Heavier tires kill acceleration? Or it’s just all in my head?
Discussion in 'General 4Runner Talk' started by Tacticalchaplain, Jul 30, 2023.
  1. Aug 12, 2023 at 4:11 PM
    Tacticalchaplain
    Tacticalchaplain [OP] New Member
    2016 TRDP
    Well, the tire shop I got them from does not have a 30 day warranty, so I’m stuck with them… just Got Them Road forced balanced today. I have a road trip on the highway next week so we will see if at least the shakes and shimmy is corrected. Soon as I got them not only did it feel slower, 50mph to 80mph on and off wheel vibrations and at times shakes… so annoying.
  2. Aug 12, 2023 at 5:53 PM
    That sucks. Try a pedal commander or sprint booster.
    Tacticalchaplain[OP] likes this.
  3. Aug 12, 2023 at 8:44 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I feel for ya damn.There must be more going on than the 6lbs a tire or whatever. Everyone and their dog has Wildpeaks, and the pitch from every shop is that there is "zero" complaints so far. The shaking happens to lots of Runners regardless of tire manufacturer, that's a tough one.
    Dude, I'd invest in pedal commander, from personal experience; each one of my wheels is 85lb
    Goodluck
  4. Aug 12, 2023 at 8:59 PM
    Tacticalchaplain
    2016 TRDP
    well, enough of you have mentioned the pedal commander that I will look into it now…
    The shop that did the road force made it sound like my suspension needed replaced as well because the front shocks are leaking and they said the control arm bushings are going bad… but I stopped at the shop that I got the tires and who does my regular maintenance, and they said just because the shocks are leaking and the bushings are starting to show a little wear doesn’t mean that it’s hurting performance or unsafe… but the other freaking shop made it sound like I needed to get a lift kit right away or the truck was gonna break down… “ go get the parts for the lift kit and bring it back. We’ll do the install, put on a new belt, and do the rear brakes.” Jesus. They also said that my rear brakes at 40% but they would do them soon and the belt needed replaced… but the other shop looked at the belt with me and said it looked fine… and the suspension was fine with the worn Toyo AT3s and not shaking or shimmying … but I did have to get them road force balanced as well initially.
  5. Aug 12, 2023 at 9:21 PM
    That's great details to know, sounds like you've been through the ringer. The fact that these things weren't an issue when you had your old Toyo's tells you all you need to know.
    *Shop's are a business that make money off orders and installs. Of course they said that shit, sometimes they're not as much as your friend as you think they are regardless of affiliation
    nimby likes this.
  6. Aug 12, 2023 at 9:24 PM
    DesertSurfer
    There is also pedal monster by Banks that many folks have said they believe to be superior to pedal commander.
    Rob41 and Tacticalchaplain[OP] like this.
  7. Aug 12, 2023 at 9:30 PM
    :eek:
    tell me more lol
  8. Aug 12, 2023 at 9:37 PM
    Tacticalchaplain
    2016 TRDP
    oh, they were all like we are so pro police and military (I’m a one-man nonprofit for All First Responders, and Veterans, but primarily police) … talking up how much they give a break to first responders and Veterans…. And then hit me with a laundry list of stuff they say needs repaired.
    The other shop does not specialize in 4x4, but a lot of the mechanics there do you have nice rigs and I have been going there for 14 years… they’ve given me a free oil changes, there’s been some times when I blew out a 33 inch tire on one of my pick up trucks and they had a set of 33s that somebody left their that they hooked me up with free… and this supposedly pro police and Veteran off road is telling me that those guys must be terrible and there’s no way that an alignment would have held with how bad my control arm bushings are… but I went right back to the other shop after and on the spot they went through everything with me and we’re just laughing at what a bunch of bullshit shops are like that and dealers… yeah, they said my shocks needed replaced, control arms, brakes, belt, etc…
  9. Aug 12, 2023 at 10:09 PM
    Tacticalchaplain
    2016 TRDP
    Great now it’s going to get confusing trying to read all the threads on who likes What better of the 3
  10. Aug 13, 2023 at 6:21 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Get in touch with the guys of kdmax(there's a thread on here) and have your 4runner tuned.
  11. Aug 13, 2023 at 8:12 AM
    Tacticalchaplain
    2016 TRDP
    I am looking at the thread and I see raving reviews, and that it makes the SPRINT booster or pedal commander obsolete… so is it something similar but just more personalized for your vehicle? Did not see in the thread, the explanation of why it makes the other products obsolete.
    I will reach out to the guy in SoCal
  12. Aug 13, 2023 at 8:14 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    The weight will definitely effect performance, and a pedal commander (though cool) just increases peddle response, no additional power over just stepping on the gas more.
    I made sure to get as close to stock weight as possible and not to over buy, like E load which are way overkill for the majority of users and come with many compromises besides weight. I went with C load A/T's and they have preformed very well in all conditions and didn't make my 4R sluggish.
