. The difference between stock bulbs and regular LEDs is quite substantial. I think it was a good purchase - I can’t imagine having the lights be brighter by going premium, if that’s the difference (other than price).
    JBTRD likes this.
  17. Nov 4, 2017 at 10:00 AM
    Rector15
    Rector15 New Member
    I was having trouble keeping the tape on the bulb so I used a longer piece of scotch tape, wrapped the end of the tape around the bulb and held the tape on the bulb with one index finger. I then used my other hand to pull the tape and the bulb came off immediately.
  18. Nov 4, 2017 at 10:04 AM
    Rector15
    Rector15 New Member
    This one was scary because of the fear of breaking the glass but it was pretty straightforward. A plastic pry tool works great. The mirror actually comes off very easily when the vehicle is new but I would think that the build up of dust on the clips holding the mirror may may it tougher over time. I’m a novice when it comes to this kind of stuff and it wasn’t very tough for me.
  19. Nov 5, 2017 at 1:40 PM
    #49
    sjd78
    sjd78 New Member
    Sean
    Which bulbs fit the puddle lights?
  20. Nov 5, 2017 at 2:03 PM
    #50
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    194/168 fit
  21. Nov 22, 2017 at 5:19 PM
    #51
    craigp40
    craigp40 New Member
    Gents, first post here but I wanted to share a quick lesson learned from the great directions provided earlier. Many were complaining about the difficulty taking out the map lights and the resulting need to remove the entire panel or use tape. I was able to do it in about 30 sec per light by simply popping off the lens covers. The key was using a set of inexpensive mini picks I bought from Harbor Freight (pictured below). Using the one with the 45 degree angle, I gently inserted the end behind the bulb and with a little pressure forcing the tip into the base of the bulb while lifting up I was able to simply pop it out easily. I did this with the doors closed so the lights were out while I was probing with the pick. These tools also make pulling out the other fixtures much easier than the plastic pry tools. Just be careful not scratch the plastic. Hope this helps.
    Hrjaw, GhostCat and rsimi72 like this.
  22. Nov 26, 2017 at 10:55 AM
    #52
    deanf
    deanf New Member
    Dean
    '21 4Runner TRD-OR
    You know what would make this thread great? I mean make it the best thread ever on the internet? A bulb list . . . . :rolleyes:
  23. Nov 26, 2017 at 11:28 AM
    #53
    HarveyElmore
    Harvey
    Offroad TRD 17'
    scottalot likes this.
  24. Nov 26, 2017 at 11:31 AM
    #54
    deanf
    deanf New Member
    Dean
    '21 4Runner TRD-OR
    Oh I'm aware of the owner's manual. Notice that most of the information is blank.
  25. Nov 26, 2017 at 5:51 PM
    #55
    HarveyElmore
    Harvey
    Offroad TRD 17'
    Morimoto will give you their replacement number if you email them. Here are a few I changed.
  26. Nov 27, 2017 at 8:59 AM
    #56
    jester243
    Dan
    Spokane, WA
    the guy I ordered from didn't give me part numbers, I just told him what I needed and he got them for me...
  27. Nov 27, 2017 at 4:03 PM
    #57
    craigp40
    craigp40 New Member
    Ok, for those of you who want things really easy without researching a bunch of crap that you don't care about... I have a standard 2016 SR5 and this is what I bought which worked out great.
    If you're like me and get these you'll be perfectly happy. If you super picky and want to analyze lumen output, heat generation, MTBF, price comparisons, etc. you're on your own.
    Go to this website: https://www.superbrightleds.com/
    Order these bulbs exactly and the quantities listed below:
    Lower Door Entry Lights (qty 4): Part Number 194-CWHP5 (https://www.superbrightleds.com/mor...-led-tower-miniature-wedge-retrofit-lan/3305/)
    Map Light (qty 2): Part Number 194-CWHP5 (https://www.superbrightleds.com/mor...-led-tower-miniature-wedge-retrofit-lan/3305/)
    Dome Light (qty 1): Part Number 3110-CW18-CB (https://www.superbrightleds.com/mor...s-led-bulb-18-smd-led-festoon-31mm/4015/8737/)
    Rear Hatch Lights (qty 2): Part Number 3110-CW18-CB (https://www.superbrightleds.com/mor...s-led-bulb-18-smd-led-festoon-31mm/4015/8737/)
    If you didn't notice, the map lights and the door lights are the same. And the dome light and rear hatch lights are the same.
    As a side note, I decided to order one red colored LED for my passenger side map light. It's the same bulb, I just picked a different color. This was primarily so that I could put a light on at night to search for something or read without impacting my night vision.
    Hope this helps.
    Hrjaw, bcs4runny, hurley119 and 7 others like this.
  28. Jan 25, 2018 at 7:46 AM
    #58
    WanderlostOverland
    WanderlostOverland New Member
    1stRunner, jr15642 and HarveyElmore like this.
  29. Feb 4, 2018 at 10:27 AM
    #59
    MeanDean
    MeanDean New Member
    Dean
    Rainier, WA
    '18 4R Limited - Magnetic Grey
    Can't thank you enough, Dan. Awesome how-to with great pictures. Made a huge difference and I probably would not have done this mod without the great write-up.
    I got my bulbs through Diode Dynamics because I did the tail-as-turn module at the same time. Anyone needing more backup lighting should check this mod out.
    If you decide to order from Diode Dynamics, their 168/194 replacement bulbs come in 3 different outputs. The SDM2 (24LM), HP3 (56LM) and HP5 (92LM). This bulb is the same in the doors, map lights, vanity mirrors and license plates. I didn't try the SDM2s, but what I recommend is the HP3 in all locations except the doors where I recommend the HP5.
  30. Nov 1, 2018 at 8:20 PM
    #60
    4runningMan
    4runningMan New Member
    New Mexico
    So is there a huge difference in the brightness/output of those 3 different 168/194 bulbs? Can our trucks run any of the three?
