Help! 2021 4Runner won’t start!
Discussion in '5th Gen 4Runners (2010-2024)' started by code3runner, Nov 8, 2021.
  1. Nov 9, 2021 at 11:32 AM
    jester243
    Dan
    Spokane, WA
    I have heard of that but only when the battery in the fob was dying but man that shouldn't be an issue on a 2021 already, I'd see if they can swap a new one in for you.
  2. Nov 9, 2021 at 12:05 PM
    Sounds like you’re on to something, the key/smart key immobilizer system.
    you shouldn’t be having any issues with a brand new truck.
    I would pull your mods long enough to make the dealership make it right with the keyless system.
  3. Nov 9, 2021 at 12:55 PM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    ....and these days a gabizilillion computers.
  4. Nov 9, 2021 at 1:41 PM
    Notcris
    Notcris New Member
    Austell, Georgia
    2021 4runner Lunar Rock Trd Pro
    You said you had aftermarket lights so maybe it's the fuse that the drl uses?
  5. Nov 9, 2021 at 2:39 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    You did a hard reset which cleared the systems awareness of a problem that may or may not return. Time will tell.
    2Toys and nimby like this.
  6. Nov 9, 2021 at 3:15 PM
    code3runner
    code3runner [OP] New Member
    2021 4runner
    which is more than the dealer did lol.
  7. Nov 9, 2021 at 3:42 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    so you did electrical wiring modifications on your new 4 runner ,you have to check the wiring harness
    Toyota 4Runner: Pressure Control Solenoid "D" Electrical (Shift Solenoid Valve SLT) (P2716 look it up !
    engine cranks and the engine does not start ....check the fuel pressure/fuel pump ..many had these tacoma/4runners new.
    jester243 likes this.
  8. Nov 9, 2021 at 4:10 PM
    The problem hopefully stays away with the reset. But after you check through fuses and wiring, i would suggest powering the switch pro with it’s own power directly from the battery, if possible. I would think that would be safer for the electrical system.
    You just never know if that tap draws enough, even when lights are off, to mess with what the various computers are expecting to see.
    DRobs, 2Toys and nimby like this.
  9. Nov 9, 2021 at 4:20 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    They likely didn't clear it so they could look for the source of the fault if you decided to have them troubleshoot it.
    jester243 and McSpazatron like this.
  10. Nov 10, 2021 at 4:22 AM
    code3runner
    2021 4runner
    Pulling the electrical components off today and putting it back to stock.
  11. Nov 10, 2021 at 4:23 AM
    code3runner
    2021 4runner
    Also, the dealer did give me a full refund.
    McSpazatron and Wvmoonshiner like this.
  12. Nov 10, 2021 at 5:31 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    That's a plus!
  13. Nov 10, 2021 at 6:41 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Kind of like an Airbus A-320. Happens often to those. Sometimes they just wake up "grouchy" on power-up. Sort of like a Windows computer...
  14. Nov 10, 2021 at 7:21 AM
    That there, is scary as shit.
  15. Nov 10, 2021 at 8:07 AM
    DRH
    DRH TRD Broverlander Extraordinaire
    Dave
    Santa Clarita, Ca
    2020 ORP
    With these vehicles it is important not to mess with the factory electrical systems unless it is unavoidable. The only electrical modifications that I have done that could not be avoided with an aftermarket fuse panel off the battery were switch backlight dimmer function and attaching to the head unit for camera upgrades.
    Rocksurfer likes this.
  16. Nov 13, 2021 at 4:25 PM
    jester243
    Dan
    Spokane, WA
  17. Nov 28, 2021 at 12:13 PM
    code3runner
    2021 4runner
    After the reset, I haven’t had any issues. I’m curious as to what caused my check Engine light to come and the immobilizer to be engaged
  18. Nov 28, 2021 at 3:57 PM
    j cat
    j cat New Member
    massachusetts
    so you removed your electrical mods and then the vehicles has no codes and no issues ?
  19. Dec 7, 2021 at 1:12 PM
    #49
    code3runner
    2021 4runner
    No. I reset the ecu by pulling the negative battery cable.
  20. Dec 7, 2021 at 1:31 PM
    #50
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
    I already hate flying. I didn’t need to know that.