  13. Aug 13, 2023 at 8:22 AM
    Just a reminder when people go with C Load, in some tires Load C is lighter than some standard load tires vs with some tire manufacturers Load C is heavier than Load E. Below example comparing 2 famous tire manufacturers with their SL, Load C & Load E options in same size.
    VS -
  14. Aug 13, 2023 at 8:27 AM
    Tacticalchaplain
    2016 TRDP
    I was very happy with my Toyo AT3s but they had so much nail damage. One of the plugs was not holding and I was literally getting ready to drive from Los Angeles to San Diego and needed new tires ASAP… so I didn’t do enough homework to realize how heavy the damn wild peaks are even I in SL…
    Ripper238[QUOTED] likes this.
  15. Aug 13, 2023 at 8:53 AM
    Xombie2000
    Xombie2000 New Member
    2016 4RUNNER trail
    I like my General grabbers.
  16. Aug 13, 2023 at 10:16 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    The tune can adjust the throttle response (which is what a pedal commander does) plus does so much more. I have the kdmax tune and love it. For the price its definitely worth a try.
    Also maybe try running a little more air pressure, nothing crazy 35-37psi
  17. Aug 13, 2023 at 1:56 PM
    Yes sir a tune does make pedal commander and sprint obsolete. There's a major difference in price and result that's why
  18. Aug 13, 2023 at 2:23 PM
    Tacticalchaplain
    2016 TRDP
    I already have an email and just to see what the price is for the tune in my area.
    hossler1788 likes this.
  19. Aug 13, 2023 at 4:12 PM
    #49
    Yoda_Mike
    Yoda_Mike New Member
    Michael
    South Glens Falls, NY
    2019 Toyota Tacoma TRD Sport
    I read an interesting article the other day on how rotational weight translates to static weight. I believe the conversation was about 11:1. So for every pound of rotation weight, the equivalent static weight would be 11lbs. Really puts it into perspective how heavy tires and wheels can negatively impact performance!
    The tune will help a lot with this for sure! By adjusting various parameters in the trucks engine and transmission computers we are able to considerably improve the throttle response, acceleration, low/mid-range power, and overall drivability of the vehicle. I think you’ll be very pleasantly surprised by the outcome! I know I was on my Tacoma. It’s the whole reason I joined the team! Dave is one of the OGs in the game too. There’s none better to work with! He will get you right, I have no doubt!
  20. Aug 14, 2023 at 7:08 AM
    #50
    Ripper238
    2019 TRD OR
    Maybe that's why I have been seeing more "pizza cutter" (narrow tires) tires as of late?
  21. Aug 14, 2023 at 7:15 AM
    #51
    Yoda_Mike
    Michael
  22. Aug 14, 2023 at 12:50 PM
    #52
    Tacticalchaplain
    2016 TRDP
    great article … I’ll never buy tires again without comparing weights … hard lesson learned
    makes me wonder too about some folks in SoCa on various popular 4x4s throwing steel old school rims on brand new expensive rigs.
  23. Aug 14, 2023 at 12:55 PM
    #53
    Ripper238
    2019 TRD OR
    Everything has its purpose. If I was rock crawling I may go heavy E load and a set of steel rims since a steel rim can be fixed out on the trail.
  24. Aug 14, 2023 at 12:59 PM
    #54
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Really make you wonder with the overland tend. With the heavy bumpers/winch/roof top tent/e rated tires/ etc...They are probably getting 13mpg or less.
  25. Aug 14, 2023 at 1:23 PM
    #55
    Tacticalchaplain
    2016 TRDP
    well, I can assure you most of the vehicles I see in these affluent beach towns are not hitting the trails or any rocks… there are people that probably don’t even know how to put the transfer case into four-wheel-drive….
    Ripper238[QUOTED] and RusPro17 like this.
  26. Aug 15, 2023 at 2:20 PM
    #56
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    Every pound saved from rotating weight is equivalent to 8.4 pounds of static weight. Adding 5 pounds of tire per wheel is like adding another 165 pound passenger.
  27. Aug 15, 2023 at 2:33 PM
    #57
    Very interesting, if that math is correct. My wheels are nearly 85lb/piece
  28. Aug 15, 2023 at 2:38 PM
    #58
    ..I have 3/2 lift and other mods, but added pedal commander. I still am averaging city mileage: 18.5L/100km - or 15.29mpg. Stock OR is 16mpg according to google..
  29. Aug 15, 2023 at 5:21 PM
    #59
    Tacticalchaplain
    2016 TRDP
    Los Angeles city traffic daily and weekly runs to San Diego and back… 16.3mpg
    will see if that changes over time with the Wildpigs.
  30. Aug 15, 2023 at 7:56 PM
    #60
    You're the first I've heard call Wildpeaks, Wildpigs. Although that is a funny clever name lol
    A. You bought them
    B. You're not running a dog or pig kind of setup believe me
