How many are going to trade for a 6th Gen?
Discussion in '5th Gen 4Runners (2010-2024)' started by hutch993, Dec 12, 2024.
  1. Mar 5, 2025 at 10:34 AM
    #541
    LA260
    LA260 New Member
    I'll take a look at the 6th gen after the mid-cycle refresh. It's the best time to get into a new car.
  2. Mar 5, 2025 at 10:43 AM
    #542
    I've had offers from Toyota dealerships to buy my 2018 since 2019 :notsure:
  3. Mar 5, 2025 at 10:52 AM
    #543
    Once they get your contact info they do anything to get you back into the dealership.
    icebear and nimby[QUOTED] like this.
  4. Mar 5, 2025 at 11:45 AM
    #544
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    Last November in for my first "free" oil change and my service advisor checking me in sheepishly said "I'm pretty sure I know the answer, but any chance you might be interested in selling us this truck? I know a guy right now who would die to have this one." I said maybe he should have bought one when I did, and no thanks to the sales offer.
    LCJ77 likes this.
  5. Mar 5, 2025 at 12:08 PM
    #545
    Doing whatever it takes to improve fuel economy = selling out?
    You know they can be removed, right?
  6. Mar 5, 2025 at 12:38 PM
    #546
    When I sold my 2003 TJ Rubicon & 2013 Tacoma TRD Off Road in 2019 to purchase my current 4R, I pretty much knew then it would be my last new vehicle purchase. Other than for a rodent-chewed injector wire 3 weeks into ownership, my 4R has not seen the inside of a Toyota service department since it's first "free" Toyota Care visit, and once for an alignment after I put on my Eibach shocks in 2020. There's no reason on earth to even consider replacing it with a 6th gen.
    toy33 likes this.
  7. Mar 5, 2025 at 1:10 PM
    #547
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    A notable percentage of people aren’t comfortable or equipped to crawl under and uninstall. I am aware it can come off. No one knows yet how easy.
  8. Mar 5, 2025 at 1:30 PM
    #548
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    We as Toyota people like reliability, usability, and simplicity. The 5th gen just works.
    I would put my years salary on the line to see which motor and trans combo lasts longer. The 1GR-FE & 5 speeed or the 2.4T with 8 speed.
    hint hint; it’s the 5th gen.
  9. Mar 5, 2025 at 1:52 PM
    #549
    Then, those people can leave it on and enjoy a .002% increase in fuel economy. :notsure:
    People took them off 3rd gen Tacos. If all else fails, use a Sawzall.
    icebear and Trail Runnah like this.
  10. Mar 5, 2025 at 1:57 PM
    #550
    Nobody would take you up on that bet.
    But, if the T24A can go a few hundred thousand miles while providing better potential fuel economy and more power, people will be satisfied.
    nimby and RkyMtnMan like this.
  11. Mar 5, 2025 at 2:43 PM
    #551
    FourBelugas
    FourBelugas New Member
    23 white ORP
  12. Mar 5, 2025 at 3:07 PM
    #552
    The dumb, ugly, impractical “wind blocker” shouldn’t even be there, it’s the largest wind blocker in the history of wind blockers.
  13. Mar 5, 2025 at 3:10 PM
    #553
    don’t get me wrong I agree with you. That is my point exactly is that it improves Fuel economy by almost nothing but like the second time ever that you parked the vehicle That annoying thing is going to be catching and scraping on the curb and then you’re that guy that everybody’s looking over at
  14. Mar 5, 2025 at 3:12 PM
    #554
    Leave it on and let it get beaten and ground down as a badge of honor.
    dgrenier15 and Thatbassguy like this.
  15. Mar 5, 2025 at 3:21 PM
    #555
    TFL took theirs off immediately, they said it took about 5 minutes and was a few bolts.
    I would say if one can't handle that, they don't need to take it off in the first place, because they shouldn't be anywhere but on the pavement within range of AAA.
  16. Mar 5, 2025 at 3:26 PM
    #556
    Oh, they're definitely going to get smashed on curbs. I agree. It's just Toyota doing their part to keep up with CAFE.
    Honestly, though, if something like that would actually make a significant difference, I would gladly bolt one on for long road trips.
    icebear and djwantke[QUOTED] like this.
  17. Mar 5, 2025 at 3:34 PM
    #557
    Imdav2u
    23 TRD PRO
    Or just keep your 5th gen. It looks better and will probably outlast the 6th gen.
  18. Mar 5, 2025 at 3:38 PM
    #558
    I’m definitely keeping my 5th gen for a long time. It will become my kids car eventually. I will need to buy something new at some point.
  19. Mar 5, 2025 at 4:46 PM
    #559
    TrailSpecial22 New Member
    PA
    No way never for the 6th gen.
  20. Mar 5, 2025 at 6:42 PM
    #560
    Ya you know I would enjoy better fuel mileage on trips if I could attach something like that. Still trying to figure out how I can glue my viper cut pieces back on :rolleyes:
  21. Mar 5, 2025 at 6:43 PM
    #561
    at least the largest wind blocker in history goes well with the largest and shiniest fenders
  22. Mar 5, 2025 at 7:01 PM
    #562
    :puke:
  23. Mar 5, 2025 at 7:07 PM
    #563
    That’s the PRO too, big coin in Canada for that beauty
  24. Mar 5, 2025 at 7:16 PM
    #564
    these are almost better looking fenders :rimshot:
    Turd Ferguson likes this.
  25. Mar 5, 2025 at 8:07 PM
    #565
    4Daughters
    4Daughters It’s how I know God has a sense of humor
    Ken
    Powder Springs, Ga
    2022 TRD ORP; Silver; too many port options...Ah well...
    TBD
    Saw my first 6th gen today. (Sorry, no pix but iPhones distort them anyway). White ORP. To my eye everything from the cowl forward looks strangely out of proportion, too large by about 5%. The roof line is notably higher than my ‘22. I’m just not sold on the new styling.
    ChessGuy likes this.
  26. Mar 5, 2025 at 8:26 PM
    #566
    That's what I thought too. Everything seems bulky and big for no damn reason. I pulled on the door handle and it felt cheap and weak. It wasn't for me either.
  27. Mar 5, 2025 at 8:29 PM
    #567
    I thought the same. The hood looks too long.
  28. Mar 5, 2025 at 8:38 PM
    #568
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Come on everyone, you know how styles come back around
  29. Mar 5, 2025 at 8:40 PM
    #569
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    Do viper cuts effect fuel economy? I was actually toying with the idea of cutting mine soon. The front end of the 4Runner just looks too bulky for my tastes. Then again, so does the butt, but that's an even tougher fix.
  30. Mar 5, 2025 at 9:48 PM
    #570
    I mean an aggressive viper cut can’t be good for aerodynamics, and I hear it can mess with you if there’s strong side wind. Word of advice, don’t go as aggressive as me on the cut it’s overkill. Certainly my mods and rack have ravaged my aerodynamics, coupled with added weight.
    As for the butt end, I cut that off too actually.
