How many wish they had gone w/o KDSS?
Discussion in '5th Gen 4Runners (2010-2024)' started by java, Apr 15, 2024.
  1. Apr 16, 2024 at 7:49 PM
    #121
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    Yes that would makes sense. As there are more frequent fast up/down movements the worst it’ll be and the hydraulics of kdss will have a hard time keeping up between each side creating a “lag”. Disabling kdss with the press of a button solves this issue
    ideally you’d want the truck to “float”, by having the suspensions absorb each bump individually and independently.
    This is extreme but a good representation or what suspensions should do in high speed off roading:
    https://youtube.com/shorts/rZBwKDnfpnM?si=RdGBsS9zN3VSG6nJ
  2. Apr 16, 2024 at 7:50 PM
    #122
    semprenissart
    semprenissart Mèfi
    @djwantke
    @TRDSD
    djwantke and Yotaholic like this.
  3. Apr 16, 2024 at 8:15 PM
    #123
    Rott4r
    Rott4r New Member
    23 MGM 4Runner TRD orp kdss
    Makes sense. High speed off road isn’t kdss territory. That’s where the trd pro comes in to play.
  4. Apr 16, 2024 at 8:21 PM
    #124
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Such a thing exists in the Jeep world as well, Rubicon versus Mojave. Mojave doesn't have a sway bar disconnect. You can probably disconnect it manually but Jeep wants it to run in the desert
    Rott4r[QUOTED] likes this.
  5. Apr 16, 2024 at 8:27 PM
    #125
    semprenissart
    semprenissart Mèfi
    Yes but with dr kdss switch and better aftermarket than OEM pro suspensions you can do just as good if not better depending on what you choose. In stock form though, your statement is correct
    Rott4r[QUOTED] and Yotaholic like this.
  6. Apr 16, 2024 at 8:29 PM
    #126
    Yotaholic
    Olympia, WA
    Will Dr. KDSS make washboards a little less painful?
  7. Apr 16, 2024 at 8:39 PM
    #127
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    I'm around 2.5/1.5 with no KDSS spacers or anything fancy - did change UCAs though while I was changing things. Still drives amazing in curves - its still pretty unbelievable compared to the one non-KDSS I test drove. @Yotaholic is lifted with it as well and haven't heard issues from him. I've read on this forum to stay below 3" but I think that's pretty standard for all 4runners because you get into bigger builds that need a lot more parts replaced.
    Think I saw a strike through on @djwantke the other day - he may be on a mandatory vacation
    There are some threads on it. It's on my list of things to try if I ever get everything else I've already purchased installed
  8. Apr 16, 2024 at 8:43 PM
    #128
    Yotaholic
    Olympia, WA
    I had two issues, a lean and stock KDSS clamps came off. The lean was because I was not parking the truck on flat surface, and it went away by itself after I parked it on a different spot. And for the clamps issue, I got beefy DR. KDSS ones. So far so good.
  9. Apr 16, 2024 at 8:47 PM
    #129
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    yes, wanted to see if ride was softer over 12 mph. It seemed like it was on the trail I did.
    to know for sure I should probably ride the same trail with and without it plugged in and have a few passengers and not tell them if it’s on or off and see if they can tell a difference
    DrKDSS has a switch you can have on your dash to make it easy to turn on and off at push of a switch
  10. Apr 16, 2024 at 8:50 PM
    #130
    flight
    flight New Member
    I've had both versions of the switch. With Icon stage 7 and e load tires, I'm not too sure if I can really feel a big difference on wash boards testing around 15psi and also at my on road 40ish psi. I'd say it's situational, and non KDSS are much smoother at speeds.
    I've also removed the front kdss sway bar, everything is MUCH smoother but I wasn't a fan of the handling for my needs.
  11. Apr 16, 2024 at 8:51 PM
    #131
    FN2187
    FN2187 Stormtrooper
    Earth
    Oh yeah, I forgot you had issues with your clamps. I should probably check mine but I don't flex as hard or as often as you so they're probably fine. Adding it to the spring mx checklist
    Yotaholic[QUOTED] likes this.
  12. Apr 16, 2024 at 8:52 PM
    #132
    semprenissart
    semprenissart Mèfi
    It should BUT I’ve only experienced the 4R with kdss (friend) or without it (mine) but not with kdss disabled from drkdss switch. However I’ve heard a lot of good things about it so I’ll let people that actually have done the mods answer that question for you. If I had kdss I would definitely install the switch
    Rott4r and Yotaholic[QUOTED] like this.
