Hand Held Air compressor opinions please
Discussion in '5th Gen 4Runners (2010-2024)' started by jake1530, Feb 13, 2025.
  1. Feb 15, 2025 at 5:57 PM
    Shredder
    Shredder New Member
    Galaxy 47
    23 OR
    Tires, shocks
  2. Feb 15, 2025 at 6:13 PM
    After all the suggestions, I watched at least half a dozen comparison videos, and have yet to see one that the Milwaukee M18 inflator didn't win. I found one on sale for $59.50 and snatched it up before they were all gone from the site.
  3. Feb 15, 2025 at 8:43 PM
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    Whoa!! $60 fantastic deal! Good on you …:yes::yes::yes:
  4. Feb 15, 2025 at 8:56 PM
    Gman2530
    Gman2530 New Member
    FYI: I purchased this model this size at Home Depot early December they were having a sale on them. 50% off… This one lasts 5 complete cycles on all 4 tires, 33s aired down to 20psi aired up to 36psi i’ve read that they have a new more powerful edition that’s more compact also I purchased a charger locally off offerup
    You won’t be disappointed :bowdown::cheers:
    https://www.amazon.com/Redlithium-H...=&hvlocphy=9061197&hvtargid=pla-2281435180498
    Thacrow likes this.
  5. Feb 15, 2025 at 10:16 PM
    lowflyer
    lowflyer New Member
    2023 TRD ORP w/ KDSS <2021 Venture w/o KDSS <line of Tundras
    I've used the Superflow MV-50 for years and run two hoses off of it simultaneously. I think it fills my stock size tires very quickly.
  6. Mar 12, 2025 at 8:35 AM
    Well, I fell for it. Too good to be true? Yup. The $60 Milwaukee M18 inflator I ordered from that site almost 4 weeks ago was a total scam. I should know better. Paypal has already refunded the payment. I guess I'll have to buy it from a reputable source. Talk about stupid...
  7. Mar 12, 2025 at 10:44 AM
    I have the Viair 300P and it's not bad with my 295's. I think I timed it around 2 minutes per tire to get from ~15 (might have been 12, but not sure) up to 35.
    A guy in our group has the ARB twin, and it seems really nice!
  8. Mar 12, 2025 at 10:49 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    That's not bad at all.
    The Viar 88P takes about 30 minutes total going from 12 psi to 40. For the price the 300P seems like a great value and a huge time saver. Thanks for the heads up!
  9. Mar 12, 2025 at 11:03 AM
  10. Mar 12, 2025 at 1:03 PM
    1SilverRunner
    Tejas
    It gets crazy hot be the end of it...
    Maybe takes two minutes to change from tire to tire. So I bet I'm pushing that 25 minute duty cycle.
    High time to upgrade. But I've had analysis paralysis about this... Bigger Viar, Thors lightning, or on board air....
    Should probably just settle for the 300P or maybe even a 400P EF.
  11. Mar 12, 2025 at 1:07 PM
    It seems like there are three tiers of air compressors.
    Tier 3: the smallish models with the internal rechargeable battery.
    • Budget option.
    • Small and very portable. Can often fit in a glove box or cubby.
    • Usually has a brand name you never heard of.
    • Not intended for inflating 4 off-road tires. Better used for topping up tires, or airing up after repairing a flat.
    • Not very reliable.
    • Slow.
    Tier 2: compressors that use common power tool batteries.
    • Price and quality are variable.
    • Reliability can be predicted by the performance of the brand’s other tools. (i.e. Milwaukee, DeWalt, Makita, Bosch).
    • will all be more reliable than tier 3 compressors.
    • Capable of swapping out depleted batteries for charged ones.
    • Middling in terms of speed.
    Tier 1: you know who they are. ARB and Viair are the big players here. There’s also a dual head compressor that is marketed under several names, like Maxi-Trac and SmittyBuilt, that seems to be gaining a reputation.
    • Output varies by model and price. You pay more for speed.
    • They are mostly made of metal.
    • They can be expensive but don’t need to be.
    • They are not in the first tier because they’re the fastest. They’re in tier 1 because they are the most reliable.
    The king of on-board air compressors is the Oasis. 100% continuous duty cycle. Enough output to run air tools. Stupidly expensive. Only an insane person would consider it. Truly the elephant in the room.
    In my experience, none of these portable compressors is 100% dependable. I’ve had an ARB twin that failed. Also in my experience, none of these compressors is as fast as they say they are.
    I have a Viair 400P. I would consider the 88p to be equally reliable, and small enough to carry in the vehicle all the time. So why shoulder the extra expense of the 400P? Duty cycle. The 400p can air up more than 1 vehicle without maxing out its duty cycle.