  21. Dec 7, 2021 at 1:37 PM
    #51
    jester243
    Dan
    Spokane, WA
    have you re-installed your mods?
  22. Dec 7, 2021 at 1:46 PM
    #52
    code3runner
    2021 4runner
    i never uninstalled them.
  23. Dec 7, 2021 at 7:59 PM
    #53
    code3runner
    2021 4runner
    So I’m back at the dealer. Same issue…
  24. Dec 7, 2021 at 11:12 PM
    #54
    If you have the money you can pay them to sort it out. But if you have a spare car then it might be easier (maybe even less hassle) for you to trace down the circuit that’s causing problem, or just rewire straight to battery. I’d be suspicious of any taps into other circuits.
    i think I saw some comments somewhere (maybe on a youtbe vid) about someone that had issues with the car shutting down after some aftermarket headlights were installed. They traced it to a tap they made on a fuel injector circuit/fuse
    2Toys and jester243 like this.
  25. Dec 8, 2021 at 3:53 PM
    #55
    Sandbuster
    Sandbuster Breaking Wind
    Central Florida
    2019 TRD Offroad
    The more I read on the "new & improved" 4Runner technology the happier I am with my old 2019 technology. At some point in automotive technology the KISS factor needs to prevail: Keep It Simple Stupid....
  26. Dec 8, 2021 at 7:21 PM
    #56
    2Toys
    Gordon
    2019 4Runner TRDORP
    Sorry about that, it is reality with computer controlled aircraft. It happens with the Dassault Falcon 2000LX I take care of also. The Honeywell EPIC avionics system is based on MicroSoft Windows operating system. Not the current version either. It wakes up grumpy often.
  27. Dec 8, 2021 at 7:25 PM
    #57
    :lalala:
    If it’s not Boeing Im not going.
    Will that mantra keep me safe? Lol
    2Toys[QUOTED] likes this.
  28. Dec 8, 2021 at 8:21 PM
    #58
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I have done quite the mods on my 2020 4Runner. I started having electrical gremlins as well. I would be driving down the road and when I went to brake my entertainment system and dash would reboot. It did this intermittently. I have almost everything aftermarket going to my switch pro. I replaced almost every bulb inside and outside my car to LED. I had an air compressor, bunch of aftermarket lights, winch etc.
    My winch connects directly into the battery terminal which connects to a control box and from there to the winch. I would have never in my wildest dreams thought it was my winch controller. I started disconnecting my mods. I literally had it sitting in my driveway and I would tap the brakes, System would reboot. So I kept the car on and started removing my mods. The situation stopped after disconnecting my winch and ARB air compressor. So after validating over the course of that day the issue was resolved I hooked the ARB back up. Issue hasn’t returned and that leaves the winch as the problem. I believe water may have got into my control box and shorted the control box which resulted in crazy electrical gremlins.
    To say it is not your aftermarket parts would be looking at the issue blinded. Not saying Toyota never messes up, but honestly I believe they have some high quality control on their stuff and they have a lot of customers without issues (not saying issues don’t arise). As an engineer that literally is what I do all the time when problems arise. Bring things back to where everything was just fine. Then slowly add parts. Or in my case slowly start removing stuff and narrow down the cause.
    In your case it would be simple to just disconnect the switch pro and put the fuse back the way it was. This way you undid everything. If all else fails your back at stock and the dealership covers it under warranty.
    Best of luck. Hope it gets fixed sooner rather than later.
    McSpazatron, 2Toys and Slopemaster like this.
  29. Dec 8, 2021 at 8:38 PM
    #59
    4R21
    4R21 New Member
    AK
    Land of Cheese
    LOL @ WAKE up grouchy
    I had a machine wake up grouchy today
    But now its happy. So am I :amen:
  30. Dec 8, 2021 at 10:14 PM
    #60
    2Toys
    Gordon
    2019 4Runner TRDORP
    I wish I could tell you that Boeing aircraft are better. They used to be, right up to the Boeing 787. It is like Boeing has lost their minds, and forgot how to design a safe and reliable aircraft. How magnificent the B-777 is, the 787 has been a nightmare. It still is to a degree. Then the 737 MAX... well, now we know they did lose their minds (in management, anyway) with the MCAS debacle.