  13. Apr 16, 2024 at 8:53 PM
    #133
    semprenissart
    semprenissart Mèfi
    :(:help:
    Yotaholic likes this.
  14. Apr 16, 2024 at 8:54 PM
    #134
    Yotaholic
    Olympia, WA
    Yep, it is legit
    2ndGen22re, Rott4r and semprenissart like this.
  15. Apr 16, 2024 at 8:56 PM
    #135
    flight
    flight New Member
    Rott4r, semprenissart and Yotaholic like this.
  16. Apr 16, 2024 at 8:56 PM
    #136
    Klinsman55
    K
    Northern Nevada
    2024 LE silver
    It does trigger an alert on display and I had option to ignore it with push of button.
  17. Apr 16, 2024 at 9:04 PM
    #137
    Rott4r
    Rott4r New Member
    I’m going to look into that switch. I see It as it will do more good then harm.
  18. Apr 16, 2024 at 9:19 PM
    #138
    Klinsman55
    K
    Northern Nevada
    2024 LE silver
    what suspension you have and how much lift?
    I’m thinking of a Bilstein 1.2” to 1.6” lift but wouldn’t want to do that if it makes my ride more stiff and clamps to come off
  19. Apr 16, 2024 at 9:26 PM
    #139
    Yotaholic
    Olympia, WA
    OME 2.5" I think
    Klinsman55[QUOTED] likes this.
  20. Apr 16, 2024 at 9:33 PM
    #140
    Rott4r
    Rott4r New Member
    I have the Dr kdss clamps and those adapters. Havnt installed them yet, didn’t need the adapters since my bushings are not stressed or angled at 2.25” lift. I’ll save them for the future when I upgrade to a better suspension. Never looked at his switch since it wasn’t something I thought I needed.
  21. Apr 17, 2024 at 5:55 AM
    #141
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
  22. Apr 17, 2024 at 6:16 AM
    #142
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I just learned more about it. I thought Limited had largest sway bar, but KDSS has 42mm and hydraulic front sway bar links that look like they raise and lower the bar for more articulation. If your suspension doesn't have enough travel on extension I don't think disconnects will help much. I just raised mine and I may lower it and inch in front for more decompression travel. That said I always made it where I was going and back without all that stuff. 4runner Pro means the vehicle is equipped for off road even if the driver isn't. Good tires and driver mean the most on 4runner. I used 5100s and I'm very satisfied. I just got more lift than intended with OME and 5100s on top setting. I read and researched, but you never know until your done. I reset my struts 3 times and just got tired. I used 2" lift rear to level with front. My Xreas rear springs felt to mushy. It rides and drives great now. I ended up about 4" of lift and used adjustable sway bar links which actually seem unnecessary now. Extended would probably be fine ,but they are all about the same expensive price like a bump stop. I used Energy suspension bump stops from 3rd gen rear for front on mine for $22.
  23. May 12, 2024 at 11:43 PM
    #143
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hahaha yes sir
    I’m in Mexico on vacation
    But I was sleeping in the doghouse since April 12 :)
    2Toys and Yotaholic like this.
  24. May 12, 2024 at 11:44 PM
    #144
    Dr KDSS kill switch is excellent yes
  25. May 13, 2024 at 6:45 AM
    #145
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    If the roads you drive on do not heavily exercise the 4r’s suspension then kdss may have diminishing value.
    We have lots of mountain twisties here. I have driven a 5gen sr5 and it felt downright dangerous, at the speed I’m accustomed to driving.
    With kdss, my 4r feels like a typical Subaru cuv, carving up the mountain roads
    Ripper238 and RUNNER4DAN like this.
  26. May 13, 2024 at 6:48 AM
    #146
    Yobruhitsme
    Denver
    Ineos Grenadier
    Sharing the kdss tool amongst dealers - That should tell you it doesn’t fail that much!
    Ripper238 and Acesandeights like this.
  27. May 13, 2024 at 9:20 AM
    #147
    Yotaholic
    Olympia, WA
    Ha!
  28. May 13, 2024 at 12:13 PM
    #148
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    2024 4Runner OR Solar Octane
    Or maybe it's the fact that kdss only exists on the 4runner for Toyota models (and even then not all 4runner models) so why bother investing in a big money tool that would only see limited use and Toyota will just lend the tool out.
  29. May 13, 2024 at 12:34 PM
    #149
    Yobruhitsme
    Denver
    Ineos Grenadier
    Land Cruiser 200 has them too
  30. May 13, 2024 at 1:39 PM
    #150
    garoto
    garoto New Member
    But… the fact that it needs such rare special tool is bound to be a risk one is willing to take with regards to long term ownership.
