Hood Scoop Water Leak
Discussion in '5th Gen 4Runners (2010-2024)' started by garoto, Apr 2, 2024.
  1. Apr 7, 2024 at 11:33 AM
    TroutMan
    TroutMan New Member
    What I find is that it only really leaks when the car is nose down. Level or nose up seems to be fine. At least that's what happens in my case - my driveway has a good slope and if I leave it nose down and it pours, the insulation inside the hood can end up wet.
    garoto[OP] likes this.
  2. Apr 7, 2024 at 12:33 PM
    garoto
    garoto [OP] New Member
    On level surface for me, it rained last night and the insulation was damp.
    With a power wash, wet quite a bit but does not penetrate through.
    Gotta see what happens if it rains while driving, but I assume that will be the least wet.
    It also ends up wet if I pour water or hose it down directly on it
    Saker likes this.
  3. Apr 7, 2024 at 12:57 PM
    Saker New Member
    21 Black T4RORP
    Gotta ask,
    1. When you install the scoop, does it feel like the fasteners get snug before you feel the scoop seal?
    2. Maybe a recommendation to get your scoop to seal without too much headache.
    Buna-N O-Ring Splicing Kit
    Might be worth a try!
    garoto[QUOTED][OP] likes this.
  4. Apr 7, 2024 at 3:11 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @garoto
    Direct water pressure on hood scoop, similar to touchless wash. More than enough time elapsed while soaking.
    Water does not penetrate carpet. Dry to touch, but perhaps it could soak over a day and feel damp (hence my white water stains). No water leaked into engine bay anywhere else.
    I slid my hand under the carpet, it is wet down in there from washing.
    That being said, only a couple water drops came out from underneath hood carpet in one spot at the bottom edge, after hood stayed open.
    Conclusion:
    The hood scoop isn't as fake as the haters say.
    If it lets water in, it lets a little air in for extra HP
    Saker and garoto[OP] like this.
  5. Apr 7, 2024 at 3:12 PM
    garoto
    This recommendation is super cool. I’m not too worried about the fact that it leaks, it honestly feels very normal. Even if I were to get the seal to be perfect, by Toyota instructions the seal at the top carries a 1” gap between seals in two parts. So 2” gap total between seals where there is zero seal. Furthermore, the fake vent itself has zero seals by design and will leak no matter what, even the one that I took off leaks in the faucet, it’s inevitable.
    that said, I like this kit and may very well use it to fix what Toyota failed to do.
    Saker[QUOTED] and djwantke like this.
  6. Apr 7, 2024 at 3:20 PM
    garoto
    Hey, thanks so much for checking it out! Yes, it takes a bit to penetrate the carpet, it beads for a bit and unless it sits it will slide off because the carpet has “deep channels” inside that can’t be seen or felt from the outside. (I’ll share a photo later). Overall, it sounds like you’re seeing at least some water, which makes it feel rather normal. From my analysis, it’s impossible for water not to leak to to absence or any seal in the “fake vent” itself and how it attaches to the fake scoop, as well as how the fake scoop seals against the body, you can see in my original photo that Toyota recommends two “1 inch” gaps at the top between two seals.
    djwantke[QUOTED] likes this.
  7. Aug 28, 2024 at 5:53 PM
    garoto
    My Solution, documented.
    1. I wanted to prevent water from getting through the scoop or screw holes.
    2. I needed it to still fit flush and clean.
    3. I wanted to prevent the damage to the hood paint. It is happening, and even after touching it up it went through that. Even after PPFng that spot it screwed up the ppf.
    My solution involved thick EPT sealer up front. Gaskets on each side to lift the side from touching the hood but just enough that it’s still clean and flush. Prevent as much water intrusion as possible. The rear will still have minor water intrusion (very minor) because Toyota must leave gaps so that the hood scoop and hood enter each other at the hood scoop crease. There are no way around it.
    After my install about 99.9% of any water intrusion stopped.