    I consider the 400p (and accoutrements) to be too big to carry all the time. I’m considering the Noco Boost Air AX65 combination compressor and boost box. It’s new, so I’ll wait for more reviews, but I like the idea.
  12. Mar 12, 2025 at 1:30 PM
    1SilverRunner
    Tejas
    Eff it. I had like $140 in Amazon gift cards. Went ahead and ordered the Viar 400P-A EF. Item 40145.
    Thanks @Thatbassguy for the push. Now I don't have to dread airing up my tires!
    Thatbassguy and Captain Spalding like this.
  13. Mar 12, 2025 at 4:02 PM
    Good analysis!
    I've heard a lot of praise for the Milwaukee M18 compressor, but haven't seen it in action yet.
    The Viair 300P definitely takes up some space. I keep it in a Husky bag along with the custom hose I assembled. I'm able to tuck it into my platform out of the way, so it's not a nuisance.
    You're welcome! I'm always happy to help folks get rid of their extra money.
  14. Mar 12, 2025 at 5:25 PM
    You shoulda said EF it...:D:rimshot:
    Let us know how it works.
  15. Mar 13, 2025 at 5:19 AM
    J.A.
    J.A. New Member
    NY
    2007 4Runner Sport 4WD V-8
    www.top4runners.com
    I use the same one as well and love it. https://www.top4runners.com/ja/2007/air.html. Though this may be discontinued now, I think its being sold under the Buffalo Tools Black Bull AC150 name now.
  16. Mar 22, 2025 at 4:09 PM
    chrisb009
    chrisb009 New Member
    Chris
    4Runner
    I purchased a VIAIR air compressor...it works fine.
  17. Mar 22, 2025 at 4:33 PM
    Gman2530
    Gman2530 New Member
    I’m sorry I didn’t see this sooner, but check Home Depot. They were having a sale on them.
  18. Mar 22, 2025 at 8:42 PM
    I appreciate the tip, thanks. No sale currently at Home Depot I could find, it's $179 + tax there. I found it in Amazonia for $137.50 with free 2-day shipping, and no tax. It'll be here Monday.
    Thanks again. Any review of the M18 inflator you'd like to share?
  19. Mar 23, 2025 at 4:21 AM
    #49
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Nothing beats a tank. Especially if you don't use it a ton.
    And i use my tanks weekly.
  20. Mar 23, 2025 at 7:23 AM
    #50
  21. Mar 23, 2025 at 8:08 AM
    #51
    J.A.
    J.A. New Member
    NY
    www.top4runners.com
  22. Mar 23, 2025 at 8:52 AM
    #52
    Blackshirt
    Blackshirt New Member
    ‘24 SR5 Premium 4WD
    I have used a Viair 60P for years. It has been reliable and powerful for its smallish size. It’s also well packaged, making it easy to move to another vehicle. It is powered by a 12v source. This gets used in our sedan and our Sidecar outfit for long trips and the suv for refilling aired down tires off-road.
  23. Mar 26, 2025 at 10:55 AM
    #53
    surfingbuddhist
    surfingbuddhist New Member
    Glen
    2020 4Runner
    It's all about CFM's - this one is super fast airing up all 4 tires at the same time. I mounted this one with a C4 second battery tray under my hood, so I always have air available. upload_2025-3-26_10-54-50.png
    kmeeg[QUOTED] likes this.
  24. Mar 26, 2025 at 1:24 PM
    #54
    I’d say CFMs take a back seat to duty cycle. The inflation time savings are small compared to the off-time waiting for your compressor to cool down.
    5thToy, glwood54 and Thacrow like this.
  25. Apr 1, 2025 at 10:51 AM
    #55
    surfingbuddhist
    Glen
    2020 4Runner
    Have never had to wait for mine to cool down.
  26. Apr 1, 2025 at 12:59 PM
    #56
    You're so right, I dont have the best one and it takes forever to air back up. So painful
    the project farm guy is amazing. Ive bought several products based only on his recommendations
    Thacrow[QUOTED] likes this.
  27. Apr 2, 2025 at 11:51 AM
    #57
    Duty cycle is only a concern for the puny compressors. A high-flow compressor like the EZ Flate Moab linked earlier is ~50 sec per tire, so less than 4 minutes of total run time. You can go through an entire wheeling season and run the compressor just half an hour per year lol.
  28. Apr 2, 2025 at 5:18 PM
    #58
    surfingbuddhist
    Glen
    2020 4Runner
    This^. The 6.35CFM compressor airs up all 4 tires at the same time so quickly it never has a chance to overheat. I can air up my car and then a 2nd car immediately after with no issues.
