Help with hyperflashing LED's
Discussion in '5th Gen 4Runners (2010-2024)' started by Rdesouza74, Jan 9, 2020.
  1. Jan 22, 2020 at 8:58 AM
    Rdesouza74
    Rdesouza74 [OP] New Member
    Ricardo
    07 4runner
    Nomods
    i checked again this morning, no bulbs are burned out
  2. Jan 22, 2020 at 9:02 AM
    Rdesouza74
    Ricardo
    07 4runner
    Nomods
    these are the ones i have on now
    SIRIUSLED 1156 Anti Hyper Flash Built-in load resistor True 25W Amber Extremely Bright LED Bulb for Turn Signal Only 1156A
  3. Jan 22, 2020 at 9:17 AM
    TRDPro916
    TRDPro916 New Member
    4Runner Pro
    Currently stock; MODS coming soon.
    I have a 2019 4Runner Pro and I got no issues..
    Front and Rear turn Signals: w/LED ENDPAGE 4 qty
    Reverse light: LED SEALIGHT 912
    Front DRL/High Beams: Vouke 9005 Anti Flicker Resistors and BEAMTECH LED Headlight Bulb
    At first I went with SIRIUS decoder resistor and it didn't work, so I changed and got Vouke and it out great!
  4. Jan 22, 2020 at 9:25 AM
    Rdesouza74
    Ricardo
    07 4runner
    Nomods
    my headlights, high beams and fog lights are beamtech.
    reverse, brake lights, front and rear turn signal are from sirius. i didnt see a endpage for my front signals.
    are your DRL's the yellow ones or with your headlights on your 2019? mine are by the bumper as seen on the brief clip i took this morning.
  5. Jan 22, 2020 at 9:28 AM
    TRDPro916
    4Runner Pro
    Its with the headlights. Not yellow; the DRL/High Beams operate as one.
  6. Jan 22, 2020 at 9:36 AM
    Rdesouza74
    Ricardo
    07 4runner
    Nomods
    on mine are the yellow ones on the bottom, could that be the issue then? or are each model of the 4runners built with their own features? because my lights are definitely not on only the yellow ones.
  7. Jan 22, 2020 at 9:44 AM
    TRDPro916
    4Runner Pro
    Picture of headlight?
  8. Jan 22, 2020 at 9:47 AM
    Rdesouza74
    Ricardo
    07 4runner
    Nomods
  9. Jan 22, 2020 at 9:49 AM
    Rdesouza74
    Ricardo
    07 4runner
    Nomods
  10. Jan 22, 2020 at 10:07 AM
    Rdesouza74
    Ricardo
    07 4runner
    Nomods
    do you think its possible since my DRL lights are also the turn signals, and the bulbs currently in there now are only for signals, that im having this issue?
  11. Jan 22, 2020 at 11:20 AM
    TRDPro916
    4Runner Pro
    Its weird because you are using the LED lights with the resistors. If they are yellow, I would just put in the OEM bulbs
  12. Jan 22, 2020 at 11:25 AM
    Rdesouza74
    Ricardo
    07 4runner
    Nomods
    ive been reading up on this some more and the only other thing i can see is that the LED's i have in there now, even though they have the built-in resistors, they are only for turn signals only and i may need the ones that are turn signals and DRL. would that make sense?
  13. Mar 8, 2021 at 12:54 AM
    Dark Knight Yotas
    Dark Knight Yotas New Member
    Wait does that unit from DIODE DYNAMICS also work if your turn signals are your day time running lights??
  14. Mar 8, 2021 at 8:34 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
